Habe ein Problem mit SSL wer kann helfen??
ich61
Ich habe in meiner error log folgende meldungen stehen
[Mon Oct 01 06:25:14 2007] [warn] Init: SSL server IP/port conflict: web0.XXXX.YYYYYY.de:443 (/etc/apache2/confixx_vhosts/web0.conf:37) vs. web8.XXXX.YYYYYY.de:443 (/etc/apache2/confixx_vhosts/web8.conf:59)
[Mon Oct 01 06:25:14 2007] [warn] Init: SSL server IP/port conflict: XXXX.YYYYYY.de:443 (/etc/apache2/confixx_mhost.conf:173) vs. web8.XXXX.YYYYYY.de:443 (/etc/apache2/confixx_vhosts/web8.conf:59)
[Mon Oct 01 06:25:14 2007] [warn] Init: SSL server IP/port conflict: 1.2.3.4.5:443 (/etc/apache2/confixx_mhost.conf:127) vs. web8.XXXX.YYYYYY.de:443 (/etc/apache2/confixx_vhosts/web8.conf:59)
[Mon Oct 01 06:25:14 2007] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Mon Oct 01 06:25:14 2007] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Mon Oct 01 06:25:14 2007] [notice] mod_python: Creating 8 session mutexes based on 300 max processes and 0 max threads.
[Mon Oct 01 06:25:14 2007] [notice] mod_python: using mutex_directory /tmp
[Mon Oct 01 06:25:15 2007] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon Oct 01 06:25:15 2007] [warn] RSA server certificate CommonName (CN) `confixx' does NOT match server name!?
Wer kann mir sagen was da los ist??Ich nutzte gar kein SSL außer bei webmin.Verstehe nicht was der als will???
