Hallo zusammen
bin hier am verzweifeln mit dem Dns Server Bind er will einfach nicht starten
mein server ist Debian 4 ( Etch )
mein error.log
der bericht vom update:
was stimmt das nicht am anfang lief alles und seitdem update zu 8.6.0 läuft der Dns Server ( Bind ) nicht mehr
danke und gruss
mein error.log
[Mon Sep 08 15:06:55 2008] [warn] Init: Session Cache is not configured [hint: SSLSessionCache]
[Mon Sep 08 15:06:55 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Mon Sep 08 15:06:55 2008] [warn] Init: SSL server IP/port conflict: default-Server IP:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:80) vs. webmail:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:135)
[Mon Sep 08 15:06:55 2008] [warn] Init: SSL server IP/port conflict: meine domain:443 (/var/www/vhosts/meine Domain/conf/httpd.include:12) vs. webmail:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:135)
[Mon Sep 08 15:06:55 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Mon Sep 08 15:06:55 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Mon Sep 08 15:06:56 2008] [warn] RSA server certificate CommonName (CN) `plesk' does NOT match server name!?
[Mon Sep 08 15:06:56 2008] [warn] Init: SSL server IP/port conflict: default-Server IP:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:80) vs. webmail:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:135)
[Mon Sep 08 15:06:56 2008] [warn] Init: SSL server IP/port conflict: meine domain:443 (/var/www/vhosts/meine domain/conf/httpd.include:12) vs. webmail:443 (/etc/apache2/conf.d/zz010_psa_httpd.conf:135)
[Mon Sep 08 15:06:56 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Mon Sep 08 15:06:56 2008] [notice] Apache/2.2.3 (Debian) PHP/4.4.4-8+etch6 mod_ssl/2.2.3 OpenSSL/0.9.8c mod_perl/2.0.2 Perl/v5.8.8 configured -- resuming normal operations
Autoinstaller 3.3.2 (build at 2008-07-10 09:35 svn rev. 0) started at (timezone UTC) Mon Sep 8 12:49:56 2008Command line args: /opt/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/root/psa --select-release-id=PLESK_8_6_0 --notify-email=lui20045@hotmail.de --install-component=base --install-component=de-DE-locale Try to find rcfile...Autoinstaller rcfile not found.Checking hostname is sucessfull.Opsys detected as: os_name=Linux os_vendor=Debian version=4.0 arch=i686 environment=vzFinal opsys (with overriding) is: os_name=Linux os_vendor=Debian version=4.0 arch=i686 environment=vzDownloading the file products.inf3: 100% done.Downloading the file plesk.inf3: 12%..21%..58%..60%..72%..81%..90%..100% done.Downloading the file sitebuilder.inf3: 10%..21%..36%..43%..50%..61%..72%..83%..90%..100% done.Downloading the file sso.inf3: 13%..26%..40%..53%..67%..80%..93%..100% done.repository: Get brief packages info for all sourcesChecking for installed packages... DebRepository: readSystemPackagesBrief: execute dpkg-query --show '--showformat=s:${Status}\nF:${Package}_installed.deb\nN:${Package}\nV:${Version}\nA:${Architecture}\nX:\n'| awk '/^s:install ok/,/^X:/ { print $0}'| grep -v '^s:' Downloading the file PSA_8.6.0/plesk-8.6.0-deb4.0-i386.inf3: 11%..22%..31%..42%..50%..62%..70%..81%..90%..100% done.No removers section in this build.No preferrers section in this build.Virtuozzo was detected. Trying to connect to VZAgent...Warning! Failed to connect to VZAgent: open: No such file or directoryadd line 'deb http://autoinstall.plesk.com/debian/PSA_8.6.0 etch all' to source.listIgn http://autoinstall.plesk.com etch Release.gpgIgn http://autoinstall.plesk.com etch Release.gpgIgn http://autoinstall.plesk.com etch ReleaseGet:1 http://security.debian.org etch/updates Release.gpg [189B]Get:2 http://ftp.se.debian.org etch Release.gpg [386B]Ign http://autoinstall.plesk.com etch ReleaseIgn http://autoinstall.plesk.com etch/all Packages/DiffIndexHit http://security.debian.org etch/updates ReleaseHit http://ftp.se.debian.org etch ReleaseIgn http://autoinstall.plesk.com etch/all Packages/DiffIndexHit http://autoinstall.plesk.com etch/all PackagesIgn http://security.debian.org etch/updates/main Packages/DiffIndexIgn http://ftp.se.debian.org etch/main Packages/DiffIndexHit http://autoinstall.plesk.com etch/all PackagesIgn http://security.debian.org etch/updates/contrib