Postfix-Problem
imported_loisl
kann mir bitte mal jemand Helfen .... bin schon fast einem Woche dran und komme nicht auf die Lösung.
Vorab schon mal vielen lieben Dank :-)
INFOS:
Server bei EUServ
ispCP RC5a
Mit den derzeitigen Einstellungen kommen die Emails sofort mit der Nachricht "Undelivered Mail Return to Sender" zurück
postconf -n
append_at_myorigin = yes
append_dot_mydomain = no
biff = no
command_directory = /usr/sbin
inet_interfaces = all
local_destination_recipient_limit = 1
local_recipient_maps = unix:passwd.byname $alias_database
local_transport = local
mailbox_size_limit = 0
mydestination = $myhostname, $mydomain
mydomain = mail.ifarbe.de
myhostname = ifarbe.de
mynetworks_style = host
myorigin = $myhostname
recipient_delimiter = +
setgid_group = postdrop
smtpd_banner = $myhostname ESMTP ispCP 1.0.0 RC5 OMEGA Managed
smtpd_data_restrictions = reject_multi_recipient_bounce, reject_unauth_pipelining
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_invalid_helo_hostname, reject_non_fqdn_helo_hostname
smtpd_recipient_restrictions = reject_non_fqdn_recipient, reject_unknown_recipient_domain, permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_unlisted_recipient, check_policy_service inet:127.0.0.1:12525, check_policy_service inet:127.0.0.1:60000, permit
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_sender_restrictions = reject_non_fqdn_sender, reject_unknown_sender_domain, permit_mynetworks, permit_sasl_authenticated
transport_maps = hash:/etc/postfix/ispcp/transport
virtual_alias_maps = hash:/etc/postfix/ispcp/aliases
virtual_gid_maps = static:8
virtual_mailbox_base = /var/mail/virtual
virtual_mailbox_domains = hash:/etc/postfix/ispcp/domains
virtual_mailbox_limit = 0
virtual_mailbox_maps = hash:/etc/postfix/ispcp/mailboxes
virtual_minimum_uid = 1000
virtual_transport = virtual
virtual_uid_maps = static:1000
mail.warn (Auszug)
Jul 14 13:17:58 85-31-187-210 postfix/trivial-rewrite[18144]: warning: do not list domain ifarbe.de in BOTH mydestination and virtual_mailbox_domains
Jul 14 13:18:02 85-31-187-210 last message repeated 2 times
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18234]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18234]: fatal: unable to use my own hostname
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18235]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18235]: fatal: unable to use my own hostname
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18236]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18236]: fatal: unable to use my own hostname
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18237]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 13:25:35 85-31-187-210 postfix/virtual[18237]: fatal: unable to use my own hostname
Jul 14 13:25:36 85-31-187-210 postfix/qmgr[18232]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 14 13:25:36 85-31-187-210 postfix/qmgr[18232]: warning: private/virtual socket: malformed response
Jul 14 13:25:36 85-31-187-210 postfix/qmgr[18232]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 14 13:25:36 85-31-187-210 postfix/master[18229]: warning: process /usr/lib/postfix/virtual pid 18234 exit status 1
Jul 14 13:25:36 85-31-187-210 postfix/master[18229]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 14 13:25:36 85-31-187-210 postfix/master[18229]: warning: process /usr/lib/postfix/virtual pid 18235 exit status 1
Jul 14 13:25:36 85-31-187-210 postfix/master[18229]: warning: process /usr/lib/postfix/virtual pid 18236 exit status 1
Jul 14 13:25:36 85-31-187-210 postfix/master[18229]: warning: process /usr/lib/postfix/virtual pid 18237 exit status 1
Jul 14 13:26:11 85-31-187-210 postfix/trivial-rewrite[18233]: warning: do not list domain ifarbe.de in BOTH mydestination and virtual_mailbox_domains
Jul 14 13:26:13 85-31-187-210 postfix/trivial-rewrite[18233]: warning: do not list domain ifarbe.de in BOTH mydestination and virtual_mailbox_domains
Jul 14 13:42:15 85-31-187-210 postfix/virtual[18364]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 13:42:15 85-31-187-210 postfix/virtual[18364]: fatal: unable to use my own hostname
Jul 14 13:42:16 85-31-187-210 postfix/qmgr[18232]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 14 13:42:16 85-31-187-210 postfix/qmgr[18232]: warning: private/virtual socket: malformed response
Jul 14 13:42:16 85-31-187-210 postfix/qmgr[18232]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 14 13:42:16 85-31-187-210 postfix/master[18229]: warning: process /usr/lib/postfix/virtual pid 18364 exit status 1
Jul 14 13:42:16 85-31-187-210 postfix/master[18229]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
mail.err (Auszug)
Jul 14 13:01:41 85-31-187-210 postfix/virtual[18066]: fatal: unable to use my own hostname
Jul 14 13:08:11 85-31-187-210 amavis[2080]: (02080-01) TROUBLE in process_request: Error writing a SMTP response to the socket: Broken pipe at (eval 43) line 778, <GEN3> line 47.
