Creating config file /etc/mailman3/mailman-web.py with new version
Traceback (most recent call last):
File "/usr/bin/django-admin", line 21, in <module>
management.execute_from_command_line()
File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 364, in execute_from_command_line
utility.execute()
File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 356, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 283 , in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 330 , in execute
output = self.handle(*args, **options)
File "/usr/lib/python3/dist-packages/django/core/management/commands/migrate.p y", line 83, in handle
executor = MigrationExecutor(connection, self.migration_progress_callback)
File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 2 0, in __init__
self.loader = MigrationLoader(self.connection)
File "/usr/lib/python3/dist-packages/django/db/migrations/loader.py", line 52, in __init__
self.build_graph()
File "/usr/lib/python3/dist-packages/django/db/migrations/loader.py", line 210 , in build_graph
self.applied_migrations = recorder.applied_migrations()
File "/usr/lib/python3/dist-packages/django/db/migrations/recorder.py", line 6 5, in applied_migrations
self.ensure_schema()
File "/usr/lib/python3/dist-packages/django/db/migrations/recorder.py", line 5 2, in ensure_schema
if self.Migration._meta.db_table in self.connection.introspection.table_name s(self.connection.cursor()):
File "/usr/lib/python3/dist-packages/django/db/backends/base/base.py", line 25 4, in cursor
return self._cursor()
File "/usr/lib/python3/dist-packages/django/db/backends/dummy/base.py", line 2 0, in complain
raise ImproperlyConfigured("settings.DATABASES is improperly configured. "
django.core.exceptions.ImproperlyConfigured: settings.DATABASES is improperly co nfigured. Please supply the ENGINE value. Check settings documentation for more details.
dpkg: error processing package mailman3-web (--configure):
installed mailman3-web package post-installation script subprocess returned err or exit status 1
Setting up odbcinst (2.3.6-0.1) ...
Setting up odbcinst1debian2:amd64 (2.3.6-0.1) ...
Setting up libgdal20 (2.4.0+dfsg-1+b1) ...
Setting up python3-gdal (2.4.0+dfsg-1+b1) ...
Processing triggers for fontconfig (2.13.1-2) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for systemd (241-7~deb10u4) ...
Processing triggers for man-db (2.8.5-2) ...
mailman3-web