Packages/DiffIndexIgn http://ftp.se.debian.org etch/contrib Packages/DiffIndexIgn http://ftp.se.debian.org etch/main Sources/DiffIndexIgn http://ftp.se.debian.org etch/contrib Sources/DiffIndexHit http://security.debian.org etch/updates/main PackagesHit http://ftp.se.debian.org etch/main PackagesHit http://security.debian.org etch/updates/contrib PackagesHit http://ftp.se.debian.org etch/contrib PackagesHit http://ftp.se.debian.org etch/main SourcesHit http://ftp.se.debian.org etch/contrib SourcesFetched 2B in 1s (2B/s)Reading package lists...Warning: not connected 'non-free' repository sectionrepository: Get brief packages info for all sourcesDetecting installed product components.Component plesk/base: mode up2date, installed=1219435200, available=1219410000Component plesk/base have no older version, so keyupdate not neededComponent plesk/psa-autoinstaller: mode up2date, installed=0, available=0Component plesk/postgresql: mode install, installed=0, available=0Component plesk/vault: mode install, installed=0, available=1216663200Component plesk/docs: mode install, installed=0, available=1216663200Component plesk/ppwse: mode install, installed=0, available=1216663200Component plesk/api: mode install, installed=0, available=1219410000Component plesk/pmm: mode install, installed=0, available=1219410000Component plesk/sb-publish: mode install, installed=0, available=0Component plesk/sbm: mode install, installed=0, available=0Component plesk/cf-support: mode install, installed=0, available=1216663200Component plesk/miva: mode install, installed=0, available=1216663200Component plesk/billing: mode install, installed=0, available=0Component plesk/nl-NL-locale: mode install, installed=0, available=1217923200Component plesk/mod-bw: mode install, installed=0, available=0Component plesk/asp: mode install, installed=0, available=0Component plesk/java: mode install, installed=0, available=1216663200Component plesk/mod_python: mode install, installed=0, available=0Component plesk/ruby: mode install, installed=0, available=1216663200Component plesk/fcgi: mode install, installed=0, available=0Component plesk/php4: mode install, installed=0, available=0Component plesk/php5: mode install, installed=0, available=0Component plesk/psa-firewall: mode install, installed=0, available=1216663200Component plesk/psa-vpn: mode install, installed=0, available=1216663200Component plesk/psa-fileserver: mode install, installed=0, available=1216663200Component plesk/sshterm: mode install, installed=0, available=1216663200Component plesk/watchdog: mode install, installed=0, available=1216663200Component plesk/cs-gs: mode install, installed=0, available=1216663200Component plesk/battlefield: mode install, installed=0, available=1216663200Component plesk/bf2: mode install, installed=0, available=1216663200Component plesk/mailman: mode install, installed=0, available=1216663200Component plesk/kav: mode install, installed=0, available=1216663200Component plesk/drweb: mode install, installed=0, available=1216663200Component plesk/spamassassin: mode install, installed=0, available=1216663200Component plesk/rblsmtpd: mode install, installed=0, available=1216663200Component plesk/backup-vz: mode install, installed=0, available=1219410000Component plesk/de-DE-locale: mode install, installed=0, available=1217923200Component plesk/ja-JP-locale: mode install, installed=0, available=1216191600Component plesk/es-ES-locale: mode install, installed=0, available=1216191600Component plesk/ru-RU-locale: mode install, installed=0, available=1216191600Component plesk/fr-FR-locale: mode install, installed=0, available=1216191600Component plesk/it-IT-locale: mode install, installed=0, available=1216191600Component plesk/zh-CN-locale: mode install, installed=0, available=1216191600Component plesk/zh-TW-locale: mode install, installed=0, available=1216191600KeyUpdateChecker::doCheck: no components for check key updateChecking whether the package dependencies are resolved.Check package set before installationInstalling packagesReading package lists...Building dependency tree...psa-imp is already the newest version.psa-ingo is already the newest version.psa-kronolith is already the newest version.psa-mimp is