L
lapinga
Hello,
I have a little problem with senders using exchange servers or outlook.com
I know I have to add some lines to the greylisting whitelist, and so I did.
But something is wrong.
When I add *outlook.com to the whitelist through the GLM2 interface it does show up as added, but it doesn't seem to be added to the greylisting.
I go to shell and do this:
so, I add it manually with:
and then it shows up on that list.
HOWEVER:
when I log into my plesk panel and go to the GLM2 panel and click on anything in the blacklist, then it is deleted again from that list i see in shell
CentOs 6.4, plesk 11.5.30#16
GLM 2.3.2
steps to reproduce:
1) log into shell and manually add *outlook.com with above command
2) log into plesk, go to GLM, go to white/blacklist, left click on *outlook.com (you get a edit box to change the name) then just rightclick (edit box dissapears and page is reloaded)
3) go to shell again and check the list with above command, *outlook.com is GONE even tho it still shows in the GLM panel
also, i would like to take the chance and ask:
i think since i am on plesk 11.5 my greylisting is rejecting mails with a 5.7.1 error instead the temporal 4.x.x error it should... does anyone know anything about this?
as you see there is nothing there./usr/local/psa/bin/grey_listing -i
Grey listing configuration.
Grey listing checking enabled
Grey interval 5 minutes
Expire interval 51840 minutes
Penalty interval 2 minutes
Penalty disabled
Personal grey listing
configuration allowed
Server-wide black list:
Server-wide white list:
White domains patterns list:
Black domains patterns list:
SUCCESS: Gathering of server wide information complete.
/usr/local/psa/bin/grey_listing --update-server -domains-whitelist "add:*outlook.com"
HOWEVER:
GLM 2.3.2
steps to reproduce:
