PLESK 8.4 / QMail / Courier Problem
JMaus
nach einem Festplatten Crash mussten wir das System Neuinstallieren
nach Neuinstallation mit Ubuntu 7.10 Server und dem autoinstaller von Plesk 8.4
läuft plesk wieder
nun zum Problem
der Login über Horde funktioniert weder mit User noch mit User@domain.tld
desweiteren ist der mail abruf über pop3/imap nicht möglich
hier mal ausschnitte aus den logs
psa-horde.log
May 17 17:59:24 HORDE [error] [imp] FAILED LOGIN 217.85.70.240 to localhost:143[imap/notls] as shizo@infected-reflex.de [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 00:52:02 HORDE [error] [imp] FAILED LOGIN 89.128.59.147 to localhost:143[imap/notls] as juan@redinred.net [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 11:15:49 HORDE [error] [imp] FAILED LOGIN 86.76.87.15 to localhost:143[imap/notls] as info@jucaro.fr [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 12:39:32 HORDE [error] [imp] FAILED LOGIN 89.128.59.147 to localhost:143[imap/notls] as juan@redinred.net [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 12:39:56 HORDE [error] [imp] FAILED LOGIN 89.128.59.147 to localhost:143[imap/notls] as juan@redinred.net [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 13:14:16 HORDE [error] [imp] FAILED LOGIN 89.128.59.147 to localhost:143[imap/notls] as juan@redinred.net [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
May 18 18:59:53 HORDE [error] [imp] FAILED LOGIN 217.85.75.11 to localhost:143[imap/notls] as shizo@infected-reflex.de [on line 258 of "/usr/share/psa-horde/imp/lib/Auth/imp.php"]
mail.warn
May 18 18:55:01 www2 qmail-queue-handlers[27753]: starter: submitter[27754] exited normally
May 18 18:55:01 www2 qmail-remote-handlers[27755]: Handlers Filter before-remote for qmail started ...
May 18 18:55:01 www2 qmail-remote-handlers[27755]: from=#@[]
May 18 18:55:01 www2 qmail-remote-handlers[27755]: to=postmaster@www2.1st-level-server.de
May 18 18:58:20 www2 imapd: LOGIN FAILED, ip=[84.44.231.240]
May 18 18:59:42 www2 imapd: LOGIN FAILED, ip=[127.0.0.1]
May 18 18:59:52 www2 last message repeated 2 times
May 18 19:00:00 www2 relaylock: /var/qmail/bin/relaylock: mail from 89.215.33.185:3751 (89-215-33-185.2073126800.ddns-lan.pl.$
May 18 19:00:03 www2 qmail-queue-handlers[4766]: Handlers Filter before-queue for qmail started ...
May 18 19:00:03 www2 qmail-queue-handlers[4766]: from=aakwibiwrts@bmiinc.com
May 18 19:00:03 www2 qmail-queue-handlers[4766]: to=info@interhispania.com
mail.err
wir haben auch schon die configurations files mit anderen plesk servern verglichen, die sind korrekt...
hoffentlich hat jemand ein tip für uns oder kennt eine lösung zum problem
haben nun 3 tage mit google versucht eine lösung zu finden, leider nichts gefunden was funktioniert.
gruß
Johannes
Moin,
ich kann trotz Registierung nicht auf den Artikel zugreifen. Access denied!?
Es wäre lieb, wenn jemand den Inhalt hier kurz posten könnte.
Danke, Dromaius
Moin,
nach Stunden der Verzweiflung hat mir schließlich:
apt-get install -reinstall psa-imp
geholfen. Ein einfaches dpkg-reconfigure ... hat nicht geholfen. Bei Debian/Ubuntu ... gibt die beiden xinit.d Dateien nicht mehr.
Gruß Dromaius
hab ein ähnliches Problem
Bei uns ist Ubuntu 6.06 und Plesk 8.4.0 drauf.
Bei uns gibt es die Dateien noch.
Jedoch funktioniert das mit dem smtp-auth bei qmail nicht mehr. Obwohl es aktiviert ist.
@huschi Hab auch nach deiner Anleitung Plesk/Qmail: Nach Update auf Plesk 8.4 funktioniert SMTP-Auth nicht mehr - huschi.net
mal alles kontrolliert, /etc/inetd.conf gibt es bei uns jedoch nicht dafür /etc/xinetd.conf
In der /etc/xinetd.d/smpt_psa steht folgendes drin:
service smtp
env = SMTPAUTH=1 POPAUTH=1 POPLOCK_TIME=20
socket_type = stream
protocol = tcp
wait = no
disable = no
user = root
instances = UNLIMITED
server = /var/qmail/bin/tcp-env
server_args = -Rt0 /usr/sbin/rblsmtpd -r sbl.spamhaus.org /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
Vielleicht hat ja jemand noch eine idee sonst müssen wir aufs nächste Pleskupdate warten...
sicher das xinetd die Kontrolle hat? Schau mal in die inetd.conf ob die Zeilen noch auskommentiert sind. Auch wenn für PLESK immer wieder xinetd empfohlen wird, so installiert sich PLESK von Haus aus immer wieder mit inetd. Und Updates pfuschen da gelegentlich auch gerne mal rein.
.../etc/inetd.conf gibt es bei uns jedoch nicht...
kann es sein das die beim letzten Pleskupdate gelöscht wurde?
Ebenso haben wir das Problem das die Skripte in den cron Ordnern (cron.daily, cron.weekly usw.) nicht ausgeführt werden (z.b./etc/cron.weekly/50plesk-weekly). Ich habe sie nun direkt in die crontab geschrieben u.a. berechnet plesk so auch den Traffic. So gehts nun zwar erstmal aber das ist ja nicht der richtige Weg.
Reitet nicht so viel auf der inetd.conf rum. Es gibt verschiedene Szenarien, warum sie noch existiert oder nie existiert hat, or what ever.
Das einzig wichtige ist, daß qmail-smtpd "SMTPAUTH" in den Umgebungsvariablen finden muß. Blöde Sache, ist aber so.
@marcoweb
Bzgl. Deinen cron.daily, etc.: Check ob Du anacron drauf hast, welches sich eigentlich darum kümmern sollte.