already the newest version.psa-mnemo is already the newest version.psa-passwd is already the newest version.psa-turba is already the newest version.The following NEW packages will be installed:psa-locale-de-de0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.7 not fully installed or removed.Need to get 1940kB of archives.After unpacking 9572kB of additional disk space will be used.WARNING: The following packages cannot be authenticated!psa-locale-de-deAuthentication warning overridden.Get:1 http://autoinstall.plesk.com etch/all psa-locale-de-de 8.6-build86080805.15 [1940kB]Fetched 1940kB in 0s (2587kB/s)Selecting previously deselected package psa-locale-de-de.(Reading database ... 38508 files and directories currently installed.)Unpacking psa-locale-de-de (from .../psa-locale-de-de_8.6-build86080805.15_all.deb) ...Setting up psa-imp (4.1.6-debian4.0.build86080722.01) ...Trying to start MySQL server... Trying to establish test connection... connecteddone Setting up psa-ingo (1.1.5-debian4.0.build86080722.01) ... Setting up psa-kronolith (2.1.8-debian4.0.build86080722.01) ...Trying to start MySQL server... Trying to establish test connection... connecteddoneTrying to install kronolith database... ERROR while trying to Unable to install kronolith database, see psa log for detailsCheck the error reason(see log file: /tmp/kronolith_8.6.0_debian4.0.build86080722.01_installing.080908.12.50.log), fix and try again Aborting... dpkg: error processing psa-kronolith (--configure):subprocess post-installation script returned error exit status 1Setting up psa-mimp (1.0.2-debian4.0.build86080722.01) ...Setting up psa-mnemo (2.1.2-debian4.0.build86080722.01) ...Trying to start MySQL server... Trying to establish test connection... connecteddoneTrying to install mnemo database... ERROR while trying to Unable to install mnemo database, see psa log for detailsCheck the error reason(see log file: /tmp/mnemo_8.6.0_debian4.0.build86080722.01_installing.080908.12.50.log), fix and try again Aborting... dpkg: error processing psa-mnemo (--configure):subprocess post-installation script returned error exit status 1Setting up psa-passwd (3.0.1-debian4.0.build86080722.01) ...Setting up psa-turba (2.1.7-debian4.0.build86080722.01) ...Trying to start MySQL server... Trying to establish test connection... connecteddoneTrying to install turba database... ERROR while trying to Unable to install turba database, see psa log for detailsCheck the error reason(see log file: /tmp/turba_8.6.0_debian4.0.build86080722.01_installing.080908.12.50.log), fix and try again Aborting... dpkg: error processing psa-turba (--configure):subprocess post-installation script returned error exit status 1Setting up psa-locale-de-de (8.6-build86080805.15) ...Trying to start MySQL server... Trying to establish test connection... connecteddone Errors were encountered while processing:psa-kronolithpsa-mnemopsa-turbaE: Sub-process /usr/bin/dpkg returned an error code (1)Ign http://autoinstall.plesk.com etch Release.gpgIgn http://autoinstall.plesk.com etch ReleaseIgn http://autoinstall.plesk.com etch/all Packages/DiffIndexGet:1 http://security.debian.org etch/updates Release.gpg [189B]Get:2 http://ftp.se.debian.org etch Release.gpg [386B]Hit http://autoinstall.plesk.com etch/all PackagesHit http://security.debian.org etch/updates ReleaseHit http://ftp.se.debian.org etch ReleaseIgn http://security.debian.org etch/updates/main Packages/DiffIndexIgn http://ftp.se.debian.org etch/main Packages/DiffIndexIgn http://security.debian.org etch/updates/contrib Packages/DiffIndexIgn http://ftp.se.debian.org etch/contrib Packages/DiffIndexIgn http://ftp.se.debian.org etch/main Sources/DiffIndexIgn http://ftp.se.debian.org etch/contrib Sources/DiffIndexHit http://security.debian.org etch/updates/main PackagesHit http://ftp.se.debian.org etch/main PackagesHit http://security.debian.org etch/updates/contrib PackagesHit http://ftp.se.debian.org etch/contrib PackagesHit http://ftp.se.debian.org etch/main SourcesHit http://ftp.se.debian.org etch/contrib SourcesFetched 2B in 1s (2B/s)Reading package lists...ERROR: An error occurred on attempt to install packages.Attention! Your software might be inoperable.
danke und gruss
