Directive Local Value Master Value
allow_call_time_pass_reference On On
allow_url_fopen On On
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 5 2039
expose_php On On
extension_dir /usr/lib/php/extensions /usr/lib/php/extensions
file_uploads On On
gpc_order GPC GPC
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .: .:
log_errors Off Off
log_errors_max_len 1024 1024
magic_quotes_gpc On On
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
max_execution_time 30 30
max_input_time 60 60
memory_limit 32M 32M
open_basedir /var/www/vhosts/boeing-787.go-around.de/httpdocs:/tmp no value
output_buffering no value no value
output_handler no value no value
post_max_size 8M 8M
precision 12 12
register_argc_argv On On
register_globals Off Off
report_memleaks On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
