hallo zusammen
Beim Aufrufen von Horde erhalte ich folgende Fehler:
Hat ev. jemand eine Idee und kann mir weiter helfen?
Ev. per MSN: chris71@gmx.net
Vielen Dank
Gruss v.
Chris
web1p1
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'confixximailread'@'localhost' (using password: YES) in /var/www/confixx/html/horde3/config/hooks.php on line 1114
Warning: mysql_select_db() [function.mysql-select-db]: Access denied for user 'www-data'@'localhost' (using password: NO) in /var/www/confixx/html/horde3/config/hooks.php on line 1115
Warning: mysql_select_db() [function.mysql-select-db]: A link to the server could not be established in /var/www/confixx/html/horde3/config/hooks.php on line 1115
Warning: mysql_query() [function.mysql-query]: Access denied for user 'www-data'@'localhost' (using password: NO) in /var/www/confixx/html/horde3/config/hooks.php on line 1118
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /var/www/confixx/html/horde3/config/hooks.php on line 1118
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /var/www/confixx/html/horde3/config/hooks.php on line 1119
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /var/www/confixx/html/horde3/config/hooks.php on line 1130
Warning: mysql_close(): no MySQL-Link resource supplied in /var/www/confixx/html/horde3/config/hooks.php on line 1131
Vielen Dank
Gruss v.
Chris
