Festplatte defekt oder RAID kaputt?
p0se
ich habe einen Dedizierte Server bei Hetzner der mir seit kurzem folgende Mails schickt.
This is an automatically generated mail message from mdadm running on hostname.de
A DegradedArray event had been detected on md device /dev/md/0.
Faithfully yours, etc.
P.S. The /proc/mdstat file currently contains the following:
Personalities : [raid1] [linear] [multipath] [raid0] [raid6] [raid5] [raid4] [raid10]
md2 : active raid1 sda3[0](F) sdb3[1]
      232624448 blocks super 1.2 [2/1] [_U]
      bitmap: 2/2 pages [8KB], 65536KB chunk
md0 : active raid1 sda1[0](F) sdb1[1]
      16760832 blocks super 1.2 [2/1] [_U]
md1 : active raid1 sda2[0](F) sdb2[1]
      523712 blocks super 1.2 [2/1] [_U]
unused devices: <none>
Die Mail bekomme ich immer drei mal.
A DegradedArray event had been detected on md device /dev/md/1
A DegradedArray event had been detected on md device /dev/md/2
Auf dem Server soll ein Raid 1 mit zwei SSDs laufen.
lsblk
NAME    MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sda       8:0    0 238.5G  0 disk
├─sda1    8:1    0    16G  0 part
│ └─md0   9:0    0    16G  0 raid1 [SWAP]
├─sda2    8:2    0   512M  0 part
│ └─md1   9:1    0 511.4M  0 raid1 /boot
└─sda3    8:3    0   222G  0 part
  └─md2   9:2    0 221.9G  0 raid1 /
sdb       8:16   0 238.5G  0 disk
├─sdb1    8:17   0    16G  0 part
├─sdb2    8:18   0   512M  0 part
└─sdb3    8:19   0   222G  0 part
mdadm --detail /dev/md0
/dev/md0:
           Version : 1.2
     Creation Time : Fri Aug 10 07:37:44 2018
        Raid Level : raid1
        Array Size : 16760832 (15.98 GiB 17.16 GB)
     Used Dev Size : 16760832 (15.98 GiB 17.16 GB)
      Raid Devices : 2
     Total Devices : 2
       Persistence : Superblock is persistent
       Update Time : Sat Nov 17 03:47:01 2018
             State : clean, degraded
    Active Devices : 1
   Working Devices : 1
    Failed Devices : 1
     Spare Devices : 0
Consistency Policy : resync
              UUID : dd523ce1:157d5f8f:8d8080e0:2cdc6b5f
            Events : 58
    Number   Major   Minor   RaidDevice State
       -       0        0        0      removed
       1       8       17        1      active sync   /dev/sdb1
       0       8        1        -      faulty   /dev/sda1
mdadm --detail /dev/md1
/dev/md1:
           Version : 1.2
        Raid Level : raid1
        Array Size : 523712 (511.44 MiB 536.28 MB)
     Used Dev Size : 523712 (511.44 MiB 536.28 MB)
      Raid Devices : 2
     Total Devices : 2
       Update Time : Tue Nov 20 06:26:19 2018
    Active Devices : 1
   Working Devices : 1
    Failed Devices : 1
     Spare Devices : 0
              UUID : b3b5cecd:945c5e2b:be3b7d1c:344c64ab
            Events : 68
       -       0        0        0      removed
       1       8       18        1      active sync   /dev/sdb2
       0       8        2        -      faulty   /dev/sda2
mdadm --detail /dev/md2
/dev/md2:
           Version : 1.2
        Raid Level : raid1
        Array Size : 232624448 (221.85 GiB 238.21 GB)
     Used Dev Size : 232624448 (221.85 GiB 238.21 GB)
      Raid Devices : 2
     Total Devices : 2
     Intent Bitmap : Internal
       Update Time : Tue Nov 20 08:07:16 2018
    Active Devices : 1
   Working Devices : 1
    Failed Devices : 1
     Spare Devices : 0
Consistency Policy : bitmap
              UUID : 84212392:eda2b623:c8b33612:f1b70bf7
            Events : 547010
       -       0        0        0      removed
       1       8       19        1      active sync   /dev/sdb3
       0       8        3        -      faulty   /dev/sda3
smartctl -a /dev/sda ergibt folgende Meldung
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.0-29-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Short INQUIRY response, skip product id
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
smartctl -a -T permissive /dev/sda ergibt folgendes
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature:     0 C
Drive Trip Temperature:        0 C
Read defect list: asked for grown list but didn't get it
Error Counter logging not supported
Device does not support Self Test logging
smartctl -a /dev/sdb ergibt...
