USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 664 280 ? Ss 20:48 0:00 init
100 30312 0.0 0.0 15080 1628 ? Ss 20:48 0:00 /usr/bin/dbus-daemon --system
root 30601 0.0 0.0 3592 692 ? Ss 20:48 0:00 /sbin/syslogd -a /var/lib/named/dev/log
root 30612 0.0 0.0 19824 1504 ? Ss 20:48 0:00 /usr/sbin/saslauthd -n 2 -a pam
root 30632 0.0 0.0 19824 1504 ? S 20:48 0:00 /usr/sbin/saslauthd -n 2 -a pam
root 30638 0.0 0.0 9180 1124 ? S 20:48 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=imapd -maxprocs=40 -maxperip=4 -pid=/var/run/imapd.pid -nodnslookup -noidentlookup 143 /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root 30641 0.0 0.0 6904 884 ? S 20:48 0:00 /usr/sbin/courierlogger imapd
root 30650 0.0 0.0 9180 1124 ? S 20:48 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=imapd-ssl -maxprocs=40 -maxperip=4 -pid=/var/run/imapd-ssl.pid -nodnslookup -noidentlookup 993 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root 30652 0.0 0.0 6904 884 ? S 20:48 0:00 /usr/sbin/courierlogger imapd-ssl
root 30660 0.0 0.0 9180 1124 ? S 20:48 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=pop3d -maxprocs=40 -maxperip=4 -pid=/var/run/pop3d.pid -nodnslookup -noidentlookup 110 /usr/sbin/pop3login /usr/lib/courier-imap/authlib/authpsa /usr/bin/pop3d Maildir
root 30666 0.0 0.0 6904 884 ? S 20:48 0:00 /usr/sbin/courierlogger pop3d
root 30679 0.0 0.0 9180 1124 ? S 20:48 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=pop3d-ssl -maxprocs=40 -maxperip=4 -pid=/var/run/pop3d-ssl.pid -nodnslookup -noidentlookup 995 /usr/bin/couriertls -server -tcpd /usr/sbin/pop3login /usr/lib/courier-imap/authlib/authpsa /usr/bin/pop3d Maildir
root 30682 0.0 0.0 6904 884 ? S 20:48 0:00 /usr/sbin/courierlogger pop3d-ssl
root 30692 0.0 0.0 28652 2364 ? Ss 20:48 0:00 /usr/sbin/sshd -o PidFile=/var/run/sshd.init.pid
root 30703 0.0 0.0 10624 1016 ? Ss 20:48 0:00 /usr/sbin/xinetd
named 31835 0.0 0.0 51848 4116 ? Ssl 20:48 0:00 /usr/sbin/named -t /var/lib/named -u named
root 31858 0.0 0.0 7844 1452 ? S 20:48 0:00 /bin/sh /usr/bin/mysqld_safe --user=mysql --pid-file=/var/lib/mysql/mysqld.pid --socket=/var/lib/mysql/mysql.sock --datadir=/var/lib/mysql
mysql 31912 0.0 0.1 107120 16504 ? Sl 20:48 0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/lib/mysql/mysqld.pid --skip-locking --port=3306 --socket=/var/lib/mysql/mysql.sock
root 31983 0.0 0.2 66804 39476 ? Ss 20:48 0:01 /usr/sbin/spamd --username=popuser --daemonize --nouser-config --helper-home-dir=/var/qmail --max-children 1 --create-prefs --virtual-config-dir=/var/qmail/mailnames/%d/%l/.spamassassin --pidfile=/var/run/spamd/spamd_full.pid --socketpath=/tmp/spamd_full.sock
popuser 31984 0.0 0.2 66804 39484 ? S 20:48 0:00 spamd child
root 32029 0.0 0.1 184436 22316 ? Ss 20:48 0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
root 32088 0.0 0.0 75580 6740 ? Ss 20:48 0:00 /usr/local/psa/admin/bin/httpsd
psaadm 32092 0.0 0.2 87840 34644 ? S 20:48 0:01 /usr/local/psa/admin/bin/httpsd
root 32213 0.0 0.0 9952 808 ? Ss 20:48 0:00 /usr/sbin/cron
psaadm 32249 0.0 0.2 89332 36032 ? S 20:48 0:03 /usr/local/psa/admin/bin/httpsd
drweb 32256 0.0 0.0 16372 14376 ? Ss 20:48 0:00 /opt/drweb/drwebd -ini=/etc/drweb/drweb32.ini
psaadm 26035 0.2 0.2 85868 35564 ? S 21:51 0:01 /usr/local/psa/admin/bin/httpsd
qmails 29770 0.0 0.0 2544 420 ? S 21:57 0:00 qmail-send
qmaill 29771 0.0 0.0 2492 488 ? S 21:57 0:00 splogger qmail
root 29773 0.0 0.0 2532 400 ? S 21:57 0:00 qmail-lspawn ./Maildir/
qmailr 29774 0.0 0.0 2532 416 ? S 21:57 0:00 qmail-rspawn
qmailq 29775 0.0 0.0 2488 372 ? S 21:57 0:00 qmail-clean
wwwrun 30133 0.0 0.1 184436 22316 ? S 21:57 0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf
root 5559 0.0 0.0 48972 3164 ? Ss 22:02 0:00 sshd: root@pts/0
root 5582 0.0 0.0 12568 2192 pts/0 Ss 22:02 0:00 -bash
markus 7259 0.2 0.0 29544 3312 ? Ss 22:04 0:00 proftpd: markus - 84.155.117.7: IDLE
root 7603 0.0 0.0 7608 912 pts/0 R+ 22:05 0:00 ps aux
