2020-02-05T09:00:39.163112Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2020-02-05T09:00:40.620421Z 0 [Warning] InnoDB: New log files created, LSN=45790
2020-02-05T09:00:41.228739Z 0 [Warning] InnoDB: Creating foreign key constraint system tables.
2020-02-05T09:00:41.565267Z 0 [Warning] No existing UUID has been found, so we assume that this is the first time that this server has been started. Generating a new UUID: fc6b02f9-47f5-11ea-baf3-0084ed59d048.
2020-02-05T09:00:41.655373Z 0 [Warning] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened.
2020-02-05T09:00:42.134713Z 0 [Warning] CA certificate ca.pem is self signed.
2020-02-05T09:00:42.425319Z 1 [Warning] root@localhost is created with an empty password ! Please consider switching off the --initialize-insecure option.
2020-02-05T09:01:24.307304Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2020-02-05T09:01:24.309342Z 0 [Note] mysqld (mysqld 5.7.29-0ubuntu0.18.04.1) starting as process 3133 ...
2020-02-05T09:01:24.314209Z 0 [Note] InnoDB: PUNCH HOLE support available
2020-02-05T09:01:24.314237Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-02-05T09:01:24.314245Z 0 [Note] InnoDB: Uses event mutexes
2020-02-05T09:01:24.314253Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2020-02-05T09:01:24.314260Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-02-05T09:01:24.314268Z 0 [Note] InnoDB: Using Linux native AIO
2020-02-05T09:01:24.314577Z 0 [Note] InnoDB: Number of pools: 1
2020-02-05T09:01:24.314702Z 0 [Note] InnoDB: Using CPU crc32 instructions
2020-02-05T09:01:24.316513Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-02-05T09:01:24.327983Z 0 [Note] InnoDB: Completed initialization of buffer pool
2020-02-05T09:01:24.330595Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-02-05T09:01:24.343329Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2020-02-05T09:01:24.463988Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-02-05T09:01:24.464050Z 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-02-05T09:01:24.587118Z 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-02-05T09:01:24.588081Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2020-02-05T09:01:24.588094Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2020-02-05T09:01:24.589071Z 0 [Note] InnoDB: 5.7.29 started; log sequence number 2630588
2020-02-05T09:01:24.589454Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2020-02-05T09:01:24.589770Z 0 [Note] Plugin 'FEDERATED' is disabled.
2020-02-05T09:01:24.591683Z 0 [Note] InnoDB: Buffer pool(s) load completed at 200205 10:01:24
2020-02-05T09:01:24.596675Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2020-02-05T09:01:24.596691Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2020-02-05T09:01:24.597431Z 0 [Warning] CA certificate ca.pem is self signed.
2020-02-05T09:01:24.597465Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2020-02-05T09:01:24.666320Z 0 [Warning] Insecure configuration for --pid-file: Location '/tmp' in the path is accessible to all OS users. Consider choosing a different directory.
2020-02-05T09:01:24.675060Z 0 [Note] Event Scheduler: Loaded 0 events
2020-02-05T09:01:24.675378Z 0 [Note] mysqld: ready for connections.
