nukem
Hallo, ich habe follgendes Prob:
# apt-get -f -y install proftpd
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
proftpd: Depends: proftpd-common (= 1.2.10-15sarge1) but it is not going to be installed
Conflicts: ftp-server
Conflicts: proftpd-mysql but 1.2.10-15sarge1 is to be installed
proftpd-mysql: Depends: proftpd-common (= 1.2.10-15sarge1) but it is not going to be installed
Conflicts: proftpd but 1.2.10-15sarge1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Fehler beim Löschen des Pakets proftpd-common :
dpkg: dependency problems prevent removal of proftpd-common:
proftpd-mysql depends on proftpd-common (= 1.2.10-15sarge1).
dpkg: error processing proftpd-common (--remove):
dependency problems - not removing
proftpd-common
wie kann ich dieses lösen?
proftpd-common
