## Path: Network/WWW/Apache2
## Description: Configuration for Apache 2
## Type: string
## Default: ""
## ServiceRestart: apache2
# Here you can name files, separated by spaces, that should be Include'd from
# httpd.conf.
# This allows you to add e.g. VirtualHost statements without touching
# /etc/httpd/httpd.conf itself, which makes upgrading easier.
APACHE_CONF_INCLUDE_FILES=""
## Type: string
## Default: ""
# Here you can name directories, separated by spaces, that should be Include'd
# from httpd.conf.
# All files contained in these directories will be recursively included by apache.
# If a pattern like *.conf is appended, apache will use it.
# Examples: "/etc/apache2/my_conf/"
# "/etc/apache2/virtual_hosts/*.conf"
# "local/*.conf /srv/www/virtual/"
APACHE_CONF_INCLUDE_DIRS=""
## Type: string
## Default: "access actions alias auth auth_dbm autoindex cgi dir env expires include log_config mime negotiation setenvif ssl suexec userdir php4"
# [It might look silly to not simply edit httpd.conf for the LoadModule statements.
# However, since the LoadModule statements might need an absolute path to the modules,
# switching between MPMs can be quite a hassle. It's easier to just give the names here.]
# * list of all modules shipped with the base distribution:
# access actions alias asis auth auth_anon auth_dbm auth_digest auth_ldap
# autoindex cache case_filter case_filter_in cern_meta cgi charset_lite
# dav dav_fs deflate dir disk_cache dumpio echo env expires ext_filter
# file_cache headers imap include info ldap log_config log_forensic logio
# mem_cache mime mime_magic negotiation proxy proxy_connect proxy_ftp
# proxy_http rewrite setenvif speling ssl status suexec unique_id userdir
# usertrack vhost_alias
# see http://httpd.apache.org/docs-2.0/mod/ !
# * It pays to use IfDefine statements... like
# <IfModule mod_xyz.c>
# </IfModule>
# * In the APACHE_MODULES variable, you can use mod_xyz or just xyz syntax.
# You may also name an absolute path if you like.
# * NOTE ON MOD_SSL: before you can enable this module, you need a server certificate.
# A test certificate can be created by entering
# 'cd /usr/share/doc/packages/apache2; ./certificate.sh' as root.
# Also, you need to set the ServerName inside the <VirtualHost _default_:443>
# block to the fully qualified domain name (see /etc/HOSTNAME).
# * if your server certificate is protected by a passphrase you should increase the
# APACHE_START_TIMEOUT (see above)
# * modules listed here will be ignored if they are not installed
# EXAMPLES:
# fairly minimal
# APACHE_MODULES="access alias auth dir log_config mime setenvif"
# apache's default installation
# APACHE_MODULES="access actions alias asis auth autoindex cgi dir imap include log_config mime negotiation setenvif status userdir"
# your settings
APACHE_MODULES="access actions alias auth auth_dbm autoindex cgi dir env expires include log_config mime negotiation setenvif ssl suexec mod_suphp php4"
## Type: string
## Default: ""
# Additional server flags:
# Put here any server flags ("Defines") that you want to hand over to
# httpd at start time, or other command line flags.
# Background: Any directives within an <IfDefine flag>...</IfDefine>
# section are only processed if the flag is defined.
# This allows to write configuration which is active only in a
# special cases, like during server maintenance, or for testing
# something temporarily.
# Notably, to enable SSL support, 'SSL' needs to be added here.
# To enable the server-status, 'STATUS' needs to be added here.
# It does not matter if you write flag1, -D flag1 or -Dflag1.
# Multiple flags can be given as "-D flag1 -D flag2" or simply "flag1 flag2".
# Specifying such flags here is equivalent to giving them on the commandline.
# (e.g. via rcapache2 start -DReverseProxy)
# Example:
# "SSL STATUS AWSTATS SVN_VIEWCVS no_subversion_today"
APACHE_SERVER_FLAGS=""
