saslfinger -s
saslfinger - postfix Cyrus sasl configuration Sun Jun 10 18:17:43 CEST 2007
version: 1.0.1
mode: server-side SMTP AUTH
-- basics --
Postfix: 2.3.8
System: Debian GNU/Linux 4.0 \n \l
-- smtpd is linked to --
libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0xb7d8b000)
-- active SMTP AUTH and TLS parameters for smtpd --
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_tls_CAfile = /etc/ssl/certs/smtps.pem
smtpd_tls_cert_file = /etc/ssl/certs/smtps.pem
smtpd_tls_key_file = /etc/ssl/certs/smtps.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_use_tls = yes
-- listing of /usr/lib/sasl2 --
total 692
drwxr-xr-x 2 root root 4096 2007-06-09 17:13 .
drwxr-xr-x 40 root root 12288 2007-06-09 16:43 ..
-rw-r--r-- 1 root root 13304 2006-12-13 22:26 libanonymous.a
-rw-r--r-- 1 root root 855 2006-12-13 22:26 libanonymous.la
-rw-r--r-- 1 root root 12844 2006-12-13 22:26 libanonymous.so
-rw-r--r-- 1 root root 12844 2006-12-13 22:26 libanonymous.so.2
-rw-r--r-- 1 root root 12844 2006-12-13 22:26 libanonymous.so.2.0.22
-rw-r--r-- 1 root root 15502 2006-12-13 22:26 libcrammd5.a
-rw-r--r-- 1 root root 841 2006-12-13 22:26 libcrammd5.la
-rw-r--r-- 1 root root 15052 2006-12-13 22:26 libcrammd5.so
-rw-r--r-- 1 root root 15052 2006-12-13 22:26 libcrammd5.so.2
-rw-r--r-- 1 root root 15052 2006-12-13 22:26 libcrammd5.so.2.0.22
-rw-r--r-- 1 root root 46320 2006-12-13 22:26 libdigestmd5.a
-rw-r--r-- 1 root root 864 2006-12-13 22:26 libdigestmd5.la
-rw-r--r-- 1 root root 43040 2006-12-13 22:26 libdigestmd5.so
-rw-r--r-- 1 root root 43040 2006-12-13 22:26 libdigestmd5.so.2
-rw-r--r-- 1 root root 43040 2006-12-13 22:26 libdigestmd5.so.2.0.22
-rw-r--r-- 1 root root 13482 2006-12-13 22:26 liblogin.a
-rw-r--r-- 1 root root 835 2006-12-13 22:26 liblogin.la
-rw-r--r-- 1 root root 13384 2006-12-13 22:26 liblogin.so
-rw-r--r-- 1 root root 13384 2006-12-13 22:26 liblogin.so.2
-rw-r--r-- 1 root root 13384 2006-12-13 22:26 liblogin.so.2.0.22
-rw-r--r-- 1 root root 29300 2006-12-13 22:26 libntlm.a
-rw-r--r-- 1 root root 829 2006-12-13 22:26 libntlm.la
-rw-r--r-- 1 root root 28776 2006-12-13 22:26 libntlm.so
-rw-r--r-- 1 root root 28776 2006-12-13 22:26 libntlm.so.2
-rw-r--r-- 1 root root 28776 2006-12-13 22:26 libntlm.so.2.0.22
-rw-r--r-- 1 root root 13818 2006-12-13 22:26 libplain.a
-rw-r--r-- 1 root root 835 2006-12-13 22:26 libplain.la
-rw-r--r-- 1 root root 13992 2006-12-13 22:26 libplain.so
-rw-r--r-- 1 root root 13992 2006-12-13 22:26 libplain.so.2
-rw-r--r-- 1 root root 13992 2006-12-13 22:26 libplain.so.2.0.22
-rw-r--r-- 1 root root 21726 2007-05-30 13:09 libsasldb.a
-rw-r--r-- 1 root root 856 2007-05-30 13:09 libsasldb.la
-rw-r--r-- 1 root root 17980 2007-05-30 13:09 libsasldb.so
-rw-r--r-- 1 root root 17980 2007-05-30 13:09 libsasldb.so.2
-rw-r--r-- 1 root root 17980 2007-05-30 13:09 libsasldb.so.2.0.22
-- content of /etc/postfix/sasl/smtpd.conf --
pwcheck_method: saslauthd
mech_list: PLAIN LOGIN
-- active services in /etc/postfix/master.cf --
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
-o fallback_relay=
showq unix n - - - - showq
error unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
maildrop unix - n n - - pipe
uucp unix - n n - - pipe
ifmail unix - n n - - pipe
bsmtp unix - n n - - pipe
scalemail-backend unix - n n - 2 pipe
mailman unix - n n - - pipe
${nexthop} ${user}
cyrus unix - n n - - pipe
flags= user=cyrus argv=/usr/sbin/cyrdeliver -r ${sender} -m ${extension} ${user}
-- mechanisms on localhost --
250-AUTH PLAIN LOGIN
250-AUTH=PLAIN LOGIN
-- end of saslfinger output --
