>> MySQLTuner 1.7.0 - Major Hayden <[email protected]>
>> Bug reports, feature requests, and downloads at http://mysqltuner.com/
>> Run with '--help' for additional options and output filtering
[--] Skipped version check for MySQLTuner script
[OK] Logged in using credentials from debian maintenance account.
[OK] Currently running supported MySQL version 5.7.16
[OK] Operating on 64-bit architecture
-------- Storage Engine Statistics -----------------------------------------------------------------
[--] Status: +ARCHIVE +BLACKHOLE +CSV -FEDERATED +InnoDB +MEMORY +MRG_MYISAM +MyISAM +PERFORMANCE_SCHEMA
[--] Data in MEMORY tables: 1M (Tables: 2)
[--] Data in MyISAM tables: 2G (Tables: 262)
[--] Data in InnoDB tables: 2M (Tables: 81)
[OK] Total fragmented tables: 0
-------- Security Recommendations ------------------------------------------------------------------
[OK] There are no anonymous accounts for any database users
[OK] All database users have passwords assigned
[--] There are 612 basic passwords in the list.
-------- CVE Security Recommendations --------------------------------------------------------------
[OK] NO SECURITY CVE FOUND FOR YOUR VERSION
-------- Performance Metrics -----------------------------------------------------------------------
[--] Up for: 3d 2h 23m 42s (19M q [71.568 qps], 1M conn, TX: 1062G, RX: 5G)
[--] Reads / Writes: 91% / 9%
[--] Binary logging is disabled
[--] Physical Memory : 7.7G
[--] Max MySQL memory : 3.7G
[--] Other process memory: 962.5M
[--] Total buffers: 656.0M global + 6.2M per thread (500 max threads)
[--] P_S Max memory usage: 0B
[--] Galera GCache Max memory usage: 0B
[OK] Maximum reached memory usage: 743.5M (9.38% of installed RAM)
[OK] Maximum possible memory usage: 3.7G (47.72% of installed RAM)
[OK] Overall possible memory usage with other process is compatible with memory available
[OK] Slow queries: 0% (0/19M)
[OK] Highest usage of available connections: 2% (14/500)
[OK] Aborted connections: 0.00% (3/1441902)
[!!] name resolution is active : a reverse name resolution is made for each new connection and can reduce performance
[OK] Query cache is disabled by default due to mutex contention on multiprocessor machines.
[OK] Sorts requiring temporary tables: 0% (1K temp sorts / 2M sorts)
[!!] Joins performed without indexes: 188220
[OK] Temporary tables created on disk: 2% (11K on disk / 398K total)
[OK] Thread cache hit rate: 99% (80 created / 1M connections)
[!!] Table cache hit rate: 16% (2K open / 13K opened)
[OK] Open file limit used: 44% (2K/5K)
[OK] Table locks acquired immediately: 99% (25M immediate / 25M locks)
-------- Performance schema ------------------------------------------------------------------------
[--] Performance schema is disabled.
-------- ThreadPool Metrics ------------------------------------------------------------------------
[--] ThreadPool stat is disabled.
-------- MyISAM Metrics ----------------------------------------------------------------------------
[OK] Key buffer used: 100.0% (268M used / 268M cache)
[OK] Key buffer size / total MyISAM indexes: 256.0M/642.6M
[OK] Read Key buffer hit rate: 100.0% (980M cached / 304K reads)
[!!] Write Key buffer hit rate: 39.1% (1M cached / 621K writes)
-------- InnoDB Metrics ----------------------------------------------------------------------------
[--] InnoDB is enabled.
[OK] InnoDB buffer pool / data size: 128.0M/2.6M
[!!] Ratio InnoDB log file size / InnoDB Buffer pool size (37.5 %): 48.0M/128.0M should be equal 25%
[OK] InnoDB buffer pool instances: 1
[--] Number of InnoDB Buffer Pool Chunk : 1 for 1 Buffer Pool Instance(s)
[OK] Innodb_buffer_pool_size aligned with Innodb_buffer_pool_chunk_size & Innodb_buffer_pool_instances
[OK] InnoDB Read buffer efficiency: 99.99% (5180814 hits/ 5181467 total)
[!!] InnoDB Write Log efficiency: 166.97% (30149 hits/ 18057 total)
[OK] InnoDB log waits: 0.00% (0 waits / 48206 writes)
-------- AriaDB Metrics ----------------------------------------------------------------------------
[--] AriaDB is disabled.
-------- TokuDB Metrics ----------------------------------------------------------------------------
[--] TokuDB is disabled.
-------- XtraDB Metrics ----------------------------------------------------------------------------
[--] XtraDB is disabled.
-------- RocksDB Metrics ---------------------------------------------------------------------------
[--] RocksDB is disabled.
-------- Spider Metrics ----------------------------------------------------------------------------
[--] Spider is disabled.
-------- Connect Metrics ---------------------------------------------------------------------------
[--] Connect is disabled.
-------- Galera Metrics ----------------------------------------------------------------------------
[--] Galera is disabled.
-------- Replication Metrics -----------------------------------------------------------------------
[--] Galera Synchronous replication: NO
[--] No replication slave(s) for this server.
[--] This is a standalone server.
-------- Recommendations ---------------------------------------------------------------------------
General recommendations:
Configure your accounts with ip or subnets only, then update your configuration with skip-name-resolve=1
Adjust your join queries to always utilize indexes
Increase table_open_cache gradually to avoid file descriptor limits
Read this before increasing table_open_cache over 64: http://bit.ly/1mi7c4C
Beware that open_files_limit (5000) variable
should be greater than table_open_cache (2245)
Variables to adjust:
join_buffer_size (> 512.0K, or always use indexes with joins)
table_open_cache (> 2245)
innodb_log_file_size should be equals to 1/4 of buffer pool size (=32M) if possible.
