Hallo
in der www.conf von php-fpm steht:
ist chroot nicht das gleiche wie open_basedir? mit openbase_dir sperre ich doch auch ein?
Und warum chdir?
Kann mir dazu jemand etwas sagen?
; Chroot to this directory at the start. This value must be defined as an
; absolute path. When this value is not set, chroot is not used.
; Note: you can prefix with '$prefix' to chroot to the pool prefix or one
; of its subdirectories. If the pool prefix is not set, the global prefix
; will be used instead.
; Note: [COLOR="Red"]chrooting is a great security feature and should be used whenever
; possible. [/COLOR]However, all PHP paths will be relative to the chroot
; (error_log, sessions.save_path, ...).
; Default Value: not set
;chroot =
; Chdir to this directory at the start.
; Note: relative path can be used.
; Default Value: current directory or / when chroot
;chdir = /var/www
Und warum chdir?