Version: '5.7.29-0ubuntu0.18.04.1' socket: '/tmp/tmp.4WJGBQ79t0/mysqld.sock' port: 0 (Ubuntu)
2020-02-05T09:01:24.786504Z 0 [Note] Giving 0 client threads a chance to die gracefully
2020-02-05T09:01:24.786534Z 0 [Note] Shutting down slave threads
2020-02-05T09:01:24.786544Z 0 [Note] Forcefully disconnecting 0 remaining clients
2020-02-05T09:01:24.786552Z 0 [Note] Event Scheduler: Purging the queue. 0 events
2020-02-05T09:01:24.786599Z 0 [Note] Binlog end
2020-02-05T09:01:24.787131Z 0 [Note] Shutting down plugin 'auth_socket'
2020-02-05T09:01:24.787141Z 0 [Note] Shutting down plugin 'ngram'
2020-02-05T09:01:24.787147Z 0 [Note] Shutting down plugin 'partition'
2020-02-05T09:01:24.787153Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2020-02-05T09:01:24.787160Z 0 [Note] Shutting down plugin 'ARCHIVE'
2020-02-05T09:01:24.787165Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2020-02-05T09:01:24.787200Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2020-02-05T09:01:24.787206Z 0 [Note] Shutting down plugin 'MyISAM'
2020-02-05T09:01:24.787214Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
2020-02-05T09:01:24.787220Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2020-02-05T09:01:24.787226Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2020-02-05T09:01:24.787232Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2020-02-05T09:01:24.787237Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2020-02-05T09:01:24.787255Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2020-02-05T09:01:24.787260Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2020-02-05T09:01:24.787265Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2020-02-05T09:01:24.787270Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2020-02-05T09:01:24.787275Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2020-02-05T09:01:24.787280Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2020-02-05T09:01:24.787285Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2020-02-05T09:01:24.787289Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2020-02-05T09:01:24.787294Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2020-02-05T09:01:24.787299Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2020-02-05T09:01:24.787304Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2020-02-05T09:01:24.787309Z 0 [Note] Shutting down plugin 'INNODB_METRICS'
2020-02-05T09:01:24.787313Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO'
2020-02-05T09:01:24.787318Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2020-02-05T09:01:24.787323Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2020-02-05T09:01:24.787328Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2020-02-05T09:01:24.787333Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2020-02-05T09:01:24.787337Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2020-02-05T09:01:24.787342Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2020-02-05T09:01:24.787347Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM'
2020-02-05T09:01:24.787352Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2020-02-05T09:01:24.787356Z 0 [Note] Shutting down plugin 'INNODB_CMP'
2020-02-05T09:01:24.787361Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2020-02-05T09:01:24.787366Z 0 [Note] Shutting down plugin 'INNODB_LOCKS'
2020-02-05T09:01:24.787371Z 0 [Note] Shutting down plugin 'INNODB_TRX'
2020-02-05T09:01:24.787376Z 0 [Note] Shutting down plugin 'InnoDB'
2020-02-05T09:01:24.787565Z 0 [Note] InnoDB: FTS optimize thread exiting.
2020-02-05T09:01:24.787673Z 0 [Note] InnoDB: Starting shutdown...
2020-02-05T09:01:24.888126Z 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
2020-02-05T09:01:24.888321Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 200205 10:01:24
2020-02-05T09:01:26.677926Z 0 [Note] InnoDB: Shutdown completed; log sequence number 2630809
2020-02-05T09:01:26.680116Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2020-02-05T09:01:26.680133Z 0 [Note] Shutting down plugin 'MEMORY'
2020-02-05T09:01:26.680142Z 0 [Note] Shutting down plugin 'CSV'
2020-02-05T09:01:26.680150Z 0 [Note] Shutting down plugin 'sha256_password'
2020-02-05T09:01:26.680155Z 0 [Note] Shutting down plugin 'mysql_native_password'
2020-02-05T09:01:26.680354Z 0 [Note] Shutting down plugin 'binlog'
2020-02-05T09:01:26.680637Z 0 [Note] mysqld: Shutdown complete
2020-02-05T09:01:27.297551Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2020-02-05T09:01:27.299567Z 0 [Note] mysqld (mysqld 5.7.29-0ubuntu0.18.04.1) starting as process 3183 ...
2020-02-05T09:01:27.304368Z 0 [Note] InnoDB: PUNCH HOLE support available
2020-02-05T09:01:27.304388Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-02-05T09:01:27.304396Z 0 [Note] InnoDB: Uses event mutexes
2020-02-05T09:01:27.304403Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2020-02-05T09:01:27.304410Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-02-05T09:01:27.304417Z 0 [Note] InnoDB: Using Linux native AIO
2020-02-05T09:01:27.304721Z 0 [Note] InnoDB: Number of pools: 1
2020-02-05T09:01:27.304845Z 0 [Note] InnoDB: Using CPU crc32 instructions
2020-02-05T09:01:27.306671Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-02-05T09:01:27.317514Z 0 [Note] InnoDB: Completed initialization of buffer pool
2020-02-05T09:01:27.320238Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-02-05T09:01:27.333478Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2020-02-05T09:01:27.448775Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-02-05T09:01:27.448835Z 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-02-05T09:01:27.572027Z 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-02-05T09:01:27.572982Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2020-02-05T09:01:27.572994Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2020-02-05T09:01:27.574011Z 0 [Note] InnoDB: 5.7.29 started; log sequence number 2630809
2020-02-05T09:01:27.574321Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2020-02-05T09:01:27.574594Z 0 [Note] Plugin 'FEDERATED' is disabled.
2020-02-05T09:01:27.576949Z 0 [Note] InnoDB: Buffer pool(s) load completed at 200205 10:01:27
2020-02-05T09:01:27.581872Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2020-02-05T09:01:27.581889Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2020-02-05T09:01:27.582642Z 0 [Warning] CA certificate ca.pem is self signed.
2020-02-05T09:01:27.582675Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2020-02-05T09:01:27.582749Z 0 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
2020-02-05T09:01:27.582761Z 0 [Note] - '127.0.0.1' resolves to '127.0.0.1';
2020-02-05T09:01:27.582794Z 0 [Note] Server socket created on IP: '127.0.0.1'.
2020-02-05T09:01:27.676041Z 0 [Warning] Insecure configuration for --pid-file: Location '/tmp' in the path is accessible to all OS users. Consider choosing a different directory.
2020-02-05T09:01:27.683972Z 0 [Note] Event Scheduler: Loaded 0 events
2020-02-05T09:01:27.684188Z 0 [Note] Execution of init_file '/var/lib/mysql-files/tmp.14UNeVYXhi' started.
2020-02-05T09:01:27.685022Z 0 [Note] Execution of init_file '/var/lib/mysql-files/tmp.14UNeVYXhi' ended.
2020-02-05T09:01:27.685108Z 0 [Note] mysqld: ready for connections.
Version: '5.7.29-0ubuntu0.18.04.1' socket: '/tmp/tmp.yu1MCXyl3K/mysqld.sock' port: 3306 (Ubuntu)
2020-02-05T09:01:27.685348Z 0 [Note] Giving 0 client threads a chance to die gracefully
2020-02-05T09:01:27.685363Z 0 [Note] Shutting down slave threads
2020-02-05T09:01:27.685369Z 0 [Note] Forcefully disconnecting 0 remaining clients
2020-02-05T09:01:27.685376Z 0 [Note] Event Scheduler: Purging the queue. 0 events
2020-02-05T09:01:27.685413Z 0 [Note] Binlog end
2020-02-05T09:01:27.685813Z 0 [Note] Shutting down plugin 'auth_socket'
2020-02-05T09:01:27.685820Z 0 [Note] Shutting down plugin 'ngram'
2020-02-05T09:01:27.685825Z 0 [Note] Shutting down plugin 'partition'
2020-02-05T09:01:27.685831Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2020-02-05T09:01:27.685836Z 0 [Note] Shutting down plugin 'ARCHIVE'
2020-02-05T09:01:27.685841Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2020-02-05T09:01:27.685865Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2020-02-05T09:01:27.685876Z 0 [Note] Shutting down plugin 'MyISAM'
2020-02-05T09:01:27.685882Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
2020-02-05T09:01:27.685888Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2020-02-05T09:01:27.685892Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2020-02-05T09:01:27.685897Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2020-02-05T09:01:27.685902Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2020-02-05T09:01:27.685924Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2020-02-05T09:01:27.685930Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2020-02-05T09:01:27.685935Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2020-02-05T09:01:27.685940Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2020-02-05T09:01:27.685944Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2020-02-05T09:01:27.685949Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2020-02-05T09:01:27.685954Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2020-02-05T09:01:27.685959Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2020-02-05T09:01:27.685964Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2020-02-05T09:01:27.685969Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2020-02-05T09:01:27.685973Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2020-02-05T09:01:27.685978Z 0 [Note] Shutting down plugin 'INNODB_METRICS'
2020-02-05T09:01:27.685983Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO'
2020-02-05T09:01:27.685988Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2020-02-05T09:01:27.685993Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2020-02-05T09:01:27.685998Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2020-02-05T09:01:27.686002Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2020-02-05T09:01:27.686007Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2020-02-05T09:01:27.686012Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2020-02-05T09:01:27.686017Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM'
2020-02-05T09:01:27.686022Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2020-02-05T09:01:27.686027Z 0 [Note] Shutting down plugin 'INNODB_CMP'
2020-02-05T09:01:27.686032Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2020-02-05T09:01:27.686036Z 0 [Note] Shutting down plugin 'INNODB_LOCKS'
2020-02-05T09:01:27.686041Z 0 [Note] Shutting down plugin 'INNODB_TRX'
2020-02-05T09:01:27.686046Z 0 [Note] Shutting down plugin 'InnoDB'
2020-02-05T09:01:27.686085Z 0 [Note] InnoDB: FTS optimize thread exiting.
2020-02-05T09:01:27.686176Z 0 [Note] InnoDB: Starting shutdown...
2020-02-05T09:01:27.786411Z 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
2020-02-05T09:01:27.786540Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 200205 10:01:27
2020-02-05T09:01:29.523539Z 0 [Note] InnoDB: Shutdown completed; log sequence number 2630828
2020-02-05T09:01:29.525693Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2020-02-05T09:01:29.525706Z 0 [Note] Shutting down plugin 'MEMORY'
2020-02-05T09:01:29.525714Z 0 [Note] Shutting down plugin 'CSV'
2020-02-05T09:01:29.525721Z 0 [Note] Shutting down plugin 'sha256_password'
2020-02-05T09:01:29.525726Z 0 [Note] Shutting down plugin 'mysql_native_password'
2020-02-05T09:01:29.525912Z 0 [Note] Shutting down plugin 'binlog'
2020-02-05T09:01:29.526186Z 0 [Note] mysqld: Shutdown complete
2020-02-05T09:01:30.276856Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2020-02-05T09:01:30.278875Z 0 [Note] /usr/sbin/mysqld (mysqld 5.7.29-0ubuntu0.18.04.1) starting as process 3283 ...
2020-02-05T09:01:30.283962Z 0 [Note] InnoDB: PUNCH HOLE support available
2020-02-05T09:01:30.283989Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-02-05T09:01:30.283996Z 0 [Note] InnoDB: Uses event mutexes
2020-02-05T09:01:30.284003Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2020-02-05T09:01:30.284010Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-02-05T09:01:30.284016Z 0 [Note] InnoDB: Using Linux native AIO
2020-02-05T09:01:30.284322Z 0 [Note] InnoDB: Number of pools: 1
2020-02-05T09:01:30.284444Z 0 [Note] InnoDB: Using CPU crc32 instructions
2020-02-05T09:01:30.286250Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-02-05T09:01:30.297755Z 0 [Note] InnoDB: Completed initialization of buffer pool
2020-02-05T09:01:30.300378Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-02-05T09:01:30.313551Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2020-02-05T09:01:30.549587Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-02-05T09:01:30.549664Z 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-02-05T09:01:30.676114Z 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-02-05T09:01:30.677057Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2020-02-05T09:01:30.677069Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2020-02-05T09:01:30.677993Z 0 [Note] InnoDB: 5.7.29 started; log sequence number 2630828
2020-02-05T09:01:30.678292Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2020-02-05T09:01:30.678518Z 0 [Note] Plugin 'FEDERATED' is disabled.
2020-02-05T09:01:30.679837Z 0 [Note] InnoDB: Buffer pool(s) load completed at 200205 10:01:30
2020-02-05T09:01:30.685307Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2020-02-05T09:01:30.685322Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2020-02-05T09:01:30.686005Z 0 [Warning] CA certificate ca.pem is self signed.
2020-02-05T09:01:30.686038Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2020-02-05T09:01:30.686114Z 0 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
2020-02-05T09:01:30.686126Z 0 [Note] - '127.0.0.1' resolves to '127.0.0.1';
2020-02-05T09:01:30.686157Z 0 [Note] Server socket created on IP: '127.0.0.1'.
