Updated OpenSSL packages fix vulnerabilities
A
Admin
Summary:
Updated OpenSSL packages that fix ASN.1 parsing vulnerabilities are now
available for Red Hat Linux versions 7.1, 7.2, 7.3, and 8.0.
Description:
OpenSSL is a commercial-grade, full-featured, open source toolkit that
implements Secure Sockets Layer (SSL v2/v3) and Transport Layer Security
(TLS v1) protocols, as well as a full-strength general purpose cryptography
library.
NISCC testing of implementations of the SSL protocol uncovered two bugs in
OpenSSL 0.9.6 and OpenSSL 0.9.7. The parsing of unusual ASN.1 tag values
can cause OpenSSL to crash. A remote attacker could trigger this bug by
sending a carefully-crafted SSL client certificate to an application. The
effects of such an attack vary depending on the application targetted;
against Apache the effects are limited, as the attack would only cause
child processes to die and be replaced. An attack against other
applications that use OpenSSL could result in a Denial of Service. The
Common Vulnerabilities and Exposures project (cve.mitre.org) has assigned
the names CAN-2003-0543 and CAN-2003-0544 to this issue.
Red Hat Linux versions 7.1, 7.2, 7.3, and 8.0 contain OpenSSL 0.9.6 and are
therefore vulnerable to this issue.
These erratum packages contain a patch provided by the OpenSSL group that
protects against this issue.
Because server applications are affected by this issue, users are advised
to either restart all services that use OpenSSL functionality or reboot
their systems after installing these updates.
Red Hat would like to thank NISCC and Stephen Henson for their work on this
vulnerability.
These packages also include a patch from OpenSSL 0.9.6f which removes
the calls to abort the process in certain circumstances. Red Hat would
like to thank Patrik Hornik for notifying us of this issue.
References:
http://www.niscc.gov.uk/
http://www.openssl.org/news/secadv_20030930.txt
