stefan-becker
EDIT MOD: Ich erhalte:
Kommen die Packages nicht richtig an, oder wie kann man das verstehen?
Stefan
Parallels Products Installer 3.5.0 (build at 2009-08-17 16:44 svn rev. 0) started at (timezone CET) Sat Jan 23 23:26:00 2010 Command line args: /opt/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/root/psa --select-release-id=PLESK_9_3_0 [email protected] --install-component=base --install-component=api --install-component=backup-ded --install-component=pmm-ded --install-component=psa-firewall --install-component=psa-vpn --install-component=watchdog
Try to find rcfile...
Autoinstaller rcfile not found.
Opsys detected as: os_vendor=Debian os_name=Linux version=4.0 arch=i686 environment=~empty Final opsys (with overriding) is: os_vendor=Debian os_name=Linux version=4.0 arch=i686 environment=~empty Checking hostname is sucessfull.
Downloading the file products.inf3: 100% done.
Downloading the file plesk.inf3: 13%..23%..33%..41%..51%..61%..71%..81%..91%..100% done.
Downloading the file ppsmbe.inf3: 27%..58%..89%..100% done.
Downloading the file sitebuilder.inf3: 35%..75%..100% done.
Downloading the file sso.inf3: 24%..51%..78%..100% done.
Downloading the file setemplates.inf3: 87%..100% done.
repository: Get brief packages info for all sources Checking for installed packages...
DebRepository: readSystemPackagesBrief: execute dpkg-query --show '--showformat=s:${Status}\nF:${Package}_installed.deb\nN:${Package}\nV:${Version}\nA:${Architecture}\nX:\n'| awk '/^s:install ok/,/^X:/ { print $0}'| grep -v '^s:'
Downloading the file PSA_9.3.0/plesk-9.3.0-deb4.0-i386.inf3: 14%..25%..30%..40%..50%..63%..73%..81%..94%..100% done.
No removers section in this build.
No preferrers section in this build.
add line 'deb http://autoinstall.plesk.com/debian/PSA_9.3.0 etch all' to source.list Hit ftp://mir1.ovh.net etch Release.gpg
Get:1 ftp://mir1.ovh.net etch Release [67.8kB]
Get:2 http://security.debian.org etch/updates Release.gpg [835B] Hit http://security.debian.org etch/updates Release
Get:3 ftp://mir1.ovh.net etch/main Packages/DiffIndex Ign ftp://mir1.ovh.net etch/main Packages/DiffIndex
Get:4 ftp://mir1.ovh.net etch/main Sources/DiffIndex Ign ftp://mir1.ovh.net etch/main Sources/DiffIndex Hit ftp://mir1.ovh.net etch/main Packages Hit ftp://mir1.ovh.net etch/main Sources Ign http://security.debian.org etch/updates/main Packages/DiffIndex Ign http://security.debian.org etch/updates/main Sources/DiffIndex Hit http://security.debian.org etch/updates/main Packages Hit http://security.debian.org etch/updates/main Sources Ign http://autoinstall.plesk.com etch Release.gpg Ign http://autoinstall.plesk.com etch Release.gpg Ign http://autoinstall.plesk.com etch Release Ign http://autoinstall.plesk.com etch Release Ign http://autoinstall.plesk.com etch/all Packages/DiffIndex Ign http://autoinstall.plesk.com etch/all Packages/DiffIndex Hit http://autoinstall.plesk.com etch/all Packages Hit http://autoinstall.plesk.com etch/all Packages Fetched 67.8kB in 1s (49.6kB/s) Reading package lists...
Warning: not connected 'contrib' repository section
Warning: not connected 'non-free' repository section
repository: Get brief packages info for all sources Detecting installed product components.
