Kein ssh, https
Status
Not open for further replies.
Walter12b
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
#Deprecated option: KeyRegenerationInterval 3600
#Deprecated option: ServerKeyBits 1024
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
#Deprecated option: RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
#Deprecated option: RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
PermitUserEnvironment yes
# Kerberos options
# GSSAPI options
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
AcceptEnv LANG LC_*
UsePAM yes
Walter12b
Port 22
#ListenAddress ::
Protocol 2
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin yes
StrictModes yes
IgnoreRhosts yes
# Kerberos options
# GSSAPI options
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
AcceptEnv LANG LC_*
UsePAM yes
# Kerberos options
# GSSAPI options
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
AcceptEnv LANG LC_*
UsePAM yes
Walter12b
Ich arbeite über Putty. Ohne Remote Console bekomme ich keinen Zugriff auf den Server (Nicht mal ein Login)
GwenDragon
Also ich komme aber bis zum Login des Servers mit Windows 10 ssh.
T:\>ssh root@h2483216.stratoserver.net
The authenticity of host 'h2483216.stratoserver.net (81.169.251.222)' can't be established.
ECDSA key fingerprint is SHA256:xZOnDSq3Ez25un7YuzDui+jAh+eKF5tlvpn4k58MuB8.
Are you sure you want to continue connecting (yes/no/[fingerprint])?
Und du?
Verwendest du ein VPN oder ein Proxy?
Walter12b
Wenn der Server über Remote Console gestartet ist, dann komme ich auf die Remote Console und auf den Rechner
Ich hab den Server jetzt mal im normal Modus gestartet und dann kommt die Fehlermeldung
connection refused
Ich geh direkt per dsl ohne weitere Einstellungen auf den Server.
GwenDragon
Ich erkannte nicht, dass du noch die Rettungskonsole am Server dran hast udn das gar nicht der Normalbetrieb ist.
Ich weiß nicht was Strato mit der Wartung da bei dir vermurkst hat.
Musst du wohl von denen kostenpflichtig reparieren lassen oder jemand hier im Forum unter Suche beauftragen.
Status
