Postfix, Confixx, Problem...
afro
Hier mein Problem:
Ich kann keine E-Mail empfangen und keine E-Mail senden...
Meine main.cf
#See /usr/share/postfix/main.cf.dist for a commented, more complete version
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP Mailserver
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
myhostname = pv288.ncsrv.de
myorigin = $myhostname
mydestination = $myhostname, localhost.$mydomain, $mydomain
#mydestination = hash:/etc/postfix/confixx_localDomains
relayhost =
mynetworks = 127.0.0.0/8
mailbox_command = procmail
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
smtpd_helo_required = yes
smtpd_helo_restrictions = reject_invalid_hostname
smtpd_sasl_local_domain =
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, reject_unknown_recipient_domain, permit_sasl_authenticated, reject_unauth_destination
smtpd_sender_restrictions = reject_unknown_address
#smtpd_sasl_type = dovecot
#smtpd_sasl_path = private/auth
smtp_sasl_auth_enable = no
#smtp_sasl_password_maps = hash:/etc/passwd
### CONFIXX POSTFIX ENTRY ###
readme_directory = no
sample_directory = /etc/postfix
html_directory = no
setgid_group = postdrop
command_directory = /usr/sbin
manpage_directory = /usr/local/man
daemon_directory = /usr/libexec/postfix
mailq_path = /usr/bin/mailq
mail_owner = postfix
data_directory = /var/lib/postfix
und meine master.cf
smtp      inet  n       -       -       -       -       smtpd -o pam
587       inet  n       -       -       -       -       smtpd -o pam
#submission inet n       -       -       -       -       smtpd
#  -o smtpd_enforce_tls=yes
#  -o smtpd_client_restrictions=permit_sasl_authenticated,reject
#smtps     inet  n       -       -       -       -       smtpd
#  -o smtpd_tls_wrappermode=yes
#628      inet  n       -       -       -       -       qmqpd
pickup    fifo  n       -       -       60      1       pickup
#qmgr     fifo  n       -       -       300     1       oqmgr
	-o fallback_relay=
scache	  unix	-	-	-	-	1	scache
# agent.  See the pipe(8) man page for information about ${recipient}
#spamassassin unix - n n - - pipe user=nobody argv=/usr/bin/spamc -e /usr/sbin/sendmail -oi -f ${sender} ${recipient}
scalemail-backend unix	-	n	n	-	2	pipe
mailman   unix  -       n       n       -       -       pipe
  ${nexthop} ${user}
retry     unix  -       -       n       -       -       error
dann nochmal saslfinger:
System: Debian GNU/Linux 3.1 \n \l
-- smtp is linked to --
-- active SMTP AUTH and TLS parameters for smtp --
relayhost =
-- listing of /usr/lib/sasl2 --
total 743
drwxr-xr-x   2 root  root   2048 Sep 10 21:18 .
drwxr-xr-x  52 root  root  13312 Sep 10 19:33 ..
-rw-r-----   1 smmta smmsp   743 Sep 10 19:21 Sendmail.conf
-rw-r--r--   1 root  root  13304 Dec 13  2006 libanonymous.a
-rw-r--r--   1 root  root    855 Dec 13  2006 libanonymous.la
-rw-r--r--   1 root  root  12844 Dec 13  2006 libanonymous.so
-rw-r--r--   1 root  root  12844 Dec 13  2006 libanonymous.so.2
-rw-r--r--   1 root  root  12844 Dec 13  2006 libanonymous.so.2.0.22
-rw-r--r--   1 root  root  15502 Dec 13  2006 libcrammd5.a
-rw-r--r--   1 root  root    841 Dec 13  2006 libcrammd5.la
-rw-r--r--   1 root  root  15052 Dec 13  2006 libcrammd5.so
-rw-r--r--   1 root  root  15052 Dec 13  2006 libcrammd5.so.2
-rw-r--r--   1 root  root  15052 Dec 13  2006 libcrammd5.so.2.0.22
-rw-r--r--   1 root  root  46320 Dec 13  2006 libdigestmd5.a
-rw-r--r--   1 root  root    864 Dec 13  2006 libdigestmd5.la
-rw-r--r--   1 root  root  43040 Dec 13  2006 libdigestmd5.so
-rw-r--r--   1 root  root  43040 Dec 13  2006 libdigestmd5.so.2