Jul 14 13:08:29 85-31-187-210 amavis[2081]: (02081-01) TROUBLE in process_request: Error writing a SMTP response to the socket: Broken pipe at (eval 43) line 778, <GEN3> line 20.
mail.log (Auszug)
Jul 14 13:42:15 85-31-187-210 amavis[18113]: (18113-01) Passed CLEAN, [81.89.247.3] [81.89.247.3] <devnull@adbutler.de> -> <loisl@fast-server.eu>, Message-ID: <200807141004.m6EA40L25165@statistik.adbutler.de>, Hits: -, 262 ms
Jul 14 13:42:15 85-31-187-210 postfix/smtp[18359]: 56AE110F06F4: to=<loisl@fast-server.eu>, relay=127.0.0.1[127.0.0.1]:10024, delay=4299, delays=4299/0.01/0.01/0.26, dsn=2.6.0, status=sent (250 2.6.0 Ok, id=18113-01, from MTA: 250 2.0.0 Ok: queued as C260710F06DA)
Jul 14 13:42:15 85-31-187-210 postfix/qmgr[18232]: 56AE110F06F4: removed
Jul 14 13:42:16 85-31-187-210 postfix/qmgr[18232]: C260710F06DA: to=<loisl@fast-server.eu>, relay=none, delay=1.1, delays=0.06/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 13:52:06 85-31-187-210 imapd: Connection, ip=[::ffff:93.133.231.136]
Jul 14 13:52:06 85-31-187-210 imapd: LOGIN, user=loisl@ifarbe.de, ip=[::ffff:93.133.231.136], protocol=IMAP
Jul 14 13:55:03 85-31-187-210 postfix/pickup[18231]: 7D43A10F06E2: uid=109 from=<amavis>
Jul 14 13:55:03 85-31-187-210 postfix/cleanup[18382]: 7D43A10F06E2: message-id=<20080714115503.7D43A10F06E2@ifarbe.de>
Jul 14 13:55:03 85-31-187-210 postfix/qmgr[18232]: 7D43A10F06E2: from=<amavis@ifarbe.de>, size=1033, nrcpt=1 (queue active)
Jul 14 13:55:03 85-31-187-210 postfix/trivial-rewrite[18383]: warning: do not list domain ifarbe.de in BOTH mydestination and virtual_mailbox_domains
Jul 14 13:55:03 85-31-187-210 postfix/local[18384]: 7D43A10F06E2: to=<loisl@ifarbe.de>, orig_to=<amavis>, relay=local, delay=0.77, delays=0.75/0.01/0/0.01, dsn=5.1.1, status=bounced (unknown user: "loisl")
Jul 14 13:55:03 85-31-187-210 postfix/cleanup[18382]: 8763B10F06EE: message-id=<20080714115503.8763B10F06EE@ifarbe.de>
Jul 14 13:55:03 85-31-187-210 postfix/qmgr[18232]: 8763B10F06EE: from=<>, size=2715, nrcpt=1 (queue active)
Jul 14 13:55:03 85-31-187-210 postfix/bounce[18386]: 7D43A10F06E2: sender non-delivery notification: 8763B10F06EE
Jul 14 13:55:03 85-31-187-210 postfix/qmgr[18232]: 7D43A10F06E2: removed
Jul 14 13:55:03 85-31-187-210 postfix/local[18384]: 8763B10F06EE: to=<loisl@ifarbe.de>, orig_to=<amavis@ifarbe.de>, relay=local, delay=0.02, delays=0.01/0/0/0.01, dsn=5.1.1, status=bounced (unknown user: "loisl")
Jul 14 13:55:03 85-31-187-210 postfix/qmgr[18232]: 8763B10F06EE: removed
mail.info (Auszug)
Kann es sein, dass Du einerseits die Domain ifarbe.de als domain für den Server und andererseits mit ISPCP mindestens einen virtuellen Benutzer angelegt hast, auf den die identische domain läuft?
