Fehlermeldung:connect to 127.0.0.1[127.0.0.1]: Connection refused
axelko
ich habe einen ROOTDS bei Server4YOU mit Suse 9 und Postfix und SpamAssassin laufen. Jetzt habe ich den SA auf Version 3.1 geupdatet und erhalte in der mail.err folgende Einträge:
Apr 25 10:29:25 vs163243 spamc[10056]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:29:26 vs163243 spamc[10056]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:29:27 vs163243 spamc[10056]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:21 vs163243 spamc[11975]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:21 vs163243 spamc[11977]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:21 vs163243 spamc[11981]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:21 vs163243 spamc[11984]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:22 vs163243 spamc[11975]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:22 vs163243 spamc[11977]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:22 vs163243 spamc[11981]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:22 vs163243 spamc[11984]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:23 vs163243 spamc[11975]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:23 vs163243 spamc[11977]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:23 vs163243 spamc[11981]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:23 vs163243 spamc[11984]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:24 vs163243 spamc[11975]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:24 vs163243 spamc[11977]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:24 vs163243 spamc[12007]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:24 vs163243 spamc[12009]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:24 vs163243 spamc[11981]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:24 vs163243 spamc[12011]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:24 vs163243 spamc[11984]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:24 vs163243 spamc[12013]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Apr 25 10:32:25 vs163243 spamc[12007]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:25 vs163243 spamc[12009]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:25 vs163243 spamc[12011]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:25 vs163243 spamc[12013]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Apr 25 10:32:26 vs163243 spamc[12007]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:26 vs163243 spamc[12009]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:26 vs163243 spamc[12011]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:26 vs163243 spamc[12013]: connect(AF_INET) to spamd at 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Apr 25 10:32:27 vs163243 spamc[12007]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:27 vs163243 spamc[12009]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:27 vs163243 spamc[12011]: connection attempt to spamd aborted after 3 retries
Apr 25 10:32:27 vs163243 spamc[12013]: connection attempt to spamd aborted after 3 retries
Wenn ich im Webmin die einzelnen Nachrichten markiere und "Reque selected" oder "Flush mail Queue" betätige, werden die mails einsortiert. Wennn der Queue auf 0 ist stoppt er dann wieder mit der Fehlermeldung:
Spamd gestartet
so habe spamd gestartet aber die Meldung bleibt bestehen. Es werde keine mails einsortiert:
vs163243:/etc # cd init.d
vs163243:/etc/init.d # spamd start
[28107] info: rules: meta test DIGEST_MULTIPLE has undefined dependency 'RAZOR2_CHECK'
[28107] info: rules: meta test DIGEST_MULTIPLE has undefined dependency 'DCC_CHECK'
[28107] info: rules: meta test DIGEST_MULTIPLE has undefined dependency 'PYZOR_CHECK'
[28107] info: spamd: server started on port 783/tcp (running version 3.1.8)
[28107] info: spamd: server pid: 28107
[28107] info: spamd: server successfully spawned child process, pid 28113
[28107] info: spamd: server successfully spawned child process, pid 28114
[28107] info: prefork: child states: II
ps -ax zeigt folgendes:
vs163243:~ # ps -ax
Warning: bad ps syntax, perhaps a bogus '-'? See [URL="http://procps.sf.net/faq.html"]procps - Frequently Asked Questions (FAQ)[/URL]
  PID TTY      STAT   TIME COMMAND
    1 ?        Ss     0:00 init [3]
20113 ?        Ss     0:00 /sbin/syslogd -a /var/lib/named/dev/log -a /var/lib/n
20116 ?        Ss     0:00 /sbin/klogd -c 1 -x -x
20129 ?        Ss     0:00 /usr/sbin/saslauthd -a pam -n 1
20134 ?        Ss     0:00 /usr/bin/perl /usr/libexec/usermin/miniserv.pl /etc/u
20140 ?        Ss     0:01 /usr/bin/perl /usr/libexec/webmin/miniserv.pl /etc/we
20150 ?        Ss     0:03 /usr/sbin/clamd
20164 ?        S      0:00 /bin/sh /usr/bin/mysqld_safe --user=mysql --pid-file=
20198 ?        Sl     1:48 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/my
