Aug 26 13:39:56 vps5362 postfix/smtpd[5544]: connect from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:39:56 vps5362 postfix/smtpd[5544]: warning: SASL authentication failure: cannot connect to saslauthd server: No such file or directory
Aug 26 13:39:56 vps5362 postfix/smtpd[5544]: warning: p5B065929.dip.t-dialin.net[91.6.89.41]: SASL LOGIN authentication failed: generic failure
Aug 26 13:39:56 vps5362 postfix/smtpd[5544]: lost connection after AUTH from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:39:56 vps5362 postfix/smtpd[5544]: disconnect from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:01 vps5362 postfix/pickup[5340]: 9CC02A8C96BE: uid=0 from=<root>
Aug 26 13:40:01 vps5362 postfix/cleanup[7613]: 9CC02A8C96BE: message-id=<20110826114001.9CC02A8C96BE@srv4.doelker.info>
Aug 26 13:40:01 vps5362 postfix/qmgr[1350]: 9CC02A8C96BE: from=<root@srv4.doelker.info>, size=751, nrcpt=1 (queue active)
Aug 26 13:40:12 vps5362 postfix/smtpd[5544]: connect from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:12 vps5362 postfix/smtpd[5544]: warning: SASL authentication failure: cannot connect to saslauthd server: No such file or directory
Aug 26 13:40:12 vps5362 postfix/smtpd[5544]: warning: p5B065929.dip.t-dialin.net[91.6.89.41]: SASL LOGIN authentication failed: generic failure
Aug 26 13:40:12 vps5362 postfix/smtpd[5544]: lost connection after AUTH from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:12 vps5362 postfix/smtpd[5544]: disconnect from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:13 vps5362 postfix/smtpd[5544]: connect from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:13 vps5362 postfix/smtpd[5544]: warning: SASL authentication failure: cannot connect to saslauthd server: No such file or directory
Aug 26 13:40:13 vps5362 postfix/smtpd[5544]: warning: p5B065929.dip.t-dialin.net[91.6.89.41]: SASL LOGIN authentication failed: generic failure
Aug 26 13:40:13 vps5362 postfix/smtpd[5544]: lost connection after AUTH from p5B065929.dip.t-dialin.net[91.6.89.41]
Aug 26 13:40:13 vps5362 postfix/smtpd[5544]: disconnect from p5B065929.dip.t-dialin.net[91.6.89.41]