Component plesk/base: mode upgrade, installed=0, available=0 Checking if key update required for component plesk/base Config allows upgrade from version 9.0 without key update Currently installed component version is 9.2.3-debian4.0.build92091009.18 No keyupdate need for this component Component plesk/psa-autoinstaller: mode up2date, installed=0, available=0 Component plesk/postgresql: mode install, installed=0, available=0 Component plesk/vault: mode upgrade, installed=0, available=0 Component plesk/ppwse: mode install, installed=0, available=0 Component plesk/api: mode upgrade, installed=0, available=0 Component plesk/pmm-ded: mode upgrade, installed=0, available=0 Component plesk/sb-publish: mode install, installed=0, available=0 Component plesk/sbm: mode install, installed=0, available=0 Component plesk/cf-support: mode install, installed=0, available=0 Component plesk/miva: mode install, installed=0, available=0 Component plesk/billing: mode install, installed=0, available=0 Component plesk/mod-bw: mode up2date, installed=0, available=0 Component plesk/asp: mode install, installed=0, available=0 Component plesk/java: mode install, installed=0, available=0 Component plesk/mod_python: mode install, installed=0, available=0 Component plesk/ruby: mode install, installed=0, available=0 Component plesk/php4: mode install, installed=0, available=0 Component plesk/php5: mode upgrade, installed=0, available=0 Component plesk/qmail: mode install, installed=0, available=0 Component plesk/postfix: mode upgrade, installed=0, available=0 Component plesk/psa-firewall: mode upgrade, installed=0, available=0 Component plesk/psa-vpn: mode upgrade, installed=0, available=0 Component plesk/psa-fileserver: mode install, installed=0, available=0 Component plesk/sshterm: mode install, installed=0, available=0 Component plesk/watchdog: mode upgrade, installed=0, available=0 Component plesk/cs-gs: mode install, installed=0, available=0 Component plesk/battlefield: mode install, installed=0, available=0 Component plesk/bf2: mode install, installed=0, available=0 Component plesk/mailman: mode upgrade, installed=0, available=0 Component plesk/kav: mode install, installed=0, available=0 Component plesk/drweb: mode install, installed=0, available=0 Component plesk/spamassassin: mode install, installed=0, available=0 Component plesk/backup-ded: mode upgrade, installed=0, available=0 Component plesk/atis: mode install, installed=0, available=0 Component plesk/de-DE-locale: mode upgrade, installed=0, available=0 Component plesk/ja-JP-locale: mode install, installed=0, available=0 Component plesk/es-ES-locale: mode install, installed=0, available=0 Component plesk/ru-RU-locale: mode install, installed=0, available=0 Component plesk/fr-FR-locale: mode install, installed=0, available=0 Component plesk/it-IT-locale: mode install, installed=0, available=0 Component plesk/zh-CN-locale: mode install, installed=0, available=0 Component plesk/zh-TW-locale: mode install, installed=0, available=0 Component plesk/nl-NL-locale: mode install, installed=0, available=0 Component plesk/horde: mode upgrade, installed=0, available=0 Component plesk/atmail: mode upgrade, installed=0, available=0
KeyUpdateChecker::doCheck: no components for check key update
skip package 'psa-mod-fcgid-configurator-1.0-14.i386' from component base - there is same or newer version of this package is installed (in system psa-mod-fcgid-configurator-1.0-14.i386)
skip package 'log4cpp-plesk-0.3.5rc2-v9.275143.i386' from component pmm-ded - there is same or newer version of this package is installed (in system log4cpp-plesk-0.3.5rc2-v9.275143.i386)
skip package 'psa-ftputil-1:2.1.1-0.98221.all' from component backup-ded - there is same or newer version of this package is installed (in system psa-ftputil-1:2.1.1-0.98221.all) Checking whether the package dependencies are resolved.
Check package set before installation
Installing packages
Building dependency tree...
The following packages will be upgraded:
libpam-plesk plesk-base plesk-skins psa psa-api psa-api-rpc
psa-awstats-configurator psa-backup-manager psa-firewall
psa-locale-base-en-us psa-mail-driver-common psa-mail-pc-driver
psa-migration-agents psa-migration-manager psa-proftpd psa-proftpd-inetd
psa-pylibplesk psa-updates psa-vpn psa-watchdog 20 upgraded, 0 newly installed, 0 to remove and 79 not upgraded.
Need to get 39.4MB of archives.
After unpacking 733kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
psa-pylibplesk plesk-base libpam-plesk psa-migration-manager
psa-backup-manager psa-api-rpc psa-mail-driver-common psa psa-api
psa-locale-base-en-us psa-proftpd psa-proftpd-inetd plesk-skins
psa-mail-pc-driver psa-watchdog psa-awstats-configurator psa-firewall
psa-migration-agents psa-updates psa-vpn Authentication warning overridden.
