Postfix und Courier mit Greylisting
killahmark
Hallo Leute,
ich habe ein Problem mit dem Empfang von E-Mails, dass sie nicht zugestellt werden.
Sep 30 17:14:16 hostname postfix/smtpd[26211]: connect from mout.gmx.net[212.227.17.22]
Sep 30 17:14:16 hostname postfix/smtpd[26211]: setting up TLS connection from mout.gmx.net[212.227.17.22]
Sep 30 17:14:16 hostname postfix/smtpd[26211]: Anonymous TLS connection established from mout.gmx.net[212.227.17.22]: TLSv1 with cipher DHE-RSA-AES128-SHA (128/128 bits)
Sep 30 17:14:23 hostname postfix/policyd-weight[3766]: decided action=PREPEND X-policyd-weight: using cached result; rate: -8.5; <client=212.227.17.22> <helo=mout.gmx.net> <from=meine.mail@gmx.de> <to=e-mail@meine-domain.tld>; delay: 7s
Sep 30 17:14:23 hostname postgrey[25946]: action=pass, reason=triplet found, client_name=mout.gmx.net, client_address=212.227.17.22, sender=meine.mail@gmx.de, recipient=e-mail@meine-domain.tld
Sep 30 17:14:23 hostname postfix/smtpd[26211]: D99275A90024: client=mout.gmx.net[212.227.17.22]
Sep 30 17:14:23 hostname postfix/cleanup[26216]: D99275A90024: message-id=<trinity-3221cf92-fb67-4759-afcf-0c87528e316b-1380554055272@3capp-gmx-bs07>
Sep 30 17:14:23 hostname postfix/qmgr[26207]: D99275A90024: from=<meine.mail@gmx.de>, size=1408, nrcpt=1 (queue active)
Sep 30 17:14:23 hostname spamd[1808]: spamd: connection from localhost.localdomain [127.0.0.1] at port 56935
Sep 30 17:14:23 hostname spamd[1808]: spamd: creating default_prefs: /home/spamc/.spamassassin/user_prefs
Sep 30 17:14:23 hostname postfix/smtpd[26211]: disconnect from mout.gmx.net[212.227.17.22]
Sep 30 17:14:23 hostname spamd[1808]: config: created user preferences file: /home/spamc/.spamassassin/user_prefs
Sep 30 17:14:24 hostname spamd[1808]: spamd: processing message <trinity-3221cf92-fb67-4759-afcf-0c87528e316b-1380554055272@3capp-gmx-bs07> for spamc:1000
Sep 30 17:14:28 hostname spamd[1808]: spamd: clean message (1.1/5.0) for spamc:1000 in 5.0 seconds, 1379 bytes.
Sep 30 17:14:28 hostname spamd[1808]: spamd: result: . 1 - FREEMAIL_FROM,HTML_MESSAGE,MIME_HTML_ONLY,RCVD_IN_DNSWL_NONE scantime=5.0,size=1379,user=spamc,uid=1000,required_score=5.0,rhost=localhost.localdomain,raddr=127.0.0.1,rport=56935,mid=<trinity-3221cf92-fb67-4759-afcf-0c87528e316b-1380554055272@3capp-gmx-bs07>,autolearn=no
Sep 30 17:14:28 hostname postfix/sendmail[26218]: fatal: usage: sendmail [options]
Sep 30 17:14:28 hostname postfix/pipe[26217]: D99275A90024: to=<web0p2@mein-server.de>, orig_to=<e-mail@meine-domain.tld>, relay=spamassassin, delay=12, delays=7.3/0/0/5, dsn=4.3.0, status=deferred (temporary failure. Command output: sendmail: option requires an argument -- 'f' sendmail: option requires an argument -- 'f' sendmail: fatal: usage: sendmail [options] )
Sep 30 17:14:29 hostname spamd[1807]: prefork: child states: II
(E-Mails wurden geändert, stimmen aber soweit im log)