## Type: string
## Default: ""
# Which config file do you want to use?
# (if not set, /etc/apache2/httpd.conf is used.)
# It is unusual to need to use this setting.
APACHE_HTTPD_CONF=""
## Type: list(prefork,worker,leader,metuxmpm)
## Default: ""
# MPM (multi-processing module) to use.
# Needed to determine with which MPM apache will run, as well as
# against which header files modules will be built.
# If not set, the system will simply pick one of the installed MPMs.
# The implementation of the logic is in /usr/share/apache2/find_mpm,
# a script which can be used standalone as well if needed.
APACHE_MPM="metuxmpm"
## Type: string
## Default: ""
## ServiceReload: apache2
# email address of the server administrator (ServerAdmin directive)
# This address is added to the server's responses if APACHE_SERVERSIGNATURE
# is set to "email".
# If empty ("") it defaults to webmaster@$FQHOSTNAME, where FQHOSTNAME is
# taken from /etc/HOSTNAME.
# Note that ServerAdmin directives inside VirtualHost statements are not
# changed, even not the one in the stock SSL virtual host block.
APACHE_SERVERADMIN=""
## Type: string
## Default: ""
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If this is not set to valid DNS name for your host, server-generated
# redirections will not work. See also the UseCanonicalName directive.
# If your host doesn't have a registered DNS name, enter its IP address here.
# You will have to access it by its address anyway, and this will make
# redirections work in a sensible way.
APACHE_SERVERNAME=""
## Type: integer
## Default: 2
# timeout during server startup (seconds)
# after this time, the start script decides wether the httpd process started without error.
# Increase it, if you use mod_ssl and your certificate is passphrase protected!
APACHE_START_TIMEOUT="2"
## Type: list(on,off,email)
## Default: "on"
# Configures the footer on server-generated documents
# This correlates to the ServerSignature directive.
APACHE_SERVERSIGNATURE="on"
## Type: list(debug,info,notice,warn,error,crit,alert,emerg)
## Default: "warn"
# LogLevel: Control the number of messages logged to the error_log.
APACHE_LOGLEVEL="warn"
## Type: string
## Default: "/var/log/apache2/access_log combined"
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here. Contrarywise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
# Simply set it to empty, if you configure it yourself somewhere else.
# Examples:
# If you would like to have agent and referer logfiles:
# setting it to "/var/log/apache2/referer_log referer, /var/log/apache2/agent_log agent"
# corresponds to
# CustomLog /var/log/apache2/referer_log referer
# CustomLog /var/log/apache2/agent_log agent
# If you prefer a single logfile with access, agent, and referer information
# (Combined Logfile Format):
# setting it to "/var/log/apache2/access_log combined"
# corresponds to
# CustomLog /var/log/apache2/access_log combined
APACHE_ACCESS_LOG="/var/log/apache2/access_log combined"
## Type: list(On,Off,DNS)
## Default: "Off"
# UseCanonicalName: Determines how Apache constructs self-referencing
# URLs and the SERVER_NAME and SERVER_PORT variables.
# When set "Off", Apache will use the Hostname and Port supplied
# by the client. When set "On", Apache will use the value of the
# ServerName directive.
APACHE_USE_CANONICAL_NAME="off"
## Type: list(Major,Minor,Minimal,ProductOnly,OS,Full)
## Default: "OS"
# How much information the server response header field contains about the server.
# (installed modules, versions, etc.)
# see http://httpd.apache.org/docs-2.0/mod/core.html#servertokens
APACHE_SERVERTOKENS="OS"
## Type: list(on,off)
## Default: "off"
# If mod_status is used, include extended information about the server, like
# CPU usage, in the status report. It is a server-wide setting, and it can cost
# some performance!
APACHE_EXTENDED_STATUS="off"
## Default: "off"
# Enable buffered logging
APACHE_BUFFERED_LOGS="off"
## Type: integer
## Default: 300
# Timeout: The number of seconds before receives and sends time out.
# It is a server wide setting.
APACHE_TIMEOUT="300"
