Error starting daemon. Aborted! Kommt immer wenn ich versuche den Ts zu starten!
Syrius1988
Die Fehlermeldung "Error starting daemon. Aborted" kommt immer wenn ich versuche über das startscript den Ts server zu starten. Aber trotzdem läuft der Server. Das Problem ist das ich wahrscheinlich deswegen immer Timeouts habe.
Wie kann man das beheben?
Hier ist sie?
-------------- log started at 19-10-07 08:50 -------------
19-10-07 08:50:49,ALL,Info,server,	Server init initialized
19-10-07 08:50:49,ALL,Info,server,	Server version: 2.0.23.19 Linux
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_servers
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_server_privileges
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_channels
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_channel_privileges
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_clients
19-10-07 08:50:49,WARNING,Info,SQL,	created table ts2_bans
19-10-07 08:50:49,ALL,Info,server,	Starting VirtualServer id:1 with port:8767
19-10-07 08:50:49,ALL,Info,server,	Started VirtualServer id:1 with port:8767
19-10-07 08:50:49,WARNING,Info,SERVER,	Default VirtualServer created
19-10-07 08:50:49,WARNING,Info,SERVER,	admin account info: username: admin password: zensiert
19-10-07 08:50:49,WARNING,Info,SERVER,	superadmin account info: username: superadmin password: zensiert
--------------- log ended at 19-10-07 08:50 --------------
19-10-07 08:51:03,ALL,Info,server,	Server init finished
19-10-07 08:51:03,WARNING,Info,server,	TeamSpeak Server daemon activated
23-10-07 17:50:45,ALL,Info,server,	Server shutdown initialized
23-10-07 17:50:45,ALL,Info,server,	Stopping VirtualServer id:1 with port:8767
23-10-07 17:50:45,ALL,Info,server,	Stopped VirtualServer id:1 with port:8767
-------------- log started at 23-10-07 18:06 -------------
23-10-07 18:06:13,ALL,Info,server,	Server init initialized
23-10-07 18:06:13,ALL,Info,server,	Server version: 2.0.23.19 Linux
23-10-07 18:06:14,ALL,Info,server,	Starting VirtualServer id:1 with port:8767
23-10-07 18:06:14,ALL,Info,server,	Started VirtualServer id:1 with port:8767
--------------- log ended at 23-10-07 18:06 --------------
23-10-07 18:06:29,ALL,Info,server,	Server init finished
23-10-07 18:06:29,WARNING,Info,server,	TeamSpeak Server daemon activated
Da steht nix Relevantes drin. Such weiter oder mach den TS gesprächiger (Debug Optionen?). /var/log/messages ist evtl. auch ein Blick wert.