Get:1 http://autoinstall.plesk.com etch/all psa-pylibplesk 9.3.0-debian4.0.build93091230.07 [22.5kB]
Get:2 http://autoinstall.plesk.com etch/all plesk-base 9.3.0-debian4.0.build93091230.07 [62.8kB]
Get:3 http://autoinstall.plesk.com etch/all libpam-plesk 9.3.0-debian4.0.build93091230.07 [73.5kB]
Get:4 http://autoinstall.plesk.com etch/all psa-migration-manager 9.3.0-debian4.0.build93091230.07 [442kB]
Get:5 http://autoinstall.plesk.com etch/all psa-backup-manager 9.3.0-debian4.0.build93091230.07 [3271kB]
Get:6 http://autoinstall.plesk.com etch/all psa-api-rpc 9.3.0-debian4.0.build93091230.07 [1105kB]
Get:7 http://autoinstall.plesk.com etch/all psa-mail-driver-common 9.3.0-debian4.0.build93091230.07 [437kB]
Get:8 http://autoinstall.plesk.com etch/all psa 9.3.0-debian4.0.build93091230.07 [14.8MB]
Get:9 http://autoinstall.plesk.com etch/all psa-api 9.3.0-debian4.0.build93091230.07 [1802kB] Get:10 http://autoinstall.plesk.com etch/all psa-locale-base-en-us 9.3.0-2009121611 [2461kB]
Get:11 http://autoinstall.plesk.com etch/all psa-proftpd 1.3.1-debian4.0.build93091230.07 [1744kB]
Get:12 http://autoinstall.plesk.com etch/all psa-proftpd-inetd 1.3.1-debian4.0.build93091230.07 [27.2kB]
Get:13 http://autoinstall.plesk.com etch/all plesk-skins 9.3.0-0.287499 [8529kB]
Get:14 http://autoinstall.plesk.com etch/all psa-mail-pc-driver 1.0.0-debian4.0.build93091230.07 [1801kB]
Get:15 http://autoinstall.plesk.com etch/all psa-watchdog 2.0.3-debian4.0.build93091230.07 [1489kB]
Get:16 http://autoinstall.plesk.com etch/all psa-awstats-configurator 1.0.0-debian4.0.build93091230.07 [14.9kB]
Get:17 http://autoinstall.plesk.com etch/all psa-firewall 1.0.1-debian4.0.build93091230.07 [256kB] Err http://autoinstall.plesk.com etch/all psa-firewall 1.0.1-debian4.0.build93091230.07
Error reading from server - read (104 Connection reset by peer)
Get:18 http://autoinstall.plesk.com etch/all psa-migration-agents 9.3.0-debian4.0.build93091230.07 [30.5kB]
Get:19 http://autoinstall.plesk.com etch/all psa-updates 9.3.0-debian4.0.build93091230.07 [1502B] Get:20 http://autoinstall.plesk.com etch/all psa-vpn 1.0.1-debian4.0.build93091230.07 [1052kB] Failed to fetch http://autoinstall.plesk.com/PSA_9.3.0/dist-deb-Debian-4.0-i386/opt/modules/firewall/psa-firewall_1.0.1-debian4.0.build93091230.07_i386.deb Error reading from server - read (104 Connection reset by peer)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Fetched 39.2MB in 5s (7315kB/s)
Get:4 ftp://mir1.ovh.net etch/main Sources/DiffIndex Ign ftp://mir1.ovh.net etch/main Sources/DiffIndex Hit ftp://mir1.ovh.net etch/main Packages Hit ftp://mir1.ovh.net etch/main Sources Ign http://security.debian.org etch/updates/main Packages/DiffIndex Ign http://security.debian.org etch/updates/main Sources/DiffIndex Hit http://security.debian.org etch/updates/main Packages Hit http://security.debian.org etch/updates/main Sources Ign http://autoinstall.plesk.com etch Release.gpg Ign http://autoinstall.plesk.com etch Release Ign http://autoinstall.plesk.com etch/all Packages/DiffIndex Hit http://autoinstall.plesk.com etch/all Packages Fetched 67.8kB in 0s (99.7kB/s) Reading package lists...
ERROR: An error occurred on attempt to install packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
Parallels Products Installer.
Stefan