2020-02-05T09:01:30.694482Z 0 [Note] Event Scheduler: Loaded 0 events
2020-02-05T09:01:30.694676Z 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '5.7.29-0ubuntu0.18.04.1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Ubuntu)
2020-02-05T09:03:19.040204Z 3 [Note] Access denied for user 'newuser'@'localhost' (using password: YES)
der ist vom apache
[Wed Feb 05 09:55:44.533374 2020] [mpm_event:notice] [pid 1450:tid 139902248135616] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 09:55:44.533483 2020] [core:notice] [pid 1450:tid 139902248135616] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 10:00:30.170878 2020] [mpm_event:notice] [pid 1450:tid 139902248135616] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 10:00:30.224354 2020] [mpm_event:notice] [pid 2526:tid 139815489989568] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 10:00:30.224447 2020] [core:notice] [pid 2526:tid 139815489989568] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 10:04:41.434222 2020] [mpm_event:notice] [pid 2526:tid 139815489989568] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 10:04:41.495250 2020] [mpm_event:notice] [pid 9496:tid 139928682388416] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 10:04:41.495357 2020] [core:notice] [pid 9496:tid 139928682388416] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 10:25:32.416364 2020] [mpm_event:notice] [pid 9496:tid 139928682388416] AH00493: SIGUSR1 received. Doing graceful restart
[Wed Feb 05 10:25:32.421335 2020] [mpm_event:notice] [pid 9496:tid 139928682388416] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 10:25:32.421347 2020] [core:notice] [pid 9496:tid 139928682388416] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 10:53:48.468592 2020] [mpm_event:notice] [pid 9496:tid 139928682388416] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 10:53:48.526608 2020] [mpm_event:notice] [pid 11568:tid 140238807354304] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 10:53:48.526715 2020] [core:notice] [pid 11568:tid 140238807354304] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 11:00:36.750726 2020] [auth_basic:error] [pid 11569:tid 140238584272640] [client 193.159.182.179:19835] AH01618: user not found: /phpmyadmin/
[Wed Feb 05 11:00:55.810859 2020] [auth_basic:error] [pid 11569:tid 140238575879936] [client 195.135.184.109:55572] AH01618: user root not found: /phpmyadmin/
[Wed Feb 05 11:01:01.152630 2020] [auth_basic:error] [pid 11569:tid 140238550701824] [client 195.135.184.109:55573] AH01618: user mysql not found: /phpmyadmin/
[Wed Feb 05 11:20:14.261857 2020] [mpm_event:notice] [pid 11568:tid 140238807354304] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 11:20:14.313720 2020] [mpm_event:notice] [pid 12585:tid 140357619637184] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 11:20:14.313829 2020] [core:notice] [pid 12585:tid 140357619637184] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 13:44:08.464516 2020] [mpm_event:notice] [pid 12585:tid 140357619637184] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 13:44:08.524810 2020] [mpm_event:notice] [pid 13041:tid 139865196223424] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 13:44:08.524915 2020] [core:notice] [pid 13041:tid 139865196223424] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 13:51:56.993323 2020] [mpm_event:notice] [pid 13041:tid 139865196223424] AH00493: SIGUSR1 received. Doing graceful restart
[Wed Feb 05 13:51:56.998428 2020] [mpm_event:notice] [pid 13041:tid 139865196223424] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 13:51:56.998445 2020] [core:notice] [pid 13041:tid 139865196223424] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 05 14:13:58.318017 2020] [mpm_event:notice] [pid 13041:tid 139865196223424] AH00491: caught SIGTERM, shutting down
[Wed Feb 05 14:13:58.371919 2020] [mpm_event:notice] [pid 13295:tid 139789020150720] AH00489: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
[Wed Feb 05 14:13:58.372016 2020] [core:notice] [pid 13295:tid 139789020150720] AH00094: Command line: '/usr/sbin/apache2'
