Rookie79
Ich habe rkhunter 1.2.9-2 folgendermaßen installiert
Nun haben sich folgende Probleme ergeben:
1. Anacron Mail
2. rkhunter Mail
Was heißt das? Wie kann ich die Fehler beheben?
apt-get install rkhunter
1. Anacron Mail
/etc/cron.daily/rkhunter:
lsmod: QM_MODULES: Function not implemented
2. rkhunter Mail
Determining OS... Warning: This operating system is not fully supported!
Checking for allowed protocols... [ Warning ]
Found warnings:
[20:17:57] Warning: This operating system is not fully supported!
If you're unsure about the results above, please contact the Rootkit Hunter team through the Rootkit Hunter mailinglist at rkhunter-users@lists.sourceforge.net.
Some errors has been found while checking. Please perform a manual check on this machine (XXXXX.XXXXX.tld)
