postfix/master ............Connection refused
xsaver
Plesk 11.5.30 Debian 7.5
Nach upgrade auf Postfix 2.11.0, sehe ich minütlich folgende Einträge in meinen logs /var/log/mail.warn (/opt/psa/var/log/maillog).
postfix/master[13441]: warning: master_wakeup_timer_event: service qmgr(public/qmgr): Connection refused
postfix/master[13441]: warning: master_wakeup_timer_event: service pickup(public/pickup): Connection refused
Einträge in /etc/postfix/master.cf sind
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
pickup unix n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
maildrop unix - n n - - pipe
uucp unix - n n - - pipe
ifmail unix - n n - - pipe
bsmtp unix - n n - - pipe
scalemail-backend unix - n n - 2 pipe
mailman unix - n n - - pipe flags=R user=list:list argv=/usr/lib/plesk-9.0/postfix-mailman ${nexthop} ${user} ${recipient}
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames
pickup fifo n - - 60 1 pickup
plesk_saslauthd unix y y y - 1 plesk_saslauthd status=5 listen=6 dbpath=/plesk/passwd.db
qmgr fifo n - n 1 1 qmgr
smtps inet n - - - - smtpd -o smtpd_tls_wrappermode=yes
submission inet n - - - - smtpd -o smtpd_enforce_tls=yes -o smtpd_tls_security_level=may -o smtpd_sasl_auth_enable=yes -o smtpd_client_restrictions=permit_sasl_authenticate d,reject -o smtpd_sender_restrictions= -o smtpd_recipient_restrictions=permit_mynetworks,per mit_sasl_authenticated,reject_unauth_destination
Was läuft da falsch ? Finde nichts hilfreiches weder bei postfix, noch bei plesk ! Wer kann helfen ?
Sorry, ist kein Geheimnis
Hier meine main.cf
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_key_file = /etc/postfix/postfix_default.pem
smtpd_use_tls = yes
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = apitec.eu
mydestination = localhost.eu, localhost, localhost.localdomain
mynetworks = 127.0.0.0/8 [::1]/128 xx.xx.xx.xx./32 xx.xx.xx.xx/32 xx.xx.xx.xx/32 [xxxx:xxxx:xxxx:xxx::x]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
virtual_mailbox_maps = , hash:/var/spool/postfix/plesk/vmailbox
transport_maps = , hash:/var/spool/postfix/plesk/transport
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated, check_client_access pcre:/var/spool/postfix/plesk/non_auth.re
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_rbl_client zen.spamhaus.org, reject_rbl_client bl.spamcop.net
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks check_client_access pcre:/var/spool/postfix/plesk/no_relay.re permit_sasl_authenticated reject_unauth_destination
virtual_uid_maps = static:30
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768
non_smtpd_milters = , inet:127.0.0.1:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
mailman_destination_recipient_limit = 1
virtual_mailbox_limit = 0
smtpd_tls_CAfile = /etc/postfix/rootchain.pem
Die Zertifikate wurden entsprechend angepasst.