-rw-r--r--   1 root  root  43040 Dec 13  2006 libdigestmd5.so.2.0.22
-rw-r--r--   1 root  root  13482 Dec 13  2006 liblogin.a
-rw-r--r--   1 root  root    835 Dec 13  2006 liblogin.la
-rw-r--r--   1 root  root  13384 Dec 13  2006 liblogin.so
-rw-r--r--   1 root  root  13384 Dec 13  2006 liblogin.so.2
-rw-r--r--   1 root  root  13384 Dec 13  2006 liblogin.so.2.0.22
-rw-r--r--   1 root  root  29300 Dec 13  2006 libntlm.a
-rw-r--r--   1 root  root    829 Dec 13  2006 libntlm.la
-rw-r--r--   1 root  root  28776 Dec 13  2006 libntlm.so
-rw-r--r--   1 root  root  28776 Dec 13  2006 libntlm.so.2
-rw-r--r--   1 root  root  28776 Dec 13  2006 libntlm.so.2.0.22
-rw-r--r--   1 root  root  13818 Dec 13  2006 libplain.a
-rw-r--r--   1 root  root    835 Dec 13  2006 libplain.la
-rw-r--r--   1 root  root  13992 Dec 13  2006 libplain.so
-rw-r--r--   1 root  root  13992 Dec 13  2006 libplain.so.2
-rw-r--r--   1 root  root  13992 Dec 13  2006 libplain.so.2.0.22
-rw-r--r--   1 root  root  21726 Dec 13  2006 libsasldb.a
-rw-r--r--   1 root  root    856 Dec 13  2006 libsasldb.la
-rw-r--r--   1 root  root  17980 Dec 13  2006 libsasldb.so
-rw-r--r--   1 root  root  17980 Dec 13  2006 libsasldb.so.2
-rw-r--r--   1 root  root  17980 Dec 13  2006 libsasldb.so.2.0.22
-rw-r--r--   1 root  root  23576 Dec 13  2006 libsql.a
-rw-r--r--   1 root  root    964 Dec 13  2006 libsql.la
-rw-r--r--   1 root  root  23072 Dec 13  2006 libsql.so
-rw-r--r--   1 root  root  23072 Dec 13  2006 libsql.so.2
-rw-r--r--   1 root  root  23072 Dec 13  2006 libsql.so.2.0.22
-rw-r-----   1 root  root    702 Sep 10 21:18 saslpasswd.conf
Cannot find the smtp_sasl_password_maps parameter in main.cf.
Client-side SMTP AUTH cannot work without this parameter!
achja, hier noch die log:
Sep 10 21:40:54 pv288 postfix/master[14074]: reload configuration /etc/postfix
Sep 10 21:41:10 pv288 postfix/smtpd[14317]: warning: SASL: Connect to smtpd failed: No such file or directory
Sep 10 21:41:10 pv288 postfix/smtpd[14317]: fatal: no SASL authentication mechanisms
Sep 10 21:41:11 pv288 postfix/master[14074]: warning: process /usr/libexec/postfix/smtpd pid 14317 exit status 1
Sep 10 21:41:11 pv288 postfix/master[14074]: warning: /usr/libexec/postfix/smtpd: bad command startup -- throttling
Sep 10 21:42:11 pv288 postfix/smtpd[15868]: warning: SASL: Connect to smtpd failed: No such file or directory
Sep 10 21:42:11 pv288 postfix/smtpd[15868]: fatal: no SASL authentication mechanisms
Sep 10 21:42:12 pv288 postfix/master[14074]: warning: process /usr/libexec/postfix/smtpd pid 15868 exit status 1
Sep 10 21:42:12 pv288 postfix/master[14074]: warning: /usr/libexec/postfix/smtpd: bad command startup -- throttling
ich muss dazusagen, das ich Postfix selber neu kompilieren musste, nachdem ich es deinstalliert hatte. Fragt mich bloß nicht warum ich es deinstalliert habe :D Naja aufjedenfall hab ich es mit Sasl kompiliert...
Hoffe, mir kann jemand helfen...
"Cannot find the smtp_sasl_password_maps parameter in main.cf.
Client-side SMTP AUTH cannot work without this parameter!"
und bei dir in der main.cf auskommentiert? Mal die Raute entfernen!?
ich weiß ja nicht wo die passwortdatei ist, die passwd datei isset schonmal nciht weil er dann eine passwd.db sucht ;)
das war dafür, laut nem Tutorial das sich irgendwas nicht anmelden muss, aber ich hab ja auch schon davor das nicht hinbekommen :-/ Ich guck morgen nochmal und nehme das raus ;)
habs rausgenommen, hilft aber auhc nicht... liegt das vielleicht daran:
Also das nach smtp is linked to nichts steht?
