Debian Probleme
bandit600
habe seit ner Weile und in letzter Zeit gehäuft Probleme mit meinem Debian Root.. In letzter Zeit schmiert er immer wieder mal ab, das rätselhafte ist aber, dass es ohne ersichtlichen Grund passiert.. Hier das syslog:
un 15 01:25:14 bravo846 spamd[20190]: clean message (-2.4/5.0) for root:0 in 1.8 seconds, 38008 bytes.
Jun 15 01:25:14 bravo846 spamd[20190]: result: . -2 - ALL_TRUSTED,AWL scantime=1.8,size=38008,mid=<[email protected]>,autolearn=ham
Jun 15 01:26:01 bravo846 /USR/SBIN/CRON[2707]: (root) CMD (/usr/local/confixx/confixx_counterscript.pl)
Jun 15 01:27:01 bravo846 /USR/SBIN/CRON[2716]: (root) CMD (/usr/local/confixx/confixx_counterscript.pl)
Jun 15 01:28:01 bravo846 /USR/SBIN/CRON[2720]: (root) CMD (/usr/local/confixx/confixx_counterscript.pl)
Jun 15 01:28:26 bravo846 kernel: nfs: server 10.0.0.8 not responding, still trying
Jun 15 01:28:40 bravo846 last message repeated 8 times
Jun 15 01:29:01 bravo846 /USR/SBIN/CRON[2729]: (root) CMD (/usr/local/confixx/confixx_counterscript.pl)
Jun 15 01:30:01 bravo846 /USR/SBIN/CRON[2732]: (root) CMD ([ -x /etc/munin/plugins/apt ] && /etc/munin/plugins/apt update 7200 12 >/dev/null)
Jun 15 01:30:01 bravo846 /USR/SBIN/CRON[2734]: (munin) CMD (if [ -x /usr/bin/munin-cron ]; then /usr/bin/munin-cron; fi)
Jun 15 01:30:01 bravo846 /USR/SBIN/CRON[2736]: (root) CMD (/usr/local/confixx/confixx_counterscript.pl)
Jun 15 01:30:03 bravo846 kernel: powernow-k8: error - out of sync, fix 0x2 0xc, vid 0x12 0xe
Jun 15 01:30:26 bravo846 courierpop3login: Connection, ip=[::ffff:209.85.132.130]
Jun 15 01:30:26 bravo846 courierpop3login: LOGIN, user=web1p3, ip=[::ffff:209.85.132.130]
Jun 15 01:30:26 bravo846 courierpop3login: LOGOUT, user=web1p3, ip=[::ffff:209.85.132.130], top=0, retr=0, time=0
Jun 16 00:40:31 bravo846 syslogd 1.4.1#17: restart.
Jun 16 00:40:31 bravo846 kernel: klogd 1.4.1#17, log source = /proc/kmsg started.
Jun 16 00:40:31 bravo846 kernel: Inspecting /boot/System.map-2.6.14-2-k7-smp
Jun 16 00:40:31 bravo846 kernel: Loaded 21544 symbols from /boot/System.map-2.6.14-2-k7-smp.
Jun 16 00:40:31 bravo846 kernel: Symbols match kernel version 2.6.14.
Jun 16 00:40:31 bravo846 kernel: No module symbols loaded - kernel modules not enabled.
Jun 16 00:40:31 bravo846 kernel: Linux version 2.6.14-2-k7-smp (Debian 2.6.14-2bpo1) ([email protected]) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 SMP Tue Nov 15 00:28:07 CET 2005
Jun 16 00:40:31 bravo846 kernel: BIOS-provided physical RAM map:
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 0000000000000000 - 000000000009e000 (usable)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 000000000009e000 - 00000000000a0000 (reserved)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 00000000000d0000 - 0000000000100000 (reserved)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 0000000000100000 - 000000007df10000 (usable)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 000000007df10000 - 000000007df16000 (ACPI data)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 000000007df16000 - 000000007df80000 (ACPI NVS)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 000000007df80000 - 0000000080000000 (reserved)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 00000000fc000000 - 00000000fe000000 (reserved)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
Jun 16 00:40:31 bravo846 kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Das ist jetzt mal ein Auszug aus der betreffenden Zeit, um 0:40 hab ich Ihn dann per Hardware-Restart neustarten lassen, per Software-Restart ging garnix mehr..
Wird daraus jmd schlau oder hat ähnliche Probleme? Das System ist ein Debian 3.1 bei Server 4 You.. Gibt es die Möglichkeit einen Hardware-Schaden auszuschließen??
Grüße und Hoffe auf Hilfe
Interessant... Kurz vor dem Absturz sind die INodes nach oben gesprungen, wasimmer das auch verursacht hat oder woher es auch kommt.. (siehe Anhang)
Kann da jmd was zu sagen??
