Problem mit Dovecot & Postfix
freenewbie
Ich habe eine Frage zum Thema Email versenden und empfangen undzwar habe ich Postfix und Dovecot auf (Ubuntu Linux 8.04.3) installiert.
Ich kann Emails vom VServer versenden und auch empfangen nur gibt es ein Problem mit dem Outlook Express ich kann keine Emails abrufen und versenden wodran könnte es liegen ?
Ich poste mal die main.cf Konfiguarationsda*
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
recipient_delimiter = +
readme_directory = no
#delay_warning_time = 4h
mydomain = domain.tld
myhostname = mail.domain.tld
myorigin = $mydomain
mydestination = localhost, $mydomain
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
virtual_mailbox_domains = /etc/postfix/virtual_domains
virtual_mailbox_base = /var/mail/vhosts
virtual_mailbox_maps = hash:/etc/postfix/vmailbox
virtual_alias_maps = hash:/etc/postfix/virtual_alias
virtual_minimum_uid = 100
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
virtual_transport = dovecot
dovecot_destination_recipient_limit = 1
mailbox_size_limit = 0
smtpd_sasl_auth_enable = yes
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
smtpd_sasl_local_domain = $mydomain
smtpd_use_tls=yes
smtpd_tls_auth_only = no
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_received_header = yes
tls_random_source = dev:/dev/urandom
smtpd_require_helo = yes
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_invalid_hostname,  reject_unknown_client, reject_rbl_client sbl-xbl.spamhaus.org
smtpd_sender_restrictions = permit_mynetworks, reject_unknown_address, reject_unknown_sender_domain, reject_non_fqdn_sender
smtpd_recipient_limit = 250
mail.domain.tld
[email protected]     /var/mail/domain.tld/mail/
So alle virtuelle aktualisiert mittels postmap /etc/postfix/..
etc/dovecot/dovecot.conf in Kurzfassung
protocols = imap pop3 imaps pop3s
log_path = /var/log/dovecot
ssl_listen =
ssl_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
ssl_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
mail_location = maildir:/var/mail/vhosts/%d/%n
mail_privileged_group = mail
pop3_uidl_format = %08Xu%08Xv
protocol lda {
  postmaster_address = [email protected]
  auth_socket_path = /var/run/dovecot/auth-master
  mail_plugin_dir = /usr/lib/dovecot/modules/lda
  mail_plugins = cmusieve
auth default {
  mechanisms = plain login
  userdb passwd-file {
    args = /var/mail/vhosts/%d/passwd
  passdb passwd-file {
    args = /var/mail/vhosts/%d/shadow
  socket listen {
    client {
      path = /var/spool/postfix/private/auth
      mode = 0660
      user = postfix
      group = vmail
    master {
      mode = 0600
      user = vmail
      group = vmail
Die dovecot logdatei gibt mir beim versuch über outlook sich einzuloggen folgendes aus
Info: pop3-login: Disconnected: rip=xx.xx.xx.89, lip=xx.xx.xx.167
Outlook teilt mir beim Senden und Empfangen folgendes mit
Die Serveranmeldung mit Kennwortauthentifizierung ist fehlgeschlagen. Konto: '', Server: '', Protokoll: POP3, Serverantwort: '.', Port: 110, Secure (SSL): Nein, Fehlernummer: 0x800CCC18
Damit es auch gleich nicht zu aktiven Spam missbrauch kommt habe ich die ip und domainnamen geändert.
Ich würde mich auf eure Rückantworten freuen.