20207 ?        Ss     0:00 /usr/sbin/sshd -o PidFile=/var/run/sshd.init.pid
20213 ?        Ss     0:00 /usr/sbin/xinetd
20271 ?        Ss     0:01 /usr/lib/postfix/master
20329 ?        Ss     0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
20330 ?        S      0:04 /usr/bin/perl /usr/local/confixx/pipelog.pl
20342 ?        Ss     0:00 /usr/sbin/cron
20348 ?        Ss     0:00 /usr/bin/freshclam -d
15521 ?        S      0:00 qmgr -l -t fifo -u
15900 ?        S      0:00 tlsmgr -l -t unix -u
15901 ?        S      0:00 anvil -l -t unix -u
19677 ?        Ss     0:00 -bash
23655 ?        Sl     2:14 ./../jre/bin/java -server -Xms256m -Xmx512m -Dfile.en
23804 ?        S      0:00 /bin/sh /srv/www/web1/html/sc/VirtualOffice/bin/start
23820 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23821 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23822 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23823 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23824 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23825 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23829 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23831 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23832 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23835 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23988 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
23991 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
13837 ?        S      0:00 trivial-rewrite -n rewrite -t unix -u
13950 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
20157 ?        S      0:00 pickup -l -t fifo -u
20209 ?        S      0:00 /srv/www/web1/html/sc/VirtualOffice/bin/../mysql/bin/
27754 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
27859 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
27941 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
27956 ?        Ss     0:00 sshd: root@notty
27961 ?        Ss     0:00 /usr/lib/ssh/sftp-server
27971 ?        Ss     0:00 sshd: root@pts/0
27974 pts/0    Ss     0:00 -bash
28005 ?        Ss     0:00 sshd: root@pts/1
28008 pts/1    Ss+    0:00 -bash
28120 ?        S      0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
28169 ?        Ss     0:00 vsftpd
28171 ?        S      0:00 vsftpd
28219 ?        S      0:00 smtpd -n smtp -t inet -u -o content_filter smtp:[127.
28220 ?        S      0:00 proxymap -t unix -u
28224 ?        S      0:00 cleanup -z -t unix -u
28333 ?        S      0:00 smtp -t unix -u
28334 ?        S      0:00 bounce -z -n defer -t unix -u
28335 ?        S      0:00 flush -z -t unix -u
28338 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
28343 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
28344 ?        S      0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
28352 pts/0    R+     0:00 ps -ax
Ich sage nur "Linux-Grundlagen".
Wenn Du schon im richtigen Verzeichnis bist, dann mußt Du dennoch "./spamd" schreiben, damit die Shell weiß, das Du spamd aus diesem Verzeichnis starten willst und nicht /usr/sbin/spamd, den es im PATH findet.
Als nächstest prüfst Du ob SpamAssassin (spamd) wirklich auf 127.0.0.1 / Localhost lauscht. Kann auch sein, daß er auf einer festen IP oder gar einem Socket hängt. Dann mußt Du dem spamc das entsprechend mitteilen.
spamd starten
Hallo Huschi,
tja bin leider noch Linuxanfänger und am lernen. Aber danke für Die ausführliche Hilfe.
Wenn ich Spamd über "./spamd start" starten möchte kommt folgende Meldung:
vsxxxxx:/etc/init.d # ./spamd start
: bad interpreter: Datei oder Verzeichnis nicht gefunden
spamd in etc/init.d ist ein link auf /home/filter/spamd in dem folgendes steht:
#!/bin/sh
case $1 in
start)
/home/filter/bin/spamd -d -u filter
stop)
pkill spamd
restart)
pkill spamd
echo "usage: $0 {start|stop|restart}"
esac
Wenn ich im Webmin die einzelnen Nachrichten unter der Postfix Konfiguration markiere und "Reque selected" oder "Flush mail Queue" betätige, werden die mails einsortiert. Wennn der Queue auf 0 ist stoppt er dann wieder mit der Meldung Fehlermeldung:
Dann solltest Du uns mal etwas über Dein System erzählen, bzw. wer es eingerichtet hat. Denn /home/filter/ ist ein recht untypischer Ort für SpamAssassin.
Mein System
habe den Server bei SY4 gemietet. Ich habe allerdings (versucht ?) den Spam Assassin zu updaten über
cpan> install HTML::Parser
cpan> install MIME::Base64
cpan> install DB_File
cpan > install Net::DNS
cpan > install Net::SMTP
cpan > install Mail::SPF::Query
cpan > install IP::Country::Fast
cpan > install IO::Socket::SSL
cpan > install Time::HiRes
cpan > install Mail::DKIM
cpan > install Mail::DomainKeys
cpan > install LWP
cpan > install IO::Zlib
cpan > install Archive::Tar
cpan > install Mail::SpamAssassin
das war wahrscheinlich mein Fehler , oder ?
