ich habe versucht SysCP auf meinem Debian-Sarge-Server zu installieren:
gibt folgende Fehlermeldung:
Das bedeutet für mich, das ich bind9 installieren muss?
Nun versuche ich die Installation von Bind9
Nun erhalte ich folgende Fehlermeldung:
Was kann ich tun, komme leider nicht weiter ...
Währe nett, wenn mir jemand weiterhelfen könnte
Vielen Dank
apt-get install syscp
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
syscp: Depends: bind9 but it is not going to be installed
E: Broken packages
apt-get install bind9
bind9: Depends: libdns16 but it is not installable
Depends: libisc7 but it is not installable
Depends: libisccfg0 but it is not installable
Depends: liblwres1 but it is not installable
Depends: libdns16 (= 1:9.2.4-1) but it is not installable
Depends: libisccfg0 (= 1:9.2.4-1) but it is not installable
Depends: libisc7 (= 1:9.2.4-1) but it is not installable
Depends: libisccc0 (= 1:9.2.4-1) but 1:9.3.2-2 is to be installed
E: Broken packages
Vielen Dank