In diesem Fall solltest Du etwas ändern, den ISPC-Benutzer oder die Einträge in /etc/postfix/main.cf
Z.B.:
mydomain = server.ifarbe.de
myhostname = mail.server.ifarbe.de
Dann restart und nochmal die logs checken, was noch so rausfällt.
Hallo yavhcsu,
Ja, die Domain ifarbe.de läuft auch als domain für den Server mit ISPCP.
Glaube mein grosses Problem ist warning: valid_hostname: numeric hostname: 85-31-187-210
Habe nach denen Tipps abgeändert wie folgt:
mydomain = s10.ifarbe.de
myhostname = mail.s10.ifarbe.de
Versand klappt wie bisher astrein :-)
Wenn ich eine mail an den Server sende kommt der Absender keine Fehlermeldung mehr. Jetzt bin ich wieder soweit, wie vor einer Woche.
in der mail.err
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19212]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19213]: fatal: unable to use my own hostname
in der mail.log
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: C260710F06DA: from=<devnull@adbutler.de>, size=15279, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: ACF4E10F06DE: from=<loisl@iFOTOGRAF.de>, size=838, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: D14FA10F06DB: from=<loisl@farbenaberrichtig.de>, size=1429, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 1477210F06E4: from=<>, size=3207, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 11DB910F06E3: from=<loisl@ifotograf.de>, size=1186, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 07DFF10F0219: from=<loisl@farbenaberrichtig.de>, size=1438, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 082E110F0213: from=<loisl@farbenaberrichtig.de>, size=1442, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 891C110F06E6: from=<loisl@ifotograf.de>, size=1630, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 8EFAD10F06CE: from=<loisl@ifotograf.de>, size=1398, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/qmgr[18906]: 6BDF410F06D3: from=<loisl@ifarbe.de>, size=1450, nrcpt=1 (queue active)
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19207]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19207]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19209]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19209]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19208]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19208]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19210]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19210]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19211]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19211]: fatal: unable to use my own hostname
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19212]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:42 85-31-187-210 postfix/virtual[19213]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: warning: private/virtual socket: malformed response
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19207 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19209 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: C260710F06DA: to=<loisl@fast-server.eu>, relay=none, delay=10048, delays=10047/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 891C110F06E6: to=<loisl@farbenaberrichtig.de>, relay=none, delay=76962, delays=76961/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19208 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19210 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19211 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19212 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/master[18892]: warning: process /usr/lib/postfix/virtual pid 19213 exit status 1