=== START OF INFORMATION SECTION ===
Device Model:     Micron_1100_MTFDDAK256TBN
Serial Number:    171919DDE6E6
LU WWN Device Id: 5 00a075 119dde6e6
Firmware Version: M0MU031
User Capacity:    256,060,514,304 bytes [256 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Nov 20 08:11:57 2018 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  633) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (   4) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x0035) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   000    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0032   100   100   010    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       2484
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   096   096   000    Old_age   Always       -       68
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   061   052   000    Old_age   Always       -       39 (Min/Max 26/48)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
202 Unknown_SSD_Attribute   0x0030   096   096   001    Old_age   Offline      -       4
206 Unknown_SSD_Attribute   0x000e   100   100   000    Old_age   Always       -       0
246 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       11330572371
247 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       357375397
248 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       493721736
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000    Pre-fail  Always       -       2047
210 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Vendor (0xff)       Completed without error       00%      2467         -
# 2  Vendor (0xff)       Completed without error       00%      2228         -
# 3  Vendor (0xff)       Completed without error       00%      2026         -
# 4  Vendor (0xff)       Completed without error       00%      1803         -
# 5  Vendor (0xff)       Completed without error       00%      1519         -
# 6  Vendor (0xff)       Completed without error       00%      1306         -
# 7  Vendor (0xff)       Completed without error       00%      1110         -
# 8  Vendor (0xff)       Completed without error       00%       926         -
# 9  Vendor (0xff)       Completed without error       00%       718         -
#10  Vendor (0xff)       Completed without error       00%       533         -
#11  Vendor (0xff)       Completed without error       00%       349         -
#12  Vendor (0xff)       Completed without error       00%       138         -
#13  Extended offline    Completed without error       00%        12         -
#14  Extended offline    Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Completed [00% left] (119344-184879)
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Was ich nicht so ganz verstehe ist warum "smartctl -a /dev/sdb" die entsprechende Ausgabe liefert und "smartctl -a /dev/sda" nicht?!
Für mich stellt sich nun die Frage, ist die Festplatte "sda" kaputt oder hat sich das Raid nur zerlegt?
Da ich leider noch keine Erfahrung in dem Bereich sammeln konnte, und ein wenig angst habe mir die noch funktionierende Festplatte zu zerschießen, bin ich da jetzt ein wenig vorsichtig. Der Server läuft an sich noch im live Betrieb.
Sollte ich versuche das Raid wiederherzustellen oder kann man davon ausgehen das die Festplatte defekt ist?
Wenn ich es richtig verstanden habe, wird das Raid in meinem Fall durch folgende Befehle wiederhergestellt.
mdadm --manage /dev/md0 --add /dev/sda1
mdadm --manage /dev/md1 --add /dev/sda2
mdadm --manage /dev/md2 --add /dev/sda3
Ist das so richtig?
Stimme der Bewertung von Gwen zu.
Weitere Ergänzung: Schau Dir doch mal die Ausgabe von dmesg hinsichtlich SSD-Fehler durch.
dmesg zeigt nur die letzten n Nachrichten an. Aber wenn die SSD nicht mehr ansprechbar ist, sollte für den Hetzner-Support deine smartctl-Ausgabe ausreichen. Und wenn nicht, werden sie es dir schon sagen. =)
Ich habe mir die Anleitung bei Hetzner mal angeschaut.
Sieht ja auf den ersten Blick machbar aus.
Laut Hetzner wird der Server herunterfahren zum tausch der Festplatte.
Würde der dann überhaupt wieder hoch kommen? Der bootet ja eigentlich von sda auch wenn es ein RAID ist. Wenn sda aber kaputt ist, springt der Bootprozess dann auf sdb um?
Oder geht es dann nur in der recovery Umgebung?
War da nicht mal was, dass man den Bootloader explizit manuell auf beide Platten schreiben muss, dass das funktioniert, oder macht das grub mittlerweile selbst?
also:
grub-install /dev/sda
grub-install /dev/sdb
Ja, am besten den Bootloader auf beide HDDs schreiben. Zur Not kann man den aber via Rescue-System und chroot auch noch mal neu auf die andere HDD schreiben.
Das mache ich ja natürlich sobald die Festplatte ausgetauscht wurde.
meine Frage wäre ob Grub wohl schon jetzt auf sdb installiert ist, wie ich das prüfen könnte und ob ich es jetzt noch installieren kann wenn sba defekt ist?
