Hallo, danke für deine Antwort.
Im Ordner /etc/init.d/rc3.d sind folgende Dateien bzw. Verlinkungen aufgelistet:
lrwxrwxrwx 1 root root 7 Jan 1 18:29 K12sshd -> ../sshd
lrwxrwxrwx 1 root root 9 Jan 1 18:29 K12xinetd -> ../xinetd
lrwxrwxrwx 1 root root 9 Jan 1 18:29 K15syslog -> ../syslog
lrwxrwxrwx 1 root root 10 Sep 26 16:43 K16network -> ../network
lrwxrwxrwx 1 root root 12 Sep 26 16:43 K19haldaemon -> ../haldaemon
lrwxrwxrwx 1 root root 7 Sep 26 16:43 K20dbus -> ../dbus
lrwxrwxrwx 1 root root 7 Sep 26 16:43 S01dbus -> ../dbus
lrwxrwxrwx 1 root root 12 Sep 26 16:43 S02haldaemon -> ../haldaemon
lrwxrwxrwx 1 root root 10 Sep 26 16:43 S05network -> ../network
lrwxrwxrwx 1 root root 9 Jan 1 18:29 S06syslog -> ../syslog
lrwxrwxrwx 1 root root 7 Jan 1 18:29 S09sshd -> ../sshd
SSH ist also dabei.
In der Datei /etc/ssh/sshd_config steht folgendes:
# $OpenBSD: sshd_config,v 1.72 2005/07/25 11:59:40 markus Exp $
# This is the sshd server system-wide configuration file. See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented. Uncommented options change a
# default value.
#Port 22
Protocol 2
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 768
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
PermitRootLogin no
#StrictModes yes
#MaxAuthTries 6
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile .ssh/authorized_keys
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#RhostsRSAAuthentication no
# similar for protocol version 2
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
PasswordAuthentication no
#PermitEmptyPasswords no
# Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Set this to 'yes' to enable support for the deprecated 'gssapi' authentication
# mechanism to OpenSSH 3.8p1. The newer 'gssapi-with-mic' mechanism is included
# in this release. The use of 'gssapi' is deprecated due to the presence of
# potential man-in-the-middle attacks, which 'gssapi-with-mic' is not susceptible to.
#GSSAPIEnableMITMAttack no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication mechanism.
# Depending on your PAM configuration, this may bypass the setting of
# PasswordAuthentication, PermitEmptyPasswords, and
# "PermitRootLogin without-password". If you just want the PAM account and
# session checks to run without PAM authentication, then enable this but set
# ChallengeResponseAuthentication=no
UsePAM no
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding no
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
# no default banner path
#Banner /some/path
# override default of no subsystems
Subsystem sftp /usr/lib/ssh/sftp-server
# This enables accepting locale enviroment variables LC_* LANG, see sshd_config(5).
AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES
AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT
AcceptEnv LC_IDENTIFICATION LC_ALL
Sollte also eigentlich auch richtig konfiguriert sein. Wenn ich den SSH Dämon manuell vom Rescue-System aus starte, lässt er sich starten. Aber er scheint beim booten von Festplatte nicht zu starten.
LG; Robin
