This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.61. Invocation command line was
$ ./configure
## Platform. ##
hostname = v1942
uname -m = x86_64
uname -r = 2.6.18-028stab053.10
uname -s = Linux
uname -v = #1 SMP Thu Feb 28 19:11:58 MSK 2008
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: //sbin
PATH: //bin
PATH: /sbin
PATH: /usr/sbin
PATH: /usr/local/sbin
PATH: /opt/gnome/sbin
PATH: /root/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /usr/X11R6/bin
PATH: /bin
PATH: /usr/games
PATH: /opt/gnome/bin
PATH: /usr/lib/mit/bin
PATH: /usr/lib/mit/sbin
## Core tests. ##
configure:1836: checking for g++
configure:1866: result: no
configure:1836: checking for c++
configure:1836: checking for gpp
configure:1836: checking for aCC
configure:1836: checking for CC
configure:1836: checking for cxx
configure:1836: checking for cc++
configure:1836: checking for cl.exe
configure:1836: checking for FCC
configure:1836: checking for KCC
configure:1836: checking for RCC
configure:1836: checking for xlC_r
configure:1894: checking for C++ compiler version
configure:1901: g++ --version >&5
./configure: line 1902: g++: command not found
configure:1904: $? = 127
configure:1911: g++ -v >&5
./configure: line 1912: g++: command not found
configure:1914: $? = 127
configure:1921: g++ -V >&5
./configure: line 1922: g++: command not found
configure:1924: $? = 127
configure:1947: checking for C++ compiler default output file name
configure:1974: g++ conftest.cpp >&5
./configure: line 1975: g++: command not found
configure:1977: $? = 127
configure:2015: result:
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:2022: error: C++ compiler cannot create executables
See `config.log' for more details.
## Cache variables. ##
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
## Output variables. ##
APR_CFLAGS=''
APR_LDFLAGS=''
APR_LIBS=''
APR_LINK_LD=''
APU_CFLAGS=''
APU_LDFLAGS=''
APU_LIBS=''
APU_LINK_LD=''
APXS=''
APXS_CC=''
APXS_CFLAGS=''
APXS_EXTRA_CFLAGS=''
APXS_INCLUDEDIR=''
APXS_INCLUDES=''
APXS_LDFLAGS=''
APXS_LIBS=''
APXS_LIBTOOL=''
APXS_WRAPPER=''
CC=''
CFLAGS=''
CPP=''
CPPFLAGS=''
CURL_CFLAGS=''
CURL_LIBS=''
CXX='g++'
CXXFLAGS=''
DEFS=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
EXTRA_CFLAGS=''
GREP=''
INSTALL_DATA=''
INSTALL_PROGRAM=''
INSTALL_SCRIPT=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBXML_CFLAGS=''
LIBXML_LIBS=''
LN_S=''
LTLIBOBJS=''
LUA_CFLAGS=''
LUA_LIBS=''
MODSEC_APXS_EXTRA_CFLAGS=''
MODSEC_EXTRA_CFLAGS=''
OBJEXT=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PCRE_CFLAGS=''
PCRE_LIBS=''
PERL=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
ac_ct_CC=''
ac_ct_CXX=''
bindir='${exec_prefix}/bin'
build_alias=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host_alias=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
configure: exit 77
