Plesk 8.2.0 installations fehler
Status
Not open for further replies.
Igdirli 76
Hallo Leute ,
Ich wollte heute Plesk 8.2.0 auf mein Linux OpenSuSE 10.2 server installieren aber nach dem runter laden der fehlenden paketen bekam ich ein fehler:
Installation der Pakete wird gestartet
Paket wird installiert psa-logrotate-3.7-suse10.2.build82070706.15.i586
Paket wird installiert quota-3.14-14.i586
Paket wird installiert awstats-6.6-1.swsoft.noarch
Paket wird installiert psa-locale-base-en-US-8.2.0-suse10.2.build82070706.15.noarch
Paket wird installiert psa-qmail-1.03-suse10.2.build82070706.15.i586
 Checking for the system groups and users necessary for Qmail...
 Checking for the group 'qmail'...
 Trying to add group 'qmail'... done
 Checking for the group 'nofiles'...
 Trying to add group 'nofiles'... done
 Checking for the user 'alias'...
 Trying to add user 'alias'... done
 Checking for the user 'qmaild'...
 Trying to add user 'qmaild'... done
 Checking for the user 'qmaill'...
 Trying to add user 'qmaill'... done
 Checking for the user 'qmailp'...
 Trying to add user 'qmailp'... done
 Checking for the user 'qmailq'...
 Trying to add user 'qmailq'... done
 Checking for the user 'qmailr'...
 Trying to add user 'qmailr'... done
 Checking for the user 'qmails'...
 Trying to add user 'qmails'... done
 Checking for the group 'popuser'...
 Trying to add group 'popuser'... done
 Checking for the user 'popuser'...
ERROR: It seems there is a user with UID=110
       in this system, but Plesk needs the same UID
       for its operation.
       Unfortunately, this situation has not yet been
       resolved.
       Please, visit http://www.swsoft.com/support for assistance.
Exiting...
error: %pre(psa-qmail-1.03-suse10.2.build82070706.15.i586) scriptlet failed, exit status 1
error:   install: %pre scriptlet failed (2), skipping psa-qmail-1.03-suse10.2.build82070706.15
ERROR: An error occurred during installation of packages.
Achtung! Ihre Software ist vielleicht nicht betriebsbereit.
Bitte kontaktieren Sie den technischen Produktsupport.
hmm...
permalink
Bei mir hat es natürlich nicht funktioniert. Alle Packages, außer dem BasePackage und den AdditionalPleskManuals wurden installiert. Zu den obigen Zwei bekomme ich folgende autoinstaller Emails:
Zitat:
HTML:
Try to find rcfile...
Autoinstaller rcfile not found.
Check hostname is sucessfull.
Opsys detected as: os_name=Linux os_vendor=SuSE version=10.0 arch=i686 environment=
Final opsys (with overriding) is: os_name=Linux os_vendor=SuSE version=10.0 arch=i686 environment=
Downloading the file products.inf3: 100% done.
Downloading the file plesk.inf3: 55%..100% done.
Downloading the file sitebuilder.inf3: 100% done.
repository: Get brief packages info for all sources
Checking for installed packages... readSystemPackagesBrief: execute rpm -qa --queryformat
'F:system_installed_brief_%{NAME}-%{VERSION}-%{RELEASE}.rpm\nN:%{NAME}\nE:%{EPOCH}\nV:%{VERSION }\nL:%{RELEASE}\nA:%{ARCH}\nf:%{INSTALLTIME}\nB:%{ BUILDTIME}\nX:\n'
done
release PLESK_8_1_1 is actual
release PLESK_8_2_0 is actual
Release SB_3_0_0 contains no any build for this OS
Release SB_3_0_1 contains no any build for this OS
release SB_3_0_2 is actual
release SB_4_0_0 is actual
Select best build of PLESK_8_2_0 for current OS
First fit build is current best: PSA_8.2.0/plesk-8.2.0-suse10.0-i386.inf3
Select best build: finally choised PSA_8.2.0/plesk-8.2.0-suse10.0-i386.inf3
Downloading the file PSA_8.2.0/plesk-8.2.0-suse10.0-i386.inf3: 100% done.
Detecting installed product components.
Component base: mode upgrade, installed=1174565309, available=1183715928
No keyupdate need for component base
Component psa-autoinstaller: mode up2date, installed=1183642212, available=1183642212
Component asp: mode up2date, installed=1183716139, available=1183716139
Component mailman: mode up2date, installed=1183716142, available=1183716142
Component postgresql: mode up2date, installed=1177950711, available=1177950711
Component java: mode up2date, installed=1183715781, available=1183715781
Component spamassassin: mode up2date, installed=1183715790, available=1183715790
Component rblsmtpd: mode up2date, installed=1183715785, available=1183715785
Component mod_python: mode up2date, installed=1126573753, available=1126573753
Component ruby: mode up2date, installed=1183716156, available=1183716156
Component fcgi: mode up2date, installed=1160390658, available=1160390658
Component vault: mode up2date, installed=1183708774, available=1183708774
Component horde-comps: mode up2date, installed=1183716070, available=1183716070
Component docs: mode upgrade, installed=1174565424, available=1183716044
Component backup-ded: mode up2date, installed=1183716152, available=1183716152
Component drweb: mode up2date, installed=1183715712, available=1183715712
Component kav: mode up2date, installed=1183990895, available=1183990895
Component ppwse: mode install, installed=0, available=1183716102
Component api: mode up2date, installed=1183715764, available=1183715764
Component sshterm: mode up2date, installed=1183715615, available=1183715615
Component pmm: mode up2date, installed=1183716128, available=1183716128
Component psa-firewall: mode up2date, installed=1183715778, available=1183715778
Component cs-gs: mode up2date, installed=1183715772, available=1183715772
Component psa-vpn: mode up2date, installed=1183716034, available=1183716034
Component battlefield: mode install, installed=0, available=1183716077
Component bf2: mode install, installed=0, available=1183716147
Component psa-fileserver: mode up2date, installed=1183715757, available=1183715757
Component watchdog: mode up2date, installed=1183716122, available=1183716122
Component sitebuilder: mode install, installed=0, available=1182878137
Component sitebuilder have no older version, so keyupdate not needed
Component sb-publish: mode install, installed=0, available=1160553167
Component cf-support: mode install, installed=0, available=1183716150
Component atis: mode install, installed=0, available=1167889486
Component miva: mode install, installed=0, available=1183716163
Component sso: mode install, installed=0, available=1183716185
Component de-DE-locale: mode up2date, installed=1183701798, available=1183701798
Component ja-JP-locale: mode install, installed=0, available=1183701814
Component es-ES-locale: mode install, installed=0, available=1183701805
Component ru-RU-locale: mode install, installed=0, available=1183701827
Component fr-FR-locale: mode install, installed=0, available=1183701809
Component it-IT-locale: mode install, installed=0, available=1183701812
Component zh-CN-locale: mode install, installed=0, available=1183701833
Component zh-TW-locale: mode install, installed=0, available=1183701835
The component psa-autoinstaller is already installed.
