Plesk 10, Postfix - Autoresponder Probleme
firemaster1985
Hallo Zusammen
Seit dem Update auf Plesk 10 funktioniert die Autoresponder funktion nicht mehr.
Sobald ich einen Autoresponder für einen Mailaccount aktiviere, bleiben die Mails in der Mail Queue hängen mit dem Vermerk Internal mail system problems.
Hat jemand eine Idee an was dies liegt?
Danke schonmal im Voraus
Hier noch meine Postfix config:
biff = no
canonical_maps = hash:/etc/postfix/canonical
command_directory = /usr/sbin
data_directory = /var/lib/postfix
debug_peer_level = 2
defer_transports =
delay_warning_time = 1h
disable_dns_lookups = no
disable_mime_output_conversion = no
disable_vrfy_command = yes
html_directory = /usr/share/doc/packages/postfix-doc/html
inet_interfaces = all
inet_protocols = all
mail_owner = postfix
mailbox_command =
mailbox_size_limit = 51200000
mailbox_transport =
mailq_path = /usr/bin/mailq
masquerade_domains =
masquerade_exceptions = root
message_size_limit = 10240000
message_strip_characters = \0
mydestination = localhost.$mydomain, localhost, localhost.localdomain
myhostname = sr3.XXXXX.ch
mynetworks = 127.0.0.0/8, 80.74.130.XXX/32
mynetworks_style = subnet
readme_directory = /usr/share/doc/packages/postfix-doc/README_FILES
relayhost =
relocated_maps = hash:/etc/postfix/relocated
sample_directory = /usr/share/doc/packages/postfix-doc/samples
sender_canonical_maps = hash:/etc/postfix/sender_canonical
setgid_group = maildrop
smtp_sasl_auth_enable = no
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_authorized_xforward_hosts = 127.0.0.0/8
smtpd_client_restrictions =
smtpd_helo_required = no
smtpd_helo_restrictions =
smtpd_proxy_timeout = 3600s
smtpd_recipient_restrictions = permit_mynetworks, check_client_access pcre:/var/spool/postfix/plesk/no_relay.re, permit_sasl_authenticated, reject_unauth_destination, check_policy_service inet:127.0.0.1:60000
smtpd_sasl_auth_enable = yes
smtpd_sender_restrictions = hash:/etc/postfix/access, check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated, check_client_access pcre:/var/spool/postfix/plesk/non_auth.re
smtpd_timeout = 3600s
smtpd_use_tls = yes
strict_8bitmime = no
strict_rfc821_envelopes = no
transport_maps = hash:/etc/postfix/transport, hash:/var/spool/postfix/plesk/transport
virtual_alias_domains = hash:/etc/postfix/virtual, hash:/var/spool/postfix/plesk/virtual
virtual_alias_maps = hash:/etc/postfix/virtual, hash:/var/spool/postfix/plesk/virtual
virtual_gid_maps = static:30
virtual_mailbox_maps = hash:/var/spool/postfix/plesk/vmailbox
virtual_uid_maps = static:110
