Posfix Problem
Massimo
Moin
Ich habe mit Postfix ein Problem und zwar steht im mail.log immer solche Zeilen
Aug 14 09:40:01 eco3033 postfix/sendmail[25207]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/postdrop[25208]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/cleanup[25209]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/pickup[24758]: 729D18800AB: uid=110 from=<smmsp>
Aug 14 09:40:01 eco3033 postfix/trivial-rewrite[25210]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/cleanup[25209]: 729D18800AB: message-id=<20050814074001.729D18800AB@eco3033.netclusive.de>
Aug 14 09:40:01 eco3033 postfix/qmgr[17236]: 729D18800AB: from=<smmsp@eco3033.netclusive.de>, size=662, nrcpt=1 (queue active)
Aug 14 09:40:01 eco3033 postfix/smtp[25211]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/smtpd[25212]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/smtpd[25212]: connect from localhost.localdomain[127.0.0.1]
Aug 14 09:40:01 eco3033 postfix/smtpd[25212]: 87C568800AA: client=localhost.localdomain[127.0.0.1]
Aug 14 09:40:01 eco3033 postfix/cleanup[25209]: 87C568800AA: message-id=<20050814074001.729D18800AB@eco3033.netclusive.de>
Aug 14 09:40:01 eco3033 postfix/smtpd[25212]: disconnect from localhost.localdomain[127.0.0.1]
Aug 14 09:40:01 eco3033 postfix/qmgr[17236]: 87C568800AA: from=<smmsp@eco3033.netclusive.de>, size=1157, nrcpt=1 (queue active)
Aug 14 09:40:01 eco3033 amavis[20528]: (20528-05) Passed, <smmsp@eco3033.netclusive.de> -> <root@eco3033.netclusive.de>, Message-ID: <20050814074001.729D18800AB@eco3033.netclusive.de>, Hits: -
Aug 14 09:40:01 eco3033 postfix/smtp[25211]: 729D18800AB: to=<root@eco3033.netclusive.de>, orig_to=<root>, relay=127.0.0.1[127.0.0.1], delay=0, status=sent (250 2.6.0 Ok, id=20528-05, from MTA: 250 Ok: queued as 87C568800AA)
Aug 14 09:40:01 eco3033 postfix/qmgr[17236]: 729D18800AB: removed
Aug 14 09:40:01 eco3033 postfix/local[25213]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:01 eco3033 postfix/local[25213]: 87C568800AA: to=<root@eco3033.netclusive.de>, relay=local, delay=0, status=sent (delivered to mailbox)
Aug 14 09:40:01 eco3033 postfix/qmgr[17236]: 87C568800AA: removed
Aug 14 09:40:48 eco3033 postfix[25216]: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:48 eco3033 postfix/postfix-script: warning: dict_open_dlinfo: wildcard dynamic map entry no longer supported.
Aug 14 09:40:48 eco3033 postfix/postfix-script: fatal: usage: postfix start (or stop, reload, abort, flush, check, set-permissions, upgrade-configuration)
Dann im Confixx unter webmail steht Konnte keine Verbinzung zum POP3 Server aufbauen aber qpopper ist installiert und läuft
Kann jemand helfen?
OS Debian 3.1
Postfix 2
Confixx pro 3
Postfix selbst kompilliert, oder Paket von Debian?
Wenn kompilliert, wie sind die Befehle?
postconf -n
MFG Silvio
per apt-get resp er ist vorkondiguriert hab den server so bekommen
eco3033:~/confixx# postconf -n
append_dot_mydomain = no
biff = no
command_directory = /usr/sbin
content_filter = smtp-amavis:[127.0.0.1]:10024
inet_interfaces = all
mailbox_command =
mailbox_size_limit = 0
mydestination = eco3033.netclusive.de, localhost.netclusive.de, localhost
myhostname = eco3033.netclusive.de
mynetworks = 127.0.0.0/8
myorigin = /etc/mailname
recipient_delimiter = +
relayhost =
setgid_group = postdrop
smtpd_recipient_restrictions = permit_sasl_authenticated,permit_mynetworks,reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
You have new mail in /var/mail/root
eco3033:~/confixx#