Not all packages were installed.
Please, resolve the above problem and try installing the packages again.
You did not specify the components to install.
kurz danach kam diese Email:
Downloading the file plesk.inf3: 100% done.
done
Check for components requires keyupdate
Exchanging information with licensing server.
KeyUpdateChecker::doCheck: no components for check key update
repository: Get full packages info for all sources
Retrieving information about the installed packages... execute command for generate rpm cache in /tmp:
'F:system_installed_%{NAME}-%{VERSION}-%{RELEASE}.%{ARCH}.rpm\nN:%{NAME}\nE:%{EPOCH}\nV:% {VERSION}\nL:%{RELEASE}\nA:%{ARCH}\nf:%{INSTALLTIM E}\nB:%{BUILDTIME}\n[R:%{REQUIRENAME}
%{REQUIREFLAGS:depflags} %{REQUIREVERSION}\n][P:%{PROVIDENAME} %{PROVIDEFLAGS:depflags}
%{PROVIDEVERSION}\n][P:%{FILENAMES}\nm:%{FILEMODES}\n5:%{FILEMD5S}%{FIL ELINKTOS}\n][C:%{CONFLICTNAME}
%{CONFLICTFLAGS:depflags} %{CONFLICTVERSION}\n][O:%{OBSOLETENAME} %{OBSOLETEFLAGS:depflags} %{OBSOLETEVERSION}\n]X:\n'
> /tmp/autoinstaller_system_packages.cache
read cache file
done
Downloading the file PSA_8.2.0/dist-rpm-SuSE-10.0-i386/build-8.2.0-suse10.0-i386.hdr.gz: 55%..100% done.
Downloading the file PSA_8.2.0/thirdparty-rpm-SuSE-10.0-i386/thirdparty-8.2.0-suse10.0-i386.hdr.gz: 100% done.
Downloading the file PSA_8.2.0/update-rpm-SuSE-10.0-i386/update-8.2.0-suse10.0-i386.hdr.gz: 27%..53%..81%..100% done.
Determining the packages that need to be installed.
Getting packages to installation list:
Get packages to installation from selected component base
Get packages to installation from selected component docs
Warning: unresolved requires 'psa-locale-base = 8.1.1' from psa-8.1.1-suse10.0.build81070322.16.i586
Check package set before installation
repository: download selected packages
Starting installation of packages
The packages were installed successfully.
auch wenn hier nun steht ...successfully, geändert hat sich rein gar nichts. Hat jmd eine Idee?
grüße
AUSSERDEM:
Hab ich gerade festgestellt, dass ich unter KUNDEN und DOMAINS einen Datenbankerror bekomme. Die Auswahl scheinnt noch fehlerfrei zu funktionieren aber sobald ich auf einen Kunden oder eine Domain klicke passiert folgendes:
Zitat:
ERROR: PleskMainDBException
Zu Favoriten hinzufügenZu Favoriten hinzufügen
Eine Ebene höherEine Ebene höher
MySQL query failed: Unknown column 'uid' in 'field list'
0: /usr/local/psa/admin/plib/common_func.php3:216
db_query(string 'select `id`,`cr_date`,`cname`,`pname`,`login`,`account_id `,`status`,`phone`,`fax`,`email`,`address`,`city`, `state`,`pcode`,`country`,`locale`,`limits_id`,`pa rams_id`,`perm_id`,`pool_id`,`logo_id`,`tmpl_id`,` sapp_pool_id`,`uid`,`ownership` from clients where `id`=2')
1: /usr/local/psa/admin/plib/class.Table.php:180
Table->select()
2: /usr/local/psa/admin/plib/class.cObject.php:443
cObject->fetchAttrsFromTable_()
3: /usr/local/psa/admin/plib/class.Client.php3:74
Client->Client(string '2')
4: /usr/local/psa/admin/plib/common_func.php3:2867
objectMaker(string 'Client', string '2')
5: /usr/local/psa/admin/plib/class.DomainControlForm.php:268
DomainControlForm->assign(object of type BsDomain)
6: /usr/local/psa/admin/htdocs/domains/dom_ctrl.php3:152
Geändert von dabauer82 (Heute um 12:50 Uhr).
Es gibt bereits einen Thread für Plesk 8.2.x. Closed.
Status
