Auf einem Suse 9.2 mit Apache 2.0.50 habe ich folgendes Phänomen:
Ca. alle 2 Tage gegen Abend hängt sich mein Apache auf. Der Server läuft normal weiter und ich komme per SSH drauf. Nur der Apache lüppt nicht.
Ein manueller restart und es geht wieder.
Im error.log finde ich zu besagter Zeit immer diese Zeile:
Das geht dann solange weiter, bis ich den Apache restarte.
Dann kommt:
Also es läuft noch Confixx 3 drauf. Deswegen ist suexec installiert.
Kann denn jemand was mit der Fehlermeldung anfangen?
Ich danke schon mal für eure Hilfe.
[Thu May 12 18:19:56 2005] [warn] child process 30249 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 2365 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 18008 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 26807 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 32173 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 2737 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24709 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24016 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24070 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24583 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24770 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 17943 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24700 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24764 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24666 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24333 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24145 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 6748 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 2788 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24677 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 24710 still did not exit, sending a SIGTERM
[Thu May 12 18:19:57 2005] [warn] child process 32251 still did not exit, sending a SIGTERM
Dann kommt:
[Thu May 12 18:19:58 2005] [notice] caught SIGTERM, shutting down
[Thu May 12 18:19:59 2005] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Thu May 12 18:19:59 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec2)
[Thu May 12 18:20:00 2005] [notice] Apache/2.0.50 (Linux/SUSE) configured -- resuming normal operations
