tellerrocker
Hallo liebe Community,
Ich habe folgendes Problem und komm nicht weiter. Und zwar zeigt Confixx mir keinen Fehler an im Postfach, aber es gehen keine E-Mails raus und keine kommen rein...
Config:
mail.log:
mail.err:
Config:
append_dot_mydomain = no
biff = no
home_mailbox = Maildir/
inet_interfaces = all
mailbox_command = procmail
mailbox_size_limit = 0
mydestination = myorigin, server01.clubarea.fm, localhost.clubarea.fm, , localhost
myhostname = clubarea.fm
mynetworks = 84.200.18.12
myorigin = /etc/mailname
readme_directory = no
recipient_delimiter = +
relayhost =
smtpd_helo_required = yes
smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, reject_unknown_sender_domain, check_policy_service inet:127.0.0.1:12525, permit_sasl_authenticated, check_policy_service inet:127.0.0.1:10023
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $myorigin
smtpd_sender_restrictions = permit_mynetworks, permit_tls_clientcerts, reject_unknown_sender_domain, reject_non_fqdn_sender, reject_unauth_pipelining, permit_sasl_authenticated
smtpd_tls_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls = yes
mail.log:
Mar 3 10:53:13 server01 postfix/smtpd[8346]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
Mar 3 10:53:14 server01 postfix/master[15887]: warning: process /usr/lib/postfix/smtpd pid 8346 exit status 1
Mar 3 10:53:14 server01 postfix/master[15887]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Mar 3 10:53:41 server01 postfix/qmgr[7435]: 7408A3180009: from=<info@clubarea.fm>, size=641, nrcpt=1 (queue active)
Mar 3 10:53:41 server01 postfix/qmgr[7435]: E0AEA3180004: from=<www-data@server01.clubarea.fm>, size=804, nrcpt=1 (queue active)
Mar 3 10:53:41 server01 postfix/smtp[8348]: 7408A3180009: host mx00.gmx.net[213.165.67.114] refused to talk to me: 554-gmx.net (mxgmx011) Nemesis ESMTP Service not av$
Mar 3 10:53:41 server01 postfix/smtp[8349]: E0AEA3180004: host mx00.gmx.net[213.165.67.114] refused to talk to me: 554-gmx.net (mxgmx005) Nemesis ESMTP Service not av$
Mar 3 10:53:41 server01 postfix/smtp[8348]: 7408A3180009: host mx01.gmx.net[213.165.67.97] refused to talk to me: 554-gmx.net (mxgmx104) Nemesis ESMTP Service not ava$
Mar 3 10:53:41 server01 postfix/smtp[8349]: E0AEA3180004: host mx01.gmx.net[213.165.67.97] refused to talk to me: 554-gmx.net (mxgmx102) Nemesis ESMTP Service not ava$
Mar 3 10:53:42 server01 postfix/smtp[8349]: E0AEA3180004: to=<Petrich.T@gmx.de>, relay=mx0.gmx.net[213.165.67.114]:25, delay=407627, delays=407627/0.01/0.1/0, dsn=4.0$
Mar 3 10:53:42 server01 postfix/smtp[8348]: 7408A3180009: to=<j-o.sondermann@gmx.de>, relay=mx0.gmx.net[213.165.67.114]:25, delay=248238, delays=248237/0.01/0.11/0, d$
Mar 3 10:54:14 server01 postfix/smtpd[8363]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
Mar 3 10:54:15 server01 postfix/master[15887]: warning: process /usr/lib/postfix/smtpd pid 8363 exit status 1
Mar 3 10:54:15 server01 postfix/master[15887]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
mail.err:
Mar 3 10:50:02 server01 spamc[8328]: connect to spamd on 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Mar 3 10:50:03 server01 spamc[8328]: connect to spamd on 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Mar 3 10:50:04 server01 spamc[8328]: connect to spamd on 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Mar 3 10:50:05 server01 spamc[8328]: connection attempt to spamd aborted after 3 retries
Mar 3 10:50:10 server01 postfix/smtpd[8329]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
Mar 3 10:51:11 server01 postfix/smtpd[8336]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
Mar 3 10:52:12 server01 postfix/smtpd[8341]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
Mar 3 10:55:15 server01 postfix/smtpd[8370]: fatal: invalid "-o smtps" option value: missing '=' after attribute name
