mal wieder ein Plesk Problem...
Kann mir jmd. weiterhelfen.
Mein System:
Hetzner DS3000, Suse 10.0, Plesk 8.0
Gruß Simon
This letter was generated by security scanner started on host XXXXX at Jan 5, 2007 01:21 PM.
Please inspect this machine because there can be security problems or holes in its protection, or the machine can be infected.
Note: It is recommended that you re-run security scanning on the machine via Plesk control panel before you make any changes to the machine configuration.
Security scanning generated the following warnings (the full scanning log is available at /var/log/rkhunter.log):
[13:20:32] Warning: This operating system is not fully supported!
[13:21:06] WARNING, found: /dev/.udevdb (directory) /etc/.java (directory) [13:21:07] Warning: SSH version 1 possible allowed!
Mein System:
Gruß Simon
