Postfix spam Probleme mit Plesk
Krie9er
Hallo ich habe ein Problem mit Postfix und Plesk und hoffe ihr könnt mir helfen.
Und zwar:
Ich habe im Plesk das relaying aktiviert, mit auth via smtp.
Meine Config seht ihr hier:
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_use_tls = yes
smtp_enforce_tls = yes
myhostname = *****
mydestination = localhost.vserver.de, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8 [::1]/128 80.86.91.235/32
mailbox_size_limit = 51200000
recipient_delimiter = +
inet_interfaces = all
smtpd_sasl_local_domain =
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_mynetworks, check_client_access pcre:/var/spool/postfix/plesk/no_relay.re, permit_sasl_authenticated, reject_unauth_destination
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
inet_protocols = all
virtual_mailbox_maps = hash:/var/spool/postfix/plesk/vmailbox
transport_maps = hash:/var/spool/postfix/plesk/transport
smtp_tls_security_level = may
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated, check_client_access pcre:/var/spool/postfix/plesk/non_auth.re
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
virtual_uid_maps = static:110
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768
non_smtpd_milters = , inet:127.0.0.1:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
mailman_destination_recipient_limit = 1
message_size_limit = 10240000
Nun bekomme ich irgendwie von meiner eigenen Emailadresse Spam zugeschickt.
Via telnet habe ich das auch mal ausprobiert und es passierte folgendes:
220 ****** ESMTP Postfix (Debian/GNU)
mail from: test@test.de
250 2.1.0 Ok
rcpt to: user@****.de
250 2.1.5 Ok
data
354 End data with <CR><LF>.<CR><LF>
250 2.0.0 Ok: queued as D1C22962151A
ich kann einfach so mails an mich selbst senden oO
obwohl enforc tls aktiviert ist :-( (s.o.)
ich bin langsam am ende mit meinem Latein, hatte folgende flags auch ausprobiert:
smtpd_helo_required = yes
smtpd_delay_reject = no
	permit_mynetworks,
	reject_invalid_hostname,
	reject_non_fqdn_hostname,
	reject_non_fqdn_sender,
	reject_non_fqdn_recipient,
	reject_unknown_sender_domain,
	reject_unknown_recipient_domain,
	reject_unauth_pipelining,
	reject_unauth_destination,
	reject_rbl_client zombie.dnsbl.sorbs.net,
	reject_rbl_client relays.ordb.org,
	reject_rbl_client opm.blitzed.org,
	reject_rbl_client list.dsbl.org,
	reject_rbl_client sbl.spamhaus.org,
	reject_rbl_client blackholes.easynet.nl,
	reject_rbl_client unconfirmed.dsbl.org,
	reject_rbl_client dynablock.njabl.org,
	reject_rbl_client dialup.blacklist.jippg.org,
	reject_rbl_client cbl.abuseat.org,
	permit
smtpd_helo_restrictions =
	permit_mynetworks,
	reject_rhsbl_client rhsbl.sorbs.net,
	reject_rhsbl_sender rhsbl.sorbs.net,
	reject_rbl_client multihop.dsbl.org,
	permit_mynetworks,
haben leider auch nicht geholfen :'(
Ich hoffe ihr habt eine Idee
LG Krie9er
Postfix nimmt alle Mails an für die eine Mailbox samt Domain auf dem System existiert.
Das ist Usus.
Was willst du denn genau erreichen?
