Jan 3 19:24:51 vserver3 postfix/postfix-script[2729]: refreshing the Postfix mail system
Jan 3 19:24:51 vserver3 postfix/master[1779]: reload -- version 2.7.0, configuration /etc/postfix
Jan 3 19:25:51 vserver3 postfix/smtpd[2736]: connect from moutng.kundenserver.de[212.227.126.171]
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_connect: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_connect: exit
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_envfrom: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: queueid=unknown
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_envfrom: exit
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_envrcpt: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::output enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::output exit1
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_envrcpt: exit
Jan 3 19:25:51 vserver3 postfix/smtpd[2736]: 81B79A6058: client=moutng.kundenserver.de[212.227.126.171]
Jan 3 19:25:51 vserver3 postfix/cleanup[2741]: 81B79A6058: message-id=<4F03482D.7020902@example.net>
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_header: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::output exit2
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_header: exit
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_eoh: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_eoh: exit
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_body: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_body: exit
Jan 3 19:25:51 vserver3 spamass-milter[2654]: mlfi_eom: enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::input enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::empty_and_close_pipe enter
Jan 3 19:25:51 vserver3 spamass-milter[2654]: ::read_pipe enter
Jan 3 19:25:51 vserver3 spamd[527]: spamd: connection from localhost.localdomain [127.0.0.1] at port 45324
Jan 3 19:25:51 vserver3 spamd[527]: spamd: handle_user unable to find user: 'info'
Jan 3 19:25:51 vserver3 spamd[527]: spamd: still running as root: user not specified with -u, not found, or set to root, falling back to nobody
Jan 3 19:25:51 vserver3 spamd[527]: spamd: processing message <4F03482D.7020902@example.net> for info:65534
Jan 3 19:25:52 vserver3 spamd[527]: spamd: identified spam (1009.6/4.0) for info:65534 in 0.6 seconds, 1773 bytes.
Jan 3 19:25:52 vserver3 spamd[527]: spamd: result: Y 1009 - GTUBE,HELO_MISC_IP,KHOP_DYNAMIC,RCVD_IN_BRBL_LASTEXT,RCVD_IN_PBL,RCVD_IN_RP_RNBL,RCVD_IN_SORBS_DUL,TO_NO_BRKTS_DIRECT,UNPARSEABLE_RELAY scantime=0.6,size=1773,user=info,uid=65534,required_score=4.0,rhost=localhost.localdomain,raddr=127.0.0.1,rport=45324,mid=<4F03482D.7020902@example.net>,autolearn=no
Jan 3 19:25:52 vserver3 spamass-milter[2654]: ::read_pipe exit
Jan 3 19:25:52 vserver3 spamass-milter[2654]: ::read_pipe enter
Jan 3 19:25:52 vserver3 spamass-milter[2654]: ::empty_and_close_pipe exit
Jan 3 19:25:52 vserver3 spamass-milter[2654]: ::input exit2
Jan 3 19:25:52 vserver3 spamass-milter[2654]: mlfi_eom: exit
Jan 3 19:25:52 vserver3 postfix/qmgr[2733]: 81B79A6058: from=<wh.for@example.net>, size=1744, nrcpt=1 (queue active)
Jan 3 19:25:52 vserver3 postfix/smtpd[2736]: disconnect from moutng.kundenserver.de[212.227.126.171]
Jan 3 19:25:52 vserver3 spamass-milter[2654]: mlfi_close
Jan 3 19:25:52 vserver3 dovecot: deliver(info@test.de): msgid=<4F03482D.7020902@example.net>: saved mail to INBOX
Jan 3 19:25:52 vserver3 postfix/pipe[2744]: 81B79A6058: to=<info@test.de>, relay=dovecot, delay=0.71, delays=0.69/0.02/0/0.01, dsn=2.0.0, status=sent (delivered via dovecot service)
Jan 3 19:25:52 vserver3 postfix/qmgr[2733]: 81B79A6058: removed
Jan 3 19:25:52 vserver3 spamd[466]: prefork: child states: II
