APT Problem Debian Etch!
oliver-siewert
Hey Leute,
Hab ein Problem und zwar ich will ich den Kernel Updaten
und brauche da verschiendene Programme die ich per APT
installieren will.
Beim aufrufen des Befehls
apt-get install libc6-dev gcc binutils modutils kernel-package libncurses5-dev debianutils make bzip2
bekomme ich folgende Ausgabe! :
mesch:~# apt-get install libc6-dev gcc binutils modutils kernel-package libncurses5-dev debianutils make bzip2
Reading package lists... Done
Building dependency tree... Done
libc6-dev is already the newest version.
gcc is already the newest version.
binutils is already the newest version.
modutils is already the newest version.
kernel-package is already the newest version.
libncurses5-dev is already the newest version.
debianutils is already the newest version.
make is already the newest version.
bzip2 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
Need to get 0B of archives.
After unpacking 0B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = "de_DE",
        LANG = "de_DE"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up sasl2-bin (2.1.22.dfsg1-8) ...
        LANGUAGE = (unset),
        LC_ALL = "de_DE",
        LANG = "de_DE"
Starting SASL Authentication Daemon: perl: warning: Setting locale failed.
        LANGUAGE = (unset),
        LC_ALL = "de_DE",
        LANG = "de_DE"
Hab da zwar schon paar ma dran rumprobiert aber nichts hinbekommen.
Hat jemand von euch vielleicht eine schnelle elegante Lösung.
Wäre euch sehr dankbar ;)
Danke im Vorraus und Gruß aus Hessen :D
        LANGUAGE = (unset),
        LC_ALL = "de_DE",
        LANG = "de_DE"
/usr/sbin/dpkg-reconfigure: locales is broken or not fully installed
mesch:~#
So viel zum Thema locales... wie fixx ich das nun am besten?
Jo hab ich gemacht, also "All" und dann hab ich upgrade probiert und es kommt wieder eine riesige Fehlermeldung..
Setting up libtimedate-perl (1.1600-7) ...
Setting up dhcp-client (2.0pl5dfsg1-20) ...
        LANGUAGE = (unset),
        LC_ALL = "de_DE",
        LANG = "de_DE"
 sasl2-bin
