Dl Speed drosseln bei vsftpd.conf
skylow
Hallo zusammen könntet ihr mal da reinschauen wo es einzustellen ist ,damit der download vom Server etwa 240 KB/s Schnell Ist
Danke Im Voraus
# Example config file /etc/vsftpd.conf
# The default compiled in settings are very paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# If you dont change anything here you will have a minimum setup for an
# anonymus FTP server.
# General Settings
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# You may fully customise the login banner string:
ftpd_banner="FTP-server."
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# If  enabled,  all  user  and  group  information in
# directory listings will be displayed as "ftp".
#hide_ids=YES
# Local FTP user Settings
# Uncomment this to allow local users to log in.
local_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=072
# Uncomment to put local users in a chroot() jail in their home directory
# after login.
chroot_local_user=YES
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# The maximum data transfer rate permitted, in bytes per second, for
# local authenticated users. The default is 0 (unlimited).
#local_max_rate=20
# Anonymus FTP user Settings
# Allow anonymous FTP?
anonymous_enable=NO
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=No
# Default umask for anonymus users is 077. You may wish to change this to 022,
#anon_umask=022
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Uncomment this to enable anonymus FTP users to perform other write operations
# like deletion and renaming.
#anon_other_write_enable=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# The maximum data transfer rate permitted, in bytes per second, for anonymous
# authenticated users. The default is 0 (unlimited).
#anon_max_rate=20
# Log Settings
# Activate logging of uploads/downloads.
xferlog_enable=YES
# You may override where the log file goes if you like. The default is shown
# below.
xferlog_file=/var/log/xferlog
# If you want, you can have your log file in standard ftpd xferlog format
xferlog_std_format=YES
# Uncomment this to log all FTP requests and responses. This only works if
# xferlog_std_format is not enabled. Beware, it will create a huge amount of data
# in your logfile.
#log_ftp_protocol=YES
# Uncomment this to enable session status information in the system process listing.
#setproctitle_enable=YES
# Transfer Settings
# Make sure PORT transfer connections originate from port 20 (ftp-data).
#connect_from_port_20=YES
# You may change the default value for timing out an idle session.
#idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that turning on ascii_download_enable enables malicious remote parties
# to consume your I/O resources, by issuing the command "SIZE /big/file" in
# ASCII mode.
# These ASCII options are split into upload and download because you may wish
# to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
# without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
# on the client anyway..
ascii_upload_enable=YES
#ascii_download_enable=YES
# Set to NO if you want to disallow the  PASV  method of obtaining a data
# connection.
#pasv_enable=YES
#pasv_promiscuous=YES
#port_promiscuous=YES
#write_enable=YES
# PAM setting. Do NOT change this unless you know what you do!
pam_service_name=vsftpd
# Set listen=YES if you want vsftpd to run standalone
#listen=YES
Füge einfach folgenden String hinzu (egal wo):
local_max_rate=204800
damit hätteste 200kb...
Wenn es danach (bein nächsten Login auf den FTP-Server) nicht gehen sollte, mußte erst die Version updaten!