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 8EFAD10F06CE: to=<loisl@farbenaberrichtig.de>, relay=none, delay=72345, delays=72344/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 6BDF410F06D3: to=<loisl@farbenaberrichtig.de>, relay=none, delay=72495, delays=72494/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 1477210F06E4: to=<loisl@farbenaberrichtig.de>, relay=none, delay=430517, delays=430516/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 11DB910F06E3: to=<loisl@farbenaberrichtig.de>, relay=none, delay=423193, delays=423192/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: ACF4E10F06DE: to=<loisl@ifarbe.de>, relay=none, delay=3916, delays=3915/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: D14FA10F06DB: to=<loisl@farbenaberrichtig.de>, relay=none, delay=72103, delays=72102/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 07DFF10F0219: to=<loisl@farbenaberrichtig.de>, relay=none, delay=196836, delays=196835/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:29:43 85-31-187-210 postfix/qmgr[18906]: 082E110F0213: to=<loisl@farbenaberrichtig.de>, relay=none, delay=256996, delays=256995/1.1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
Jul 14 16:36:13 85-31-187-210 imapd: Connection, ip=[::ffff:93.133.231.136]
Jul 14 16:36:13 85-31-187-210 imapd: LOGIN, user=loisl@ifarbe.de, ip=[::ffff:93.133.231.136], protocol=IMAP
Jul 14 16:37:14 85-31-187-210 imapd: Connection, ip=[::ffff:127.0.0.1]
Jul 14 16:37:14 85-31-187-210 imapd: LOGIN, user=loisl@ifarbe.de, ip=[::ffff:127.0.0.1], protocol=IMAP
Jul 14 16:37:14 85-31-187-210 imapd: LOGOUT, user=loisl@ifarbe.de, ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=87, sent=392, time=0
in der mail.warn
bitte zeig uns mal, was in der Datei /etc/hosts steht. Ich vermute mal, dass da Infos zu deinem Server stehen, die Postfix nciht ganz passen. ;)
der "Hostname" sollte in der Form:
xxxx.xxxxx.tld
oder
xxxxxx.tld
vorhanden sein.
Die Einträge in der etc/postfix/main.cf sollten so ausschauen:
myhostname = xxxxx.xxxxx.tld (oder xxxxx.tld)
mydomain = xxxxx.xxxxx.tld.local (oder xxxxx.tld.local)
Hallo Ihr lieben,
Vielen Dank dass Ihr euch meinem Problem annehmt.
lg loisl
etc/hosts
# 'hosts' file configuration.
127.0.0.1       85-31-187-210.blue.kundencontroller.de.local    localhost
85.31.187.210   85-31-187-210.blue.kundencontroller.de  85-31-187-210
::ffff:85.31.187.210    85-31-187-210.blue.kundencontroller.de  85-31-187-210
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
etc/postfix/main.cf
# ispCP ω (OMEGA) a Virtual Hosting Control System
# @copyright	2001-2006 by moleSoftware GmbH
# @copyright	2006-2008 by ispCP | http://isp-control.net
# @version		SVN: $ID$
# @link			http://isp-control.net
# @author		ispCP Team
# @license
#   This program is free software; you can redistribute it and/or modify it under
#   the terms of the MPL General Public License as published by the Free Software
#   Foundation; either version 1.1 of the License, or (at your option) any later
#   version.
#   You should have received a copy of the MPL Mozilla Public License along with
#   this program; if not, write to the Open Source Initiative (OSI)
#   http://opensource.org | osi@opensource.org
# Postfix directory settings; These are critical for normal Postfix MTA functionallity
# Some common configuration parameters
#myhostname                   = 85-31-187-210.blue.kundencontroller.de
#mydomain                     = 85-31-187-210.blue.kundencontroller.de.local
# Receiving messages parameters
# Delivering local messages parameters
# Mailboxquota
# => 0 for unlimited
# => 104857600 for 100 MB
biff                         = no
# ispCP Autoresponder parameters
ispcp-arpl_destination_recipient_limit = 1
# Delivering virtual messages parameters
# SASL paramters
                               permit_mynetworks,
                               permit_mynetworks,
                               permit
# TLS parameters; activate, if avaible/used
#smtpd_use_tls               = yes
#smtpd_tls_loglevel          = 2
#smtpd_tls_cert_file         = /etc/postfix/cert.pem
#smtpd_tls_key_file          = /etc/postfix/privkey.pem
#smtpd_tls_auth_only         = no
#smtpd_tls_received_header   = yes
# AMaViS parameters; activate, if available/used
##content_filter               = amavis:[127.0.0.1]:10024
##smtpd_sasl_authenticated_header = yes
# Quota support; activate, if available/used
#virtual_create_maildirsize     = yes
#virtual_mailbox_extended       = yes
#virtual_mailbox_limit_maps     = mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
#virtual_mailbox_limit_override = yes
#virtual_maildir_limit_message  = "The user you're trying to reach is over mailbox quota."
