[Tue Jul 14 14:37:29 2009] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Tue Jul 14 14:37:29 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 32 bytes)
[Tue Jul 14 14:37:29 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Tue Jul 14 14:37:29 2009] [notice] Apache/2.2.3 (Debian) mod_jk/1.2.18 mod_python/3.2.10 Python/2.4.4 PHP/5.2.0-8+etch15 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl
/v5.8.8 configured -- resuming normal operations
[Tue Jul 14 14:54:07 2009] [error] [client 72.36.112.229] client sent HTTP/1.1 request without hostname (see RFC2616 section 14.23): /played.html
[Tue Jul 14 15:07:17 2009] [error] [client 93.214.187.245] File does not exist: /var/www/vhosts/default/htdocs/cmpro, referer: http://forums-de.ubi.com/eve/forums/a/tpc/f
/388104122/m/117100222
[Tue Jul 14 15:09:13 2009] [notice] caught SIGTERM, shutting down
[Tue Jul 14 15:12:14 2009] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Jul 14 15:12:14 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Tue Jul 14 15:12:14 2009] [notice] mod_python: Creating 8 session mutexes based on 150 max processes and 0 max threads.
[Tue Jul 14 15:12:14 2009] [notice] mod_python: using mutex_directory /tmp
[Tue Jul 14 15:12:15 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 32 bytes)
[Tue Jul 14 15:12:15 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Tue Jul 14 15:12:15 2009] [notice] Apache/2.2.3 (Debian) mod_jk/1.2.18 mod_python/3.2.10 Python/2.4.4 PHP/5.2.0-8+etch15 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl
[Tue Jul 14 15:12:18 2009] [notice] Graceful restart requested, doing restart
[Tue Jul 14 15:12:19 2009] [notice] mod_python: Creating 8 session mutexes based on 150 max processes and 0 max threads.
[Tue Jul 14 15:12:19 2009] [notice] mod_python: using mutex_directory /tmp
[Tue Jul 14 15:12:19 2009] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Tue Jul 14 15:12:19 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 32 bytes)
[Tue Jul 14 15:12:19 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Tue Jul 14 15:12:19 2009] [notice] Apache/2.2.3 (Debian) mod_jk/1.2.18 mod_python/3.2.10 Python/2.4.4 PHP/5.2.0-8+etch15 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl
[Tue Jul 14 15:14:12 2009] [notice] caught SIGTERM, shutting down
[Tue Jul 14 15:14:14 2009] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Jul 14 15:14:14 2009] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Tue Jul 14 15:14:14 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Tue Jul 14 15:14:14 2009] [notice] mod_python: Creating 8 session mutexes based on 150 max processes and 0 max threads.
[Tue Jul 14 15:14:14 2009] [notice] mod_python: using mutex_directory /tmp
[Tue Jul 14 15:14:14 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 32 bytes)
[Tue Jul 14 15:14:14 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Tue Jul 14 15:14:14 2009] [notice] Apache/2.2.3 (Debian) mod_jk/1.2.18 mod_python/3.2.10 Python/2.4.4 PHP/5.2.0-8+etch15 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl
[Tue Jul 14 15:14:21 2009] [notice] caught SIGTERM, shutting down
[Tue Jul 14 15:14:23 2009] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Jul 14 15:14:23 2009] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Tue Jul 14 15:14:23 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Tue Jul 14 15:14:23 2009] [notice] mod_python: Creating 8 session mutexes based on 150 max processes and 0 max threads.
[Tue Jul 14 15:14:23 2009] [notice] mod_python: using mutex_directory /tmp
[Tue Jul 14 15:14:23 2009] [notice] mod_bw : Memory Allocated 0 bytes (each conf takes 32 bytes)
[Tue Jul 14 15:14:23 2009] [notice] mod_bw : Version 0.8 - Initialized [0 Confs]
[Tue Jul 14 15:14:23 2009] [notice] Apache/2.2.3 (Debian) mod_jk/1.2.18 mod_python/3.2.10 Python/2.4.4 PHP/5.2.0-8+etch15 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl
