# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_use_tls = yes
# SPAM parameters
postscreen_bare_newline_action = enforce
postscreen_bare_newline_enable = yes
postscreen_dnsbl_action = enforce
postscreen_dnsbl_sites =
list.dnswl.org=127.0.[0..255].0*-2
list.dnswl.org=127.0.[0..255].1*-4
list.dnswl.org=127.0.[0..255].2*-6
list.dnswl.org=127.0.[0..255].3*-8
zen.spamhaus.org=127.0.0.9*25
zen.spamhaus.org=127.0.0.3*10
zen.spamhaus.org=127.0.0.2*5
zen.spamhaus.org=127.0.0.[4..7]*3
zen.spamhaus.org=127.0.0.[10..11]*3
swl.spamhaus.org*-10
bl.mailspike.net=127.0.0.2*10
bl.mailspike.net=127.0.0.10*5
bl.mailspike.net=127.0.0.11*4
bl.mailspike.net=127.0.0.12*3
bl.mailspike.net=127.0.0.13*2
bl.mailspike.net=127.0.0.14*1
wl.mailspike.net=127.0.0.16*-2
wl.mailspike.net=127.0.0.17*-4
wl.mailspike.net=127.0.0.18*-6
wl.mailspike.net=127.0.0.19*-8
wl.mailspike.net=127.0.0.20*-10
backscatter.spameatingmonkey.net*2
bl.ipv6.spameatingmonkey.net*2
bl.spameatingmonkey.net*2
ix.dnsbl.manitu.net*2
bl.spamcop.net*2
db.wpbl.info*2
psbl.surriel.com*2
torexit.dan.me.uk*2
tor.dan.me.uk*1
safe.dnsbl.sorbs.net*1
postscreen_dnsbl_threshold = 5
postscreen_dnsbl_whitelist_threshold = 0
postscreen_greet_action = enforce
postscreen_non_smtp_command_enable = yes
postscreen_pipelining_enable = yes
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = mail.sfnetworks.de
mydestination = *****.******.de, localhost.******.de, localhost, localhost.localdomain
relayhost =
mynetworks =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
mailman_destination_recipient_limit = 1
inet_protocols = all
virtual_mailbox_maps = , hash:/var/spool/postfix/plesk/vmailbox
transport_maps = , hash:/var/spool/postfix/plesk/transport
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
virtual_uid_maps = static:30
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768 inet:127.0.0.1:12345
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
virtual_mailbox_limit = 0
smtpd_tls_ciphers = medium
smtpd_tls_mandatory_ciphers = medium
tls_medium_cipherlist = HIGH:!aNULL:!MD5
smtpd_tls_mandatory_protocols = TLSv1 TLSv1.1 TLSv1.2
smtpd_tls_protocols = TLSv1 TLSv1.1 TLSv1.2
message_size_limit = 20480000
milter_connect_macros = j {daemon_name} {client_connections} {client_addr} {client_ptr} v
milter_default_action = accept
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
#smtp inet n - - - - smtpd
smtp inet n - - - 1 postscreen
smtpd pass - - - - - smtpd
dnsblog unix - - - - 0 dnsblog
tlsproxy unix - - - - 0 tlsproxy
submission inet n - - - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_reject_unlisted_recipient=no
# -o smtpd_client_restrictions=$mua_client_restrictions
# -o smtpd_helo_restrictions=$mua_helo_restrictions
# -o smtpd_sender_restrictions=$mua_sender_restrictions
# -o smtpd_recipient_restrictions=
# -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
# -o syslog_name=postfix/smtps
# -o smtpd_tls_wrappermode=yes
# -o milter_macro_daemon_name=ORIGINATING
#628 inet n - - - - qmqpd
cleanup unix n - - - 0 cleanup
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
# agent. See the pipe(8) man page for information about ${recipient}
maildrop unix - n n - - pipe
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
uucp unix - n n - - pipe
ifmail unix - n n - - pipe
bsmtp unix - n n - - pipe
scalemail-backend unix - n n - 2 pipe
mailman unix - n n - - pipe flags=R user=list:list argv=/usr/lib/plesk-9.0/postfix-mailman ${nexthop} ${user} ${recipient}
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames
pickup fifo n - - 60 1 pickup
qmgr fifo n - n 1 1 qmgr
smtps inet n - - - - smtpd -o smtpd_tls_wrappermode=yes
plesk_saslauthd unix y y y - 1 plesk_saslauthd status=5 listen=6 dbpath=/plesk/passwd.db
submission inet n - - - - smtpd -o smtpd_enforce_tls=yes -o smtpd_tls_security_level=encrypt -o smtpd_sasl_auth_enable=yes -o smtpd_client_restrictions=permit_sasl_authenticated,reject -o smtpd_sender_restrictions= -o smtpd_recipient_restrictions=permit_mynetworks,permit_sasl_authenticated,reject_unauth_destination
plesk-**.**.**.**- unix - n n - - smtp -o smtp_bind_address=**.**.**.** -o smtp_bind_address6= -o smtp_address_preference=ipv4
Jun 5 15:19:06 ***** postfix/master[5343]: terminating on signal 15
Jun 5 15:19:06 ***** postfix/postscreen[5390]: close database /var/lib/postfix/postscreen_cache.db: No such file or directory (possible Berkeley DB bug)
Jun 5 15:23:33 ***** postfix/dnsblog[5800]: addr 89.1.8.213 listed by domain list.dnswl.org as 127.0.5.1
Jun 5 15:27:18 ***** postfix/dnsblog[5855]: addr 17.139.149.167 listed by domain list.dnswl.org as 127.0.5.1
Jun 5 15:27:18 ***** postfix/dnsblog[5863]: addr 17.139.149.167 listed by domain wl.mailspike.net as 127.0.0.17
Ich hab kein Plan von Autos, also was mache ich? Ich fahre in einer Werkstatt und lasse machen... Von Leuten die Plan davon haben!