#virtual_overquota_bounce       = yes
Dafür sind wir ein Forum. ;)
Ok, das sieht eindeutig nach dem Problem aus.
85.31.187.210   85-31-187-210.blue.kundencontroller.de  s10.ifarbe.de
::ffff:85.31.187.210    85-31-187-210.blue.kundencontroller.de  s10.ifarbe.de
Führe bitte mal die Änderungen an der /etc/hosts, dass sie aussieht wie oben.
Das Problem bei der alten Konfiguration ist, dass der Server bei deiner IP immer eine IP zurückbekommt, obwohl du in den Serverdiensten natürlich was anderes eingetragen hast, z.B. in der main.cf s10.ifarbe.de. Ich gehe deshalb einfach mal davon aus, dass s10.ifarbe.de auf deinen Server zeigt.
Hallo .... ein wirklich schönes und konstruktives Forum :D
Erst eimal vorab noch was anderes
Im Forum von EUServ habe ich was gelesen, dass mehrere Probleme mit der Unkonformen Namensauflösung von
"85-31-187-210.blue.kundencontroller.de"
sollte ich mir die in ??? z.B. "s10.fast-server.eu" ändern lassen ???
Die Änderungen der /etc/hosts hatten schon mal den Erfolg,
dass die Fehlermeldungen weniger werden:
mail.err
Jul 15 10:15:08 85-31-187-210 postfix/virtual[2690]: fatal: unable to use my own hostname
Jul 15 10:31:48 85-31-187-210 postfix/virtual[2798]: fatal: unable to use my own hostname
Jul 15 10:31:48 85-31-187-210 postfix/virtual[2799]: fatal: unable to use my own hostname
mail.warn
Jul 15 10:15:09 85-31-187-210 postfix/master[2274]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 15 10:31:48 85-31-187-210 postfix/virtual[2798]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 10:31:48 85-31-187-210 postfix/virtual[2799]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 10:31:49 85-31-187-210 postfix/qmgr[2285]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 15 10:31:49 85-31-187-210 postfix/qmgr[2285]: warning: private/virtual socket: malformed response
Jul 15 10:31:49 85-31-187-210 postfix/qmgr[2285]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 15 10:31:49 85-31-187-210 postfix/master[2274]: warning: process /usr/lib/postfix/virtual pid 2798 exit status 1
Jul 15 10:31:49 85-31-187-210 postfix/master[2274]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 15 10:31:49 85-31-187-210 postfix/master[2274]: warning: process /usr/lib/postfix/virtual pid 2799 exit status 1
127.0.0.1 localhost localhost
85.31.187.210 s10.ifarbe.de s10.ifarbe.de
::ffff:85.31.187.210 ipv6.s10.ifarbe.de ipv6.s10.ifarbe.de
Ändere deine /etc/hosts so ab dann sollte Postfix nicht mehr meckern
Hm stimmt, is natürlich schwachsinnig, wenn ein Eintrag für die IPv4 und gleichzeitig für die IPv6 adresse aufgelöst wird... sorry :D
SOOOOO,
wollte eigentlich gerade schreiben, dass die mails noch nicht ankommen aber auch keine Fehlermeldungen da sind ... aber jetzt habe ich doch wieder welche
/var/log/mail.warn
Jul 15 12:54:48 85-31-187-210 postfix/virtual[2669]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 12:54:48 85-31-187-210 postfix/virtual[2669]: fatal: unable to use my own hostname
Jul 15 12:54:48 85-31-187-210 postfix/virtual[2670]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 12:54:48 85-31-187-210 postfix/virtual[2670]: fatal: unable to use my own hostname
Jul 15 12:54:49 85-31-187-210 postfix/qmgr[2625]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 15 12:54:49 85-31-187-210 postfix/qmgr[2625]: warning: private/virtual socket: malformed response
Jul 15 12:54:49 85-31-187-210 postfix/qmgr[2625]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 15 12:54:49 85-31-187-210 postfix/master[2622]: warning: process /usr/lib/postfix/virtual pid 2669 exit status 1
