1&1 RootServer mit Plesk + Postfix damit 1&1 Mailhost nutzen und Mails in 1&1 Webmail
CompuMan
Ich habe bei 1&1 einen Root Server mit Centos 6.4 und Plesk 11 und Postfix. Die
Ausgabe von host 123server.de ergibt (Servername natürlich nicht echt):
123server.de mail is handled by 10 mx00.kundenserver.de
123server.de mail is handled by 10 mx01.kundenserver.de
main.cf (ip Adressen geändert bzw. unkenntlich)
command_directory = /usr/sbin
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
mail_owner = postfix
inet_interfaces = all
inet_protocols = all
mydestination = localhost.$mydomain, localhost, localhost.localdomain
debug_peer_level = 2
debugger_command =
	 ddd $daemon_directory/$process_name $process_id & sleep 5
sendmail_path = /usr/sbin/sendmail.postfix
newaliases_path = /usr/bin/newaliases.postfix
mailq_path = /usr/bin/mailq.postfix
setgid_group = postdrop
html_directory = no
sample_directory = /usr/share/doc/postfix-2.8.4/samples
readme_directory = /usr/share/doc/postfix-2.8.4/README_FILES
#virtual_mailbox_domains = $virtual_mailbox_maps, hash:/var/spool/postfix/plesk/virtual_domains
#virtual_alias_maps = $virtual_maps, hash:/var/spool/postfix/plesk/virtual
#virtual_mailbox_maps = hash:/var/spool/postfix/plesk/vmailbox
transport_maps = hash:/var/spool/postfix/plesk/transport
smtpd_use_tls = yes
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
mynetworks = 127.0.0.0/8 [::1]/128 xx.xxx.xx.xxx/32 [8081:898:12g:4840::22:d547]/128
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated, check_client_access pcre:/var/spool/postfix/plesk/non_auth.re
smtpd_client_restrictions = permit_mynetworks
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, check_client_access pcre:/var/spool/postfix/plesk/no_relay.re, permit_sasl_authenticated, reject_unauth_destination
virtual_uid_maps = static:110
virtual_gid_maps = static:31
smtpd_milters = inet:localhost:12768
non_smtpd_milters = inet:localhost:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
mailman_destination_recipient_limit = 1
myhostname = 123server.de
message_size_limit = 10240000
Ich habe im 1&1 Webmailer alle meine Emailadressen angelegt (sagen wir z.B. info@123server.de und meier@123server.de) und dort auch als DNS den 1&1 Webmailer eingestellt. In Plesk ist für das Abonnement E-Maildienst auf Domän ausgestellt. Die serverweite E-Mailverwaltungseinstellung ist eingeschaltet. Es ist im gesamten Plesk keine E-Mailadresse angelegt.
Soweit läuft alles korrekt. Wenn ich in einer Anwendung vom Server im php Code (z.B. ein Kontaktformular) angebe das info@123server.de der Versender ist dann wird die Mail auch korrekt versendet. Im Return-Path steht dann noch zusätzlich gesendet von admin@123server.de , also eine automatische Emailadresse des Namens des Adminkontos (wo kann man das ändern ?) und natürlich von info@123server.de.
Sollte ein Besucher versehentlich eine falsche EMailadresse angegeben haben, so steht diese Mail dann in Plesk unter E-Mailwarteschlange. Also ich erfahre nicht das eine Mail hängengeblieben ist und kann sie auch nicht ändern oder weiterleiten. Ausserdem kann ich nur über das Log nachverfolgen welche Mails gesendet wurden.
Nun mein Wunsch was ich gerne wollte. Plesk bzw. den Server ganz von der Bearbeitung ausschliessen, also alle E-Mailverwaltungsdienste von Plesk deaktivieren. Alle Mails sollen auch im Webmailer von 1&1 auftauchen und verwaltet werden können. Denn was nützen mir dort angelegt Konten wenn da nichts zu sehen ist und nur die Namen verwendet werden ?
Also der 1&1 Root Server soll alle Mails quasi versenden als würde man direkt vom 1&1 Webmailer versenden. Da ich mal ein Hostingpaket hatte bei 1&1 wo auch eine Anwendung per sendmail versendet hatte, weiss ich das es gehen muss und genauso ist es ja auch bei allen anderen Hostingpaketen. Denn dort war es genauso wie ich es haben wollte. Es muss also an den Einstellungen liegen.
Vielleicht hat das ja auch schon Jemand selber so gelöst. Es wäre super wenn Ihr mir helfen könntet, denn so ist das nicht optimal.
Noch eine kleine Verständnissfrage, wieso stehen in Plesk zwei Postfix Services ? Einmal Plesk Milter (postfix) und einmal SMTP-Server (postfix). Den Dienst SMTP-Server habe ich dauerhaft deaktiviert.
Gruss
Wenn Du ganz ohne lokale Warteschlange auskommen willst (also ganz ohne lokalen MDA, mail delivery agent) musst Du deine PHP-Anwendungen so umstellen, dass sie einen SMTP-Server verwenden können. Dort trägst Du dann den 1&1 Mailserver und die jeweiligen Zugangsdaten für den Kundenaccount ein.
siehe z.B. hier. Da geht es zwar explizit um gmail, das Prinzip ist bei 1&1 aber identisch:
http://stackoverflow.com/questions/712392/send-email-using-gmail-smtp-server-from-php-page
Ich habe hier noch unter den Hilfen von 1&1 folgenden Text gefunden
So nutzen Sie das 1&1-Mailsystem mit Postfix unter Linux.
Mit Postfix können Sie Ihre 1&1 E-Mail-Accounts komfortabel und sicher auf Ihrem Linux-Server verwalten.
Stellen Sie bitte sicher, dass die folgende Module im Falle von SuSE Linux zusätzlich zu Postfix auf Ihrem Rechner installiert sind.
    cyrus-sasl
    postfix
Schritt 1:
Editieren Sie die Datei,
/etc/postfix/main.cf
sie muss folgende Zeilen enthalten:
relayhost = smtp.1und1.de smtp_sasl_auth_enable = yes smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd smtp_sasl_security_options = noanonymous
Schritt 2:
Die Datei
enthält folgenden Eintrag:
smtp.1und1.de mail@ihre-webhosting-domain.de:mypass
mail@ihre-webhosting-domain.de und mypass sind durch den Benutzernamen und das dazugehörige Passwort zu ersetzen. Die Rechte der Datei sollten
(-rw------) root.root
sein.
Schritt 3:
Konvertieren Sie die Datei in .db-Format:
postmap /etc/postfix/sasl_passwd
und starten Sie Postfix erneut:
/etc/init.d/postfix reload
Vielleicht stehe ich ja irgendwie auf dem Schlauch, aber für mich klingt das so wie es erklärt wird : "So nutzen Sie das 1&1-Mailsystem mit Postfix unter Linux" nach dem umgekehrten Fall oder nicht ? Es muss doch heissen "So nutzt Postfix das 1&1 Mailsystem" oder nicht ?
Aber wie gesagt vielleicht stehe ich ja total auf dem Schlauch und dies ist genau die lösung die ich gesucht habe. Was meint Ihr ?
Da hier über Suse gesprochen wird, was für Module brauche ich für Centos ?
Die eine Mailadresse reicht doch um sich am Server zu authorisieren um dann aber auch mit verschiedenen Absendemails versenden zu können, oder ? Es geht doch nur darum eine funktionierende authorisierte Verbindung zu erstellen, oder ?
Wäre schön wenn Ihr Euch dazu mal melden könntet.
Grüsse
