rguerrilla
Hallo Ihr!
Hab ein weiteres Problem: Ich kann keine Mails von extern empfangen. Das Senden von eMails an externe Accounts funktioniert wunderbar. Auch intern (also von zwei Domains auf dem gleichen Server) kann ich wunderbar eMails verschicken. Nur halt von externen Accounts anderer Server kommt nichts an.
Hier meine main.cf
Hier meine main.cf
# Postfix MTA Manager Main Configuration File;
# Please do NOT edit this file manually;
# Postfix directory settings; These are critical for normal Postfix MTA functionallity;
command_directory = /usr/sbin
program_directory = /usr/lib/postfix
# Some common configuration parameters;
inet_interfaces = all
mynetworks_style = host
myhostname = server491.xl-server.org
mydomain = server491.xl-server.org.local
myorigin = $mydomain
smtpd_banner = $myhostname ISPCP 1.0 Priamos Managed ESMTP 1.0.0 RC2 OMEGA
setgid_group = postdrop
# Receiving messages parameters;
mydestination = $myhostname, $mydomain
append_dot_mydomain = no
append_at_myorigin = yes
local_transport = local
virtual_transport = virtual
transport_maps = hash:/etc/postfix/ispcp/transport
# Delivering local messages parameters;
# Mailboxquota
# => 0 for unlimited
# => 104857600 for 100 MB
mailbox_size_limit = 0
biff = no
local_destination_recipient_limit = 1
local_recipient_maps = unix:passwd.byname $alias_database
# ISPCP Autoresponder parameters;
ispcp-arpl_destination_recipient_limit = 1
# Delivering virtual messages parameters;
virtual_mailbox_base = /var/mail/virtual
virtual_mailbox_limit = 0
virtual_mailbox_domains = hash:/etc/postfix/ispcp/domains
virtual_mailbox_maps = hash:/etc/postfix/ispcp/mailboxes
virtual_alias_maps = hash:/etc/postfix/ispcp/aliases
virtual_minimum_uid = 1000
virtual_uid_maps = static:1000
virtual_gid_maps = static:8
# SASL paramters;
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_sender_restrictions = permit_mynetworks,
permit_sasl_authenticated,
reject_unauth_destination
smtpd_recipient_restrictions = permit_mynetworks,
check_policy_service inet:127.0.0.1:60000
# TLS parameters; activate, if avaible/used
#smtpd_tld_loglevel = 2
#smtpd_tls_cert_file = /etc/postfix/cert.pem
#smtpd_tls_key_file = /etc/postfix/privkey.pem
#smtpd_use_tls = yes
#smtpd_tls_auth_only = no
#smtpd_tls_received_header = yes
# AMaViS parameters; activate, if avaible/used
#content_filter = amavis:[127.0.0.1]:10024
# Quota support; activate, if avaible/used
#virtual_create_maildirsize = yes
#virtual_mailbox_extended = yes
#virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
#virtual_mailbox_limit_override = yes
#virtual_maildir_limit_message = "The user you're trying to reach is over mailbox quota."
#virtual_overquota_bounce = yes