Jul 15 12:54:49 85-31-187-210 postfix/master[2622]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 15 12:54:49 85-31-187-210 postfix/master[2622]: warning: process /usr/lib/postfix/virtual pid 2670 exit status 1
Jul 15 12:56:03 85-31-187-210 postfix/virtual[2685]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 12:56:03 85-31-187-210 postfix/virtual[2685]: fatal: unable to use my own hostname
Jul 15 12:56:04 85-31-187-210 postfix/qmgr[2625]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 15 12:56:04 85-31-187-210 postfix/qmgr[2625]: warning: private/virtual socket: malformed response
Jul 15 12:56:04 85-31-187-210 postfix/qmgr[2625]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 15 12:56:04 85-31-187-210 postfix/master[2622]: warning: process /usr/lib/postfix/virtual pid 2685 exit status 1
Jul 15 12:56:04 85-31-187-210 postfix/master[2622]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
Jul 15 12:57:08 85-31-187-210 postfix/virtual[2693]: warning: valid_hostname: numeric hostname: 85-31-187-210
Jul 15 12:57:08 85-31-187-210 postfix/virtual[2693]: fatal: unable to use my own hostname
Jul 15 12:57:09 85-31-187-210 postfix/qmgr[2625]: warning: premature end-of-input on private/virtual socket while reading input attribute name
Jul 15 12:57:09 85-31-187-210 postfix/qmgr[2625]: warning: private/virtual socket: malformed response
Jul 15 12:57:09 85-31-187-210 postfix/qmgr[2625]: warning: transport virtual failure -- see a previous warning/fatal/panic logfile record for the problem description
Jul 15 12:57:09 85-31-187-210 postfix/master[2622]: warning: process /usr/lib/postfix/virtual pid 2693 exit status 1
Jul 15 12:57:09 85-31-187-210 postfix/master[2622]: warning: /usr/lib/postfix/virtual: bad command startup -- throttling
/var/log/mail.err
Da ist noch
die mich etwas irretiert. Die Meldung scheint von der postfix Komponente zu kommen, die für die Verwaltung der virtuellen mail domains zuständig ist.
Schau doch mal im Verzeichnis /etc/postfix/ispcp
die Dateien (domains, mailboxes, aliases, transport) durch, ob hier irgendwo 85-31-187-210 enthalten ist. Wenn ja, dann poste doch mal die Datei.
Noch etwas:
In Deiner /etc/hostname steht offensichtlich 85-31-187-210 bzw. als Teil des Namens drin. Ich würde hier den vollen Namen des Servers eintragen, also myserver.s10.ifarbe.de. Dann muß noch ein DNS-Eintrag beim Deinem domain hoster brav die auf die IP-Adresse zeigen. Perfekt wäre dann noch der passende Revers-DNS-Eintrag bei Deinem Server hoster.
Hallo yavhcsu,
Also in den ganzen Dateien vom Verzeichnis /etc/postfix/ispcp ist kein
85-31-187-210 zu finden ... Aber irgendwo muß es ja herkommen.
Habe mal die
im /etc/hostname eingetragen, die ist ja schon im DNS ....
mal testen
BINGO
ein test-mail ist eingetroffen vom SONNTAG ... der rest wird jetzt munter reinsprudeln
Na das klingt doch super :) Mal sehen ob wir im FAQ dafür einen Punkt einführen weil ich dass mit den "numeric hostnames" nun schon öfter als Problem gelesen hatte.
Sooo, alles Fehlerfrei und die mail trudeln auch immer mehr ein ...
Jetzt kommt fast schon eine peinliche Frage?
Für den Mailversand durch Outlook oder sonstige...
Wie heisst den nun jetzt mein
Servername:
SMTP-Server:
lg loisl
Das is einfach dein Server, in dem Fall s10.ifarbe.de, mail.ifarbe.de müsste aber auch gehen, sowohl für den Servernamen als auch für den SMTP-Server. ;)
lg loisl
Jop, is peinlich !
Für den Mailversand (bei Outlook) immer:
smtp.deinedomain.tld
