Login Problem mit VSFTPd
Flex
Ja, ich besitze einen kleinen VServer bei Strato und bin gerade dabei diesen aufzusetzen... Ich dachte mir, dass ich vsftpd nutze, also habe ich diesen installiert und konfiguriert...
Hier ist die vsftpd.conf:
# Example config file /etc/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Allow anonymous FTP? (Beware - allowed by default if you comment this out).
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
#local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
chown_uploads=YES
chown_username=flex
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format
#xferlog_std_format=YES
# You may change the default value for timing out an idle session.
idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that on some FTP servers, ASCII support allows a denial of service
# attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
# predicted this attack and has always been safe, reporting the size of the
# raw file.
# ASCII mangling is a horrible feature of the protocol.
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
ftpd_banner=Welcome to the Empire!
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
chroot_list_enable=NO
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
userlist_enable=YES
userlist_deny=YES
die userlist_deny ist momentan noch leer...
ftpgroup ist angelegt und der User wird so hinzugefügt bei mir:
useradd -d /home/username -g ftpgroup -s /bin/false username
passwd username
So, leider klappt danach der Login per FTP nicht:
Connecting to xxx.xxx.xxx.xxx Port 21 (#6)
Connected.  Waiting for response.
220 Welcome to the Empire!
USER flex
331 Please specify the password.
PASS xxxxxx
530 Login incorrect.
QUIT
Connection attempt failed.
Login per SSH klappt, ergo will vsftpd nicht das Passwort annehmen, aber ich weiß nicht warum...
Anonymous Login klappt, wenn ich es aktiviere...
vsFTPd läuft über den xinetd.
Habe diverse Seiten abgeklappert, aber leider nichts passendes gefunden...
Leider auch in den diversen Threads hier im Forum nichts gefunden, würde mich über eine schnelle Hilfe freuen, bin leider noch ein ziemlicher Neuling in Sachen Linux...
Grüße,
Flex
Ich vermisse die Konfiguration der Authentifizierzungs-Methode wie PAM oder SASL.
Z.B: "pam_service_name=vsftpd" inkl. passender /etc/pam.d/vsftpd.
Hmm, dazu war nichts in den Tutorials drin die ich gesehen habe... Aber naja, mittlerweile hat sich das Thema erledigt, weil ich auf den proFTPd umgestiegen bin, der auch ohne Probleme läuft...
