<Directory "/var/www/vhosts/boards-united.com/httpdocs/">
AllowOverride All
Options FollowSymLinks
Order allow,deny
Allow from all
</Directory>
AllowOverride All
Order allow,deny
Allow from all
</Directory>
RewriteLog "/var/www/mod_rewrite.log"
RewriteLogLevel 4
AllowOverride All
Order allow,deny
Allow from all
RewriteLogLevel 4
</Directory>
Weißt Du zufällig , wie das ausschauen muß ?Theoretisch kannst du auch das da rein schreiben. Würde ich persönlich der Übersicht halber aber in der .htaccess machen.
Syntax error on line 6 of /var/www/vhosts/boards-united.com/conf/vhost.conf:
RewriteLog not allowed here
### 'Main' server configuration #############################################
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
Include /etc/apache2/default-server.conf
Funktioniert es oder nicht?So , und nun habe ich auch ne Ausgabe. Wobei eine htaccess gar nicht funktionierte.
