MPlayer und mencoder Problem beim Instalieren
ReneE2306
wenn ich den Mplayer und mencoder Installieren will kommt folgende Meldung
apt-get install mplayer mencoder w32codecs
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mencoder: Depends: libasound2 (> 1.0.18) but 1.0.16-2 is to be installed
Depends: libdirac-decoder0 but it is not installable
Depends: libdirac-encoder0 but it is not installable
Depends: libfaad2 but it is not installable
Depends: libfontconfig1 (>= 2.8.0) but 2.6.0-3 is to be installed
Depends: libfribidi0 (>= 0.19.2) but it is not going to be installed
Depends: libjpeg62 (>= 6b1) but 6b-14 is to be installed
Depends: libmng1 (>= 1.0.10) but it is not going to be installed
Depends: libncurses5 (>= 5.7+20100313) but 5.7+20081213-1 is to be installed
Depends: libopencore-amrnb0 but it is not installable
Depends: libopencore-amrwb0 but it is not installable
Depends: liborc-0.4-0 (>= 1:0.4.6) but it is not installable
Depends: librtmp0 (>= 2.3) but it is not installable
Depends: libvpx0 (>= 0.9.0) but it is not installable
mplayer: Depends: libasound2 (> 1.0.18) but 1.0.16-2 is to be installed
Depends: libatk1.0-0 (>= 1.29.3) but 1.22.0-1 is to be installed
Depends: libcaca0 (>= 0.99.beta17-1) but it is not going to be installed
Depends: libdirectfb-1.2-9 but it is not installable
Depends: libjack-jackd2-0 (>= 1.9.5~dfsg-14) but it is not installable or
libjack-0.116 but it is not installable
Depends: libpulse0 (>= 0.9.21) but it is not going to be installed
kann mir jemand helfen dies zu Installieren
bis jetzt konnten ja einige von euch mir sehr behilflich sein danke noch einmal dafür
gute frage ich hab den schon vorinstaliert übernommen wenn du mir jetzt sagst wo ich das einsehen kann dann sage ich es dir
am aller besten jemand könnte mir alles von anfang an erklären wie ich den mplayer drauf bekomme
danke
lg
Wenn es ein debian-Server ist, dann
cat /etc/apt/sources.list
Ubuntu hab ich nicht aus der Kalten parat, aber sicher ähnlich.
das steht bei mir drin
# deb http://ftp.nl.debian.org/debian lenny main
deb http://ftp.nl.debian.org/debian lenny main non-free contrib
deb-src http://ftp.nl.debian.org/debian lenny main non-free contrib
deb http://autoinstall.plesk.com/debian/PSA_9.5.2 lenny all
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/ lenny/updates main contrib non-free
deb http://volatile.debian.org/debian-volatile lenny/volatile main contrib non-free
deb-src http://volatile.debian.org/debian-volatile lenny/volatile main contrib non-free
deb http://www.debian-multimedia.org lenny main
deb http://www.debian-multimedia.org stable main
deb http://www.debian-multimedia.org squeeze main non-free
deb http://www.debian-multimedia.org sarge main
deb http://www.debian-multimedia.org etch main
lg
Das ist natürlich gehöriger Blödsinn. Du fährst Lenny, da haben die Repos für andere Releases nix zu suchen. Nimm das raus, dann machst du ein
apt-get update
und es sollte gehen. Und dann überlegst du dir die Tage mal, wie du dein System von Lenny auf Squeeze hoch bekommst, bevor der Support für Oldstable ausläuft.
Also soweit so gut danke dir also mplayer ist instaliert und scheint auch zu funktionieren aber wenn ich
apt-get install mEncoder
eingebe kommt vollgende meldung wie bekomm ich das nch instaliert ?
wie ich sehe fehlen da die packete update hab ich aber schon gemacht wie bekomm ich bzw woher und wie lade ich es rein ?
Package mencoder is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package mencoder has no installation candidate
danke
lg
