server {
listen 144.xx.xxx.xxx:80;
server_name lamer.net;
return 301 http://www.lamer.net$request_uri;
server {
server_name www.lamer.net;
root /var/www/lamer;
index index.php index.html index.htm;
access_log /var/log/nginx/lamer.net.access.log;
error_log /var/log/nginx/lamer.net.error.log;
# Make site accessible from http://localhost/
#server_name localhost;
if ($allowed_country = no) {
return 444;
location ~/admin\.php$ {
auth_basic "Administrator Login";
auth_basic_user_file /xxx/xxx/htpasswd;
try_files $uri =404;
fastcgi_pass unix:/var/run/php5-fpm.sock;
fastcgi_index index.php;
fastcgi_read_timeout 300;
fastcgi_param HTTP_SCHEME https;
include fastcgi_params;
location / {
try_files $uri $uri/ /index.php?$uri&$args;
# Media: images, icons, video, audio, HTC
location ~* \.(?:jpg|jpeg|gif|png|ico|gz|svg|svgz|mp4|ogg|ogv|webm|htc)$ {
expires 1M;
access_log off;
add_header Cache-Control "public";
# CSS and Javascript
location ~* \.(?:css|js)$ {
expires 1y;
access_log off;
location ~ /(internal_data|library) {
internal;
location ~ \.php$ {
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_send_timeout 180;
fastcgi_connect_timeout 60;
fastcgi_ignore_client_abort off;
fastcgi_intercept_errors on;
server {
server {
listen 144.xx.xxx.xxx:80; default_server;
return 444;
location / {
expires 1M;
access_log off;
expires 1y;
access_log off;
internal;
location ~ \.php$ {
server {
server_name 144.xx.xxx.xxx;
server {
server_name lamer.net 144.xx.xxx.xxx;
Du kannst für einen vHost in NGINX (mehr oder weniger) beliebig viele IPs / Domains setzen. Also solange diese auch auf den Server zeigen natürlich =)Aha, das bedeutet also immer bei dem VHost kann man die IP Adresse dahinter schreiben, wo man möchte dass bei Aufruf der IP ( nicht Domain) die entsprechende Domain geladen wird.
