Kernel und Update Problem !
Dennisda
Moin,
habe ein Rooti bei Hostway ala firstdedicated.de.
Nutze dort Debian Etch mit diesen Kernel:
Linux server1xxxxxxxx.serverpool.info 2.4.35.3 #1 Mi Nov 7 17:19:02 CET 2007 i686 GNU/Linux
Naja trotzdem muss ja nen Update her, also habe ich erstmal die Source.list abgeändert und dann ein apt-get update durchgeführt, ohne Probleme durchgelaufen. Bei einem apt-get upgrade bekomme ich diese Fehlermeldung:
serverxxxxx:/# apt-get upgrade
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
  locales: Depends: glibc-2.7-1
Wenn ich glibc installiere bekomme ich diese Meldung:
serverXXXXXX:/# apt-get install glibc-2.7-1
Note, selecting libc6 instead of glibc-2.7-1
Suggested packages:
  glibc-doc libc6-i686
The following packages will be upgraded:
  libc6
1 upgraded, 0 newly installed, 0 to remove and 155 not upgraded.
1 not fully installed or removed.
Need to get 0B/4438kB of archives.
After unpacking 5157kB disk space will be freed.
Preconfiguring packages ...
(Reading database ... 19386 files and directories currently installed.)
Preparing to replace libc6 2.3.2.ds1-22 (using .../archives/libc6_2.7-18_i386.deb) ...
Checking for services that may need to be restarted...
Checking init scripts...
readlink: invalid option -- e
Try `readlink --help' for more information.
WARNING: POSIX threads library NPTL requires kernel version
2.6.8 or later. If you use a kernel 2.4, please upgrade it
before installing glibc.
The installation of a 2.6 kernel _could_ ask you to install a new libc
first, this is NOT a bug, and should *NOT* be reported. In that case,
please add etch sources to your /etc/apt/sources.list and run:
  apt-get install -t etch linux-image-2.6
Then reboot into this new kernel, and proceed with your upgrade
dpkg: error processing /var/cache/apt/archives/libc6_2.7-18_i386.deb (--unpack):
 subprocess pre-installation script returned error exit status 1
Egal was ich mache, auch wenn ich die Pakete installieren will, die ich brauche um einen eigenen Kernel zu backen. Es geht nicht.
Auch wenn ich die Systemsprache umstelle und ein Reboot durchführe, es wird nicht übernommen.
Die Log's sind sauber und ich am Ende *lach*
Kernel 2.6 kann ick ja nit so installieren.
Nu hab ich mich festgefahren und wes nicht mehr weiter. Wer hat paar bohlen um ausm Loch zukommen ?
Dennis
Dies tat auch nicht sein übriges.
In der source.list kann ich eintragen was ich möchte, jedoch kam immer das gleiche Spiel bei raus.
